MPQ8887-AEC1
65V, 9A, High-Efficiency Buck Converter with I2C Interface, Configurable Frequency, and Adjustable OCP, AEC-Q100 Qualified
- Vin (min) (V)4.5
- Vin (max) (V)65
- Iout (max) (A)9
- Iq (typ) (mA)0.5, 0.18
- Vfb (V)0.8
- fsw (max) (kHz)600
- Control ModeCurrent Mode
- Package (mm)QFN-24 (4x5)
- GradeAutomotive
- Isw Limit (typ) (A)12, 10
- Max Duty Cycle (%)100
- Regulated Outputs1
- Vout (max) (V)55
- Vout (min) (V)1
The MPQ8887-AEC1 is a high-efficiency, synchronous step-down converter with two integrated power MOSFETs capable of regulating the output voltage (VOUT) across a wide input voltage (VIN) range with high efficiency. It can achieve up to 9A of peak output current (IOUT), and offers VOUT scaling and an adjustable average IOUT limit. This makes it ideal for wireless charging, USB Extended Power Range (EPR) Power Delivery (PD), and high-power DC power supply applications.
VOUT can be controlled on the fly via the I2C serial interface. The voltage transition slew rate, switching current limit, average IOUT limit, and output over-voltage protection (OVP) can also be selected via the I2C interface.
Current mode control provides fast transient response and eases loop stabilization. Full protection features include input under-voltage lockout (UVLO), input and output OVP, output over-current protection (OCP), and thermal shutdown.
The MPQ8887-AEC1 supports a one-time programmable (OTP) memory to provide flexible configurations.
The MPQ8887-AEC1 offers a very compact solution with a minimal number of readily available, standard external components, and is available in a QFN-24 (4mmx5mm) package. It is AEC-Q100 qualified.
- Wide 4.5V to 65V Input Voltage (VIN) Range, 70V Absolute Maximum Voltage
- Wide 1V to 55V Output Voltage (VOUT) Range
- 0V to 2.047V Feedback Reference Voltage Range, with 0.5mV/Step
- Up to 9A Peak Current
- Up to 97.67% efficiency at 36VOUT/5A Load
- 180µA Low Quiescent Current (IQ) when I2C Operation Is Off
- Configurable Peak/Valley Current Limit
- Capable of 4-Phase Parallel with Phase Shift
- Supports True 100% Duty Cycle Operation
- ±5% Output Constant Current (CC) Current Limit Accuracy
- Automatic Advanced Asynchronous Modulation (AAM)/Pulse-Width Modulation (PWM) Mode, Forced PWM (FPWM) Mode with Frequency Spread Spectrum (FSS) Selection
- Configurable 200kHz to 600kHz Switching Frequency (fSW) with Clock Synchronization
- 14mΩ/18mΩ Low On Resistance (RDS(ON)) Internal Buck Power MOSFETs
- Supports VCC Voltage (VCC) Bias Function to Improve Efficiency
- Configurable Line Drop Compensation
- Configurable Output Discharge Current
- Over-Voltage Protection (OVP), Over-Current Protection (OCP), Over-Temperature Protection (OTP), and Interrupt
- Power Good (PG) Indication
- Available in a QFN-24 (4mmx5mm) Package with Wettable Flanks
MPQ8887GVE-xxxx-AEC1-Z MPQ8887GVE-xxxx-AEC1-P MPQ8887GVE-0000-AEC1-Z PQ8887GVE-0000-AEC1-P MPQ8887GVE-0001-AEC1-Z MPQ8887GVE-0001-AEC1-P
MPQ8887-AEC1 Resources
USB PD POWER STAGEPRODUCT CATEGORY -
HEAD UNITS (MID-RANGE)APPLICATIONAutomotive head unit designs have evolved from the traditional hardware interfaces into sophisticated infotainment systems that offer various in-cabin functionalities. These features include navigation, wireless connections, passenger entertainment, gesture recognition, and voice control. As consumer expectations for infotainment features continue to increase, manufacturers face design challenges ...
USB TYPE-C POWER DELIVERYAPPLICATIONUSB Type-C power delivery (PD) is gaining popularity across applications and markets, including in automotive. USB ports have become an expected standard in most car models, and are typically expected to offer both charging and data functionality. USB Type-C improves on older USB designed by offering a smaller, reversible port for easy plug-in and double the transfer speed of USB 3.0. USB PD proto...
