- MPQ4386-AEC1
MPQ4386-AEC1
36V, 30A, Low-EMI, Synchronous Step-Down Converters with ZDPTM, AEC-Q100 Qualified
- Vin (min) (V)3.3
- Vin (max) (V)36
- Iout (max) (A)30
- Iq (typ) (mA)0.009
- Vfb (V)0.8
- fsw (max) (kHz)2500
- Control ModeZero-Delay PWM Control (ZDPTM)
- Package (mm)TQFN-32 (5x6)
- GradeAutomotive
The MPQ4386-AEC1 is a configurable-frequency (200kHz to 2.5MHz) synchronous step-down switching regulator with integrated internal high-side and low-side power MOSFETs (HS-FET and LS-FET, respectively). It provides a highly efficient 30A output with fixed-frequency Zero-Delay pulse-width modulation (PWM) (ZDPTM) control for optimal transient response.
The wide 3.3V to 36V input voltage (VIN) range accommodates a variety of step-down applications in the automotive environment. A 1.5μA shutdown mode quiescent current (IQ) allows the device to be used in battery-powered applications.
High power conversion efficiency across a wide load range is achieved by scaling down the switching frequency (fSW) at light-load conditions to reduce switching and gate driver losses. An open-drain power good (PG) signal indicates whether the output is within 95% to 105% of its nominal voltage.
Frequency foldback helps prevent inductor current (IL) runaway during start-up. Thermal shutdown provides reliable, fault-tolerant operation. High duty cycle and low-dropout (LDO) mode are provided for the automotive cold-crank conditions.
The MPQ4386-AEC1 is available in a TQFN-32 (5mmx6mm) with a high thermal conductivity package to facilitate top-sided cooling applications. It is available in AEC-Q100 Grade 1.
- Designed for Automotive Transients:
- 3.3V to 36V Input Voltage (VIN) Range
- Load Dump Up to 40V
- Low-Dropout (LDO) Mode with Soft Recovery
- Highly Scalable Family:
- 30A Output Current (IOUT) Versions in Pin-Compatible Family
- Multi-Phase Capable Up to 8 Phases
- Designed for High Performance and Reduced Component Overhead:
- Zero-Delay Pulse-Width Modulation (PWM) (ZDPTM) Control for Extremely Fast Transient Response and Minimal External Capacitors
- ±1% Output Accuracy, ±1% PG Accuracy
- Fixed or Adjustable Output Voltage (VOUT) Options:
- Fixed Output: 0.8V, 1V, 1.2V, 1.8V, 3.3V, 3.8V, 4.5V, or 5V
- Adjustable VOUT Up to 13V
- Output Discharge from SW to GND
- 20ns Minimum On Time to Allow High Ratio Conversion
- High Efficiency for Increased Battery Life and Improved Thermals:
- 10μA Standby Current
- Advanced Asynchronous Modulation (AAM) Mode Increases Efficiency under Light Loads
- Integrated, Low-Resistance High-Side and Low-Side MOSFETs (HS-FET and LS-FET, Respectively)
- Thin QFN Package with High Thermal Conductivity to Facilitate Top-Side Cooling
- Optimized for Low EMC/EMI:
- 200kHz to 2.5MHz Configurable Switching Frequency (fSW)
- Symmetric VIN Pinout Placement
- Low Noise at High Frequency Bands via QuietFETTM Advanced Switching Technology
- Synchronizable to an External Clock
- CISPR 25 Class 5 Compliant
- Available in a Mesh-ConnectTM Flip-Chip, TQFN-32 (5mmx6mm) Package with Wettable Flanks
- MPSafeTM-Compatible: Functional Safety Supporting Document Available
MPQ4386GQJTHE-xxxx-AEC1-Z MPQ4386GQJTHE-xxxx-AEC1-P
MPQ4386-AEC1 Resources
HEADLIGHTSAPPLICATIONHeadlights remain one of the most important functional safety features in any vehicle. While not a new feature, most new car models now feature LED headlights to provide increased brightness, better efficiency, and longer headlight lifespans. And of course, as with any automotive application, headlight designs must meet strict thermal requirements, ISO26262 safety standards, and EMC regulations. ...
HEAD UNITS (MID-RANGE)APPLICATIONAutomotive head unit designs have evolved from the traditional hardware interfaces into sophisticated infotainment systems that offer various in-cabin functionalities. These features include navigation, wireless connections, passenger entertainment, gesture recognition, and voice control. As consumer expectations for infotainment features continue to increase, manufacturers face design challenges ...
