MPQ4236-AEC1
36V, 8A, Switching Current Buck-Boost Converter with Four Integrated MOSFETs and I2C-Adjustable OCP, AEC-Q100 Qualified
- Vin (min) (V)4
- Vin (max) (V)36
- Iout (max) (A)5
- Iq (typ) (mA)0.28
- Vfb (V)0 to 2.0475
- fsw (max) (kHz)2100
- Control ModeCurrent Mode
- Package (mm)QFN-18 (3x4)
- GradeAutomotive
- Isw Limit (typ) (A)10
- Max Duty Cycle (%)80
- Regulated Outputs1
- Vout (max) (V)26
- Vout (min) (V)1
The MPQ4236-AEC1 is a buck-boost converter with four power MOSFETs. The device can deliver up to 60W of output power at certain input supply ranges with excellent efficiency.
The MPQ4236-AEC1 is suitable for battery pre-regulators, USB power delivery (PD), and wireless charging applications. It can work well with external PD or wireless charging controllers via the I2C interface.
The I2C interface and one-time programmable (OTP) memory provide flexibility for configurable parameters.
The adjustable switching frequency (fSW) (up to 2MHz) during continuous conduction mode (CCM) greatly reduces the external inductance and capacitance. Fault condition protections include constant-current (CC) limiting, output and input over-voltage protection (OVP), and thermal shutdown (TSD).
The MPQ4236-AEC1 requires a minimal number of readily available, standard external components. It is available in a small QFN-18 (3mmx4mm) package with wettable flanks, and is available in AEC-Q100 Grade 1.
- 350μA Low Quiescent Current (IQ)
- 8A Average Inductor Current (IL)
- 4V to 36V Operating Input Voltage (VIN) Range
- 1V to 26V Output Voltage (VOUT) Range
- 0V to 2.047V I2C-Configurable Reference Voltage (VREF) Range with 0.5mV Resolution
- SWA/SWB/SWC/SWD On Resistance (RDS(ON)): 15mΩ/21mΩ/14mΩ/13mΩ
- Integrated 5V/60mA Low-Dropout (LDO) Regulator to Supply External Microcontroller Unit (MCU)
- Selectable Input or Output Constant-Current (CC) Limit with 5% Accuracy via Factory Trimming
- Input Over-Voltage Protection (OVP) Function
- Selectable Switching Frequency (fSW) with Frequency Spread Spectrum (FSS): 280kHz, 420kHz, 600kHz,
- 1.2MHz, or 2MHz
- External Clock Synchronization
- Selectable Automatic Pulse-Frequency Modulation (PFM) or Pulse-Width Modulation (PWM) Mode and Forced PWM Mode
- Configurable I2C Target Address Supported by the ADDR Pin and I2C Register
- Line Drop Compensation
- Power Good (PG) Indication
- I2C, Alert, and One-Time Programmable (OTP) Memory
- Enable (EN) Shutdown Passive Discharge
- Available in a QFN-18 (3mmx4mm) Package
MPQ4236GLE-xxxx-AEC1-Z MPQ4236GLE-xxxx-AEC1-P MPQ4236GLE-0000-AEC1-Z MPQ4236GLE-0000-AEC1-P
MPQ4236-AEC1 Resources
STEP-DOWN/STEP-UP CONVERTERSPRODUCT CATEGORY -
USB PD POWER STAGEPRODUCT CATEGORY -
STEP-DOWN/STEP-UP (BUCK-BOOST) CONVERTERS AND CONTROLLERSPRODUCT CATEGORY -
TRACTION INVERTER SYSTEMAPPLICATIONAn engine roaring is becoming a sound of the past, as the adoption of electric vehicles (EVs) continues to grow at an exponential rate. Soon the only sound will be the whirring an EV motor as the traction inverter delivers power from the battery. Traction inverters are instrumental in converting energy from the high-voltage battery (400V/800V) into three-phase AC energy to drive the vehicle’s moto...
ONBOARD CHARGING MODULE (OBCM)APPLICATIONElectric vehicles (EVs) are becoming more present every day, with the adoption of EVs growing at an exponential rate. Onboard charging (OBC) is a very important part of EVs, since it determines the maximum possible charge rate while an AC charger is connected to the vehicle. The maximum charge capability for a fully electric vehicle is typically between 6.6kW and 22kW, and for a plug-in hybrid veh...
DC FAST CHARGING STATIONAPPLICATIONDC fast charging stations are becoming more common with the increased adoption of electric vehicles. Charging stations are a vital part of the infrastructure along major highways and populated suburbs, ensuring that electric vehicles have a place to charge during long-distance travel and day-to-day driving. These systems are often comprised of multiple 25kW to 75kW modules to create fast charging ...
HEADLIGHTSAPPLICATIONHeadlights remain one of the most important functional safety features in any vehicle. While not a new feature, most new car models now feature LED headlights to provide increased brightness, better efficiency, and longer headlight lifespans. And of course, as with any automotive application, headlight designs must meet strict thermal requirements, ISO26262 safety standards, and EMC regulations. ...
USB TYPE-C POWER DELIVERYAPPLICATIONUSB Type-C power delivery (PD) is gaining popularity across applications and markets, including in automotive. USB ports have become an expected standard in most car models, and are typically expected to offer both charging and data functionality. USB Type-C improves on older USB designed by offering a smaller, reversible port for easy plug-in and double the transfer speed of USB 3.0. USB PD proto...
MPQ8878-AEC1PRODUCT36V, 10A, Four-Switch, Synchronous Buck-Boost Converter with ZDPTM, AEC-Q100 Qualified
MPQ8837-AEC1PRODUCT36V, 8A, 4-Switch, Synchronous Buck-Boost Converter with CC/CV Operation and I2C, AEC-Q100 Qualified
MPQ4232A-AEC1PRODUCT36V, 6A Buck-Boost Converter with Four Integrated MOSFETs and I2C Interface, AEC-Q100 Qualified
MPQ8887-AEC1PRODUCT65V, 9A, High-Efficiency Buck Converter with I2C Interface, Configurable Frequency, and Adjustable OCP, AEC-Q100 Qualified
MPQ4201-AEC1PRODUCT100V, Synchronous, Bidirectional Buck-Boost Controller with I2C, Battery Charging, and Adjustable OCP and PG Indication, AEC-Q100 Qualified
