MPQ29252-AEC1
- Control MethodDigital Control
- System InterfaceI2C
- Memory TypeMTP
- Number of Rails1
- フェーズ数8
- VCC (typ) (V)3.3
- Iq (typ) (mA)38
- fsw(最大)(kHz)1500
- Wettable Flank QFN OptionNo
- パッケージ(mm)TLGA-40 (5x5)
The MPQ29252-AEC1 is a digital controller that supports high-current, multi-phase voltage regulators (VRs). The device works together with external power stages to create a hybrid buck or standard multi-phase VR solutions. The MPQ29252-AEC1 can sense current via the inductor's DC resistance (DCR).
The MPQ29252-AEC1 can be configured for up to 8-phase operation to support 4-block hybrid buck topology with an external AND gate, and can be configured for up to 6-phase operation to support 3-block hybrid buck topology with an internal AND gate (PWMx_xN).
The MPQ29252-AEC1 provides an on-chip non-volatile memory (NVM) to store and restore device configurations. Device configurations and fault parameters can be easily configured or monitored via the PMBus/I2C interface.
The MPQ29252-AEC1 is based on a unique, digital, multi-phase nonlinear control to provide a fast transient response to the load transient with minimal output capacitors. With only one power-loop control method for both steady state and load transient, power loop compensation is very easy to configure.
The MPQ29252-AEC1 is available in a TLGA-40 (5mmx5mm) package, and is available in AEC-Q100 Grade 1.
- Up to 8-Phase Digital Controller
- PMBus/I2C Compliant (800kHz Bus Speed)
- Pin-Configurable for PMBus Address
- Built-In Non-Volatile Memory (NVM) to Store Configurations
- 120kHz to 1.5MHz Switching Frequency (fSW)
- Up to 3-Point Block Topology Works with Internal AND Gate
- Up to 4-Point Block Topology Works with External AND Gate
- Automatic Loop Compensation
- Selectable Open-Loop or Closed-Loop Control
- VFLYCAP Under-Voltage (UV) Monitor
- Supports Multi-Configuration for 6 Different Applications
- Active Current Sharing between Modules
- Flexible Output Current (IOUT) Sense via the Inductor's DC Resistance (DCR)
- Phase-to-Phase Active Current Balancing with Configurable Offsets for Thermal Balance
- Input Voltage (VIN), Output Voltage (VOUT), Current, and Power Monitoring
- VIN Under-Voltage Lockout (UVLO), Output Over-Voltage (OVP)/Under-Voltage Protection (UVP), Fast Over-Current Protection (OCP), Slow OCP, Over-Temperature Protection (OTP) with No Action, Latch, or Hiccup Options
- Auto-Records Voltage Regulator (VR) Fault Type to NVM
- Digital Load-Line Regulation
- Overclocking Mode by Adding Offset to VOUT
- Password Lock for Accessing Registers
- Available in a TLGA-40 (5mmx5mm) Package
MPQ29252GLUT-xxxx-AEC1-Z MPQ29252GLUT-xxxx-AEC1-P
MPQ29252-AEC1 Resources
SOC用コア電源 - デジタルマルチフェーズコントローラ製品カテゴリ -
USE CASE
INTELLI-PHASEソリューション使用事例: AIヒューマノイドロボット使用例このユースケースでは、 人工知能 (AI) ヒューマノイドロボットにおけるMPQ86750とMPQ2967のアプリケーションについて調べます。 MPQ2967と組み合わせたMPQ86750のIntelli-Phase™ソリューションは、AIヒューマノイド・ロボット・システムオンチップ (SoC) プラットフォーム向けの高効率な電源管理を提供し、信頼性の向上、コンパクトなサイズ、シンプルな設計を実現します。 AIヒューマノイドロボットは、センサデータに基づく意思決定、物体の操作、物理的環境のナビゲート、機械学習アルゴリズムを使用した適応などの複雑な機能を備え、人間のような動きや相互作用を模倣します。これらの機能は、かなりの計算能力を必要とする高度なAIアルゴリズムに基づいています。その結果、AIヒューマノイドロボットの設計者は、安全リスク、部品の損傷、およびシステ...
MPQ72957FS-AEC1製品ASIL-D, 4-Rail, 8-Phase Controller with I2C Interface, AEC-Q100 Qualified
MPQ29164-AEC1製品IMVP8 / 9 / 9.1用I2Cインタフェース付き、デジタル、6フェーズコントローラ、AEC-Q100認定済み
MPQ29125-AEC1製品3-Rail, Multi-Phase Controller, AEC-Q100 Qualified
USE CASE
INTELLI-PHASE™ ソリューション使用事例 : 中央コンピュータ使用例この使用事例では、 自律走行車の中央コンピュータのMPQ2946とMPQ86760のアプリケーションを検討します。 MPQ2946とMPQ86760は、高電力密度、汎用性、統合設計などの機能を備えた、自律走行車の中央コンピュータ向けの2つの最先端の電力変換ソリューションを提供します。 自動運転車内の中央コンピュータは、リアルタイムのデータ処理、環境の検知とモニタリング、動作制御に関する重要な意思決定など、集中的な作業負荷を処理します。電力コンバータのサイズを大きくすると、中央コンピュータに必要なより高い電力消費と供給に対応できます。ただし、大きくてかさばる電力コンバータは重量の増加により、車両の全体的な航続距離と性能も低下させます。その結果、自動車の設計者は、中央コンピュータのかなりの処理能力に対応できる、簡素化された電力コンバータ設計を求めています。 MPQ2946とM...
MPQ2946製品シリアルインタフェース付きデジタル、8フェーズコントローラ、AEC-Q100認定
車載用SOCコアレールに電力供給する場合の課題とチャンス寄稿文自動車業界は、電気自動車 (EV)、自動運転、ハイエンド インフォテインメントシステム、車両コネクティビティおよびソフトウェア デファインド ビークルに対応するために大きな変革を迎えようとしています。EV変革の目標とメリット、および自動車サプライチェーンへの影響は、現在では十分に理解されています。 ただし、自動運転とハイパフォーマンス コンピューティング (HPC) に向けたデジタル変革は初期段階で、まだ進化し続けています。この変革は、EVと内燃機関 (ICE) 車両の両方に適用されます。こうした将来有望なトレンドによる技術の混乱は、自動車のサプライチェーンに課題とチャンスをもたらすでしょう。 人口増加と都市化が続くため、現代の交通機関は渋滞、事故、移動手段の不足に悩まされており、社会経済に悪影響を及ぼしています (図1参照)。個人使用向けの自動運転車やコネクテッドカー、公共交通機関向...
USE CASE
自動運転の使用事例使用例2004年~2007年の間に、自動運転が米国で開始され、3つの無人運転への挑戦が行われました。自動運転が産業化の時代に入った今、共通の課題に対処し、複雑なシステム全体でパフォーマンスを向上させることが重要です。この使用事例では、自動運転でMPQ2967-AEC1、MPQ86960、MPQ79500FS-AEC1とMPQ79700FS-AEC1のアプリケーションを検証します。 自動運転車は、センサと演算ユニットを使用するインテリジェントな車両です。コアハードウェアモジュールには、電子制御ユニット (ECU)、ドメイン制御ユニット (DCU)、およびセンサが含まれます。SAE Internationalによって発行されたSAE J3016TM 基準によると、自動運転はL0からL5までの6つのレベルに分類されます。ここで、L0は緊急事態 (例 : 早期警告や瞬間的な支援) での運転支援を指...
MPQ2977-AEC1製品シリアルインタフェ-ス付きデジタル 6相コントローラ、AEC-Q100認定
MPQ2967-AEC1製品PMBusインタフェースを備えたデュアルレール、デジタル、4フェーズコントローラ、AEC-Q100認定
MPQ79520FS-AEC1製品MPSafeTM, ASIL-D, 5-Channel Voltage Monitor, AEC-Q100 Qualified
MPQ79505FS-AEC1製品MPSafeTM, ASIL-D, 6-Channel Voltage Monitor with Integrated Watchdog Timer, AEC-Q100 Qualified
