MPQ29252-AEC1
- Control MethodDigital Control
- System InterfaceI2C
- Memory TypeMTP
- Number of Rails1
- Number of Phases8
- VCC (typ) (V)3.3
- Iq (typ) (mA)38
- fsw (max) (kHz)1500
- Wettable Flank QFN OptionNo
- Package (mm)TLGA-40 (5x5)
The MPQ29252-AEC1 is a digital controller that supports high-current, multi-phase voltage regulators (VRs). The device works together with external power stages to create a hybrid buck or standard multi-phase VR solutions. The MPQ29252-AEC1 can sense current via the inductor's DC resistance (DCR).
The MPQ29252-AEC1 can be configured for up to 8-phase operation to support 4-block hybrid buck topology with an external AND gate, and can be configured for up to 6-phase operation to support 3-block hybrid buck topology with an internal AND gate (PWMx_xN).
The MPQ29252-AEC1 provides an on-chip non-volatile memory (NVM) to store and restore device configurations. Device configurations and fault parameters can be easily configured or monitored via the PMBus/I2C interface.
The MPQ29252-AEC1 is based on a unique, digital, multi-phase nonlinear control to provide a fast transient response to the load transient with minimal output capacitors. With only one power-loop control method for both steady state and load transient, power loop compensation is very easy to configure.
The MPQ29252-AEC1 is available in a TLGA-40 (5mmx5mm) package, and is available in AEC-Q100 Grade 1.
- Up to 8-Phase Digital Controller
- PMBus/I2C Compliant (800kHz Bus Speed)
- Pin-Configurable for PMBus Address
- Built-In Non-Volatile Memory (NVM) to Store Configurations
- 120kHz to 1.5MHz Switching Frequency (fSW)
- Up to 3-Point Block Topology Works with Internal AND Gate
- Up to 4-Point Block Topology Works with External AND Gate
- Automatic Loop Compensation
- Selectable Open-Loop or Closed-Loop Control
- VFLYCAP Under-Voltage (UV) Monitor
- Supports Multi-Configuration for 6 Different Applications
- Active Current Sharing between Modules
- Flexible Output Current (IOUT) Sense via the Inductor's DC Resistance (DCR)
- Phase-to-Phase Active Current Balancing with Configurable Offsets for Thermal Balance
- Input Voltage (VIN), Output Voltage (VOUT), Current, and Power Monitoring
- VIN Under-Voltage Lockout (UVLO), Output Over-Voltage (OVP)/Under-Voltage Protection (UVP), Fast Over-Current Protection (OCP), Slow OCP, Over-Temperature Protection (OTP) with No Action, Latch, or Hiccup Options
- Auto-Records Voltage Regulator (VR) Fault Type to NVM
- Digital Load-Line Regulation
- Overclocking Mode by Adding Offset to VOUT
- Password Lock for Accessing Registers
- Available in a TLGA-40 (5mmx5mm) Package
MPQ29252GLUT-xxxx-AEC1-Z MPQ29252GLUT-xxxx-AEC1-P
MPQ29252-AEC1 Resources
SOC CORE POWER - DIGITAL MULTI-PHASE CONTROLLERSPRODUCT CATEGORY -
MPQ72963FS-AEC1PRODUCTMPSafeTM, ASIL-D, 3-Rail, 9-Phase Controller with Digital Interface, AEC-Q100 Qualified
MPQ29260-AEC1PRODUCT60V, Multi-Phase Step-Down Controller, AEC-Q100 Qualified
USE CASE
MPQ72957FS-AEC1PRODUCTASIL-D, 4-Rail, 8-Phase Controller with I2C Interface, AEC-Q100 Qualified
MPQ29164-AEC1PRODUCTDigital, 6-Phase Controller with I2C Interface for IMVP8/9/9.1, AEC-Q100 Qualified
MPQ29125-AEC1PRODUCT3-Rail, Multi-Phase Controller, AEC-Q100 Qualified
USE CASE
INTELLI-PHASETM SOLUTION USE CASE: CENTRAL COMPUTERSUSE CASEThis use case examines the application of the MPQ2946 and MPQ86760 in central computers for autonomous vehicles. The MPQ2946 and MPQ86760 provide two cutting-edge power conversion solutions for central computers in autonomous vehicles with features including high power density, versatility, and integrated design. Central computers within autonomous vehicles power an intensive workload, inc...
MPQ2946PRODUCTDigital, 8-Phase Controller with Three Rails, AEC-Q100 Qualified
CHALLENGES AND OPPORTUNITIES WHEN POWERING AUTOMOTIVE SOC CORE RAILSARTICLEThe automotive industry is undergoing a major transformation to support electric vehicles (EVs), autonomous driving, high-end infotainment systems, vehicle connectivity, and software-defined vehicles. The goals and benefits of EV transformation, and its impact on the automotive supply chain, are well understood by now. However, the digital transformation towards autonomous driving and high-perfor...
USE CASE
AUTONOMOUS DRIVING USE CASEUSE CASEBetween 2004 and 2007, autonomous driving was launched in the United States with three unmanned driving challenges. As autonomous driving now enters the era of industrialization, it is important to address common challenges and boost performance across complex systems. This use case examines the application of the MPQ2967-AEC1, MPQ86960, MPQ79500FS-AEC1, and MPQ79700FS-AEC1 in autonomous driving. ...
MPQ2977-AEC1PRODUCTDigital 6-Phase Controller with Serial Interface, AEC-Q100 Qualified
MPQ2967-AEC1PRODUCTDual-Rail, Digital, 4-Phase Controller with PMBus Interface, AEC-Q100 Qualified
MPQ79520FS-AEC1PRODUCTMPSafeTM, ASIL-D, 5-Channel Voltage Monitor, AEC-Q100 Qualified
MPQ79505FS-AEC1PRODUCTMPSafeTM, ASIL-D, 6-Channel Voltage Monitor with Integrated Watchdog Timer, AEC-Q100 Qualified
MPQ79731FS-AEC1PRODUCTMPSafeTM, ASIL-B, 6-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79571FS-AEC1PRODUCTMPSafeTM, ASIL-D, Wide 36V VIN, Window Voltage Supervisor, AEC-Q100 Qualified
MPQ1966-AEC1PRODUCT100V, 4A, High-Frequency, Half-Bridge, N-Channel Power Gate Driver
MPQ86761-AEC1PRODUCT60A Intelli-PhaseTM Solution in a TQFN-21 (3.5mmx6mm) Package, AEC-Q100 Qualified
MPQ86725-AEC1PRODUCTIntelli-PhaseTM Solution in TQFN (3.5mmx4mm) Package, AEC-Q100 Qualified
