MPQ4201-AEC1
100V, Synchronous, Bidirectional Buck-Boost Controller with I2C, Battery Charging, and Adjustable OCP and PG Indication, AEC-Q100 Qualified
- Vin (min) (V)4.75
- Vin (max) (V)100
- Iout (max) (A)25
- Iq (typ) (mA)0.3
- Vfb (V)3.2 to 81.92
- fsw (max) (kHz)1000
- Control ModeCurrent Mode
- Package (mm)QFN-32 (5x6)
- GradeAutomotive
The MPQ4201-AEC1 integrates a synchronous, four-switch N-MOSFET driver supporting GaN with a bidirectional buck-boost controller capable of regulating different output voltages with a wide input voltage (VIN) range and high efficiency.
The MPQ4201-AEC1 provides an I2C interface with a one-time programmable (OTP) memory, which supports output voltage (VOUT) configuration, VOUT slew-rate control, and input current (IIN) and output current (IOUT) constant-current limit configuration. This makes the device suitable for USB Standard Power Range (SPR) and Extended Power Range (EPR) Power Delivery (PD) designs and high-power systems.
The MPQ4201-AEC1 provides forced continuous conduction mode (FCCM), automatic pulse-frequency modulation (PFM)/pulse-width modulation (PWM) selection mode, battery charging control, and a configurable switching frequency (fSW) with frequency spread spectrum function (FSS), which supports flexible designs for different applications.
It integrates battery charge cycle control with accurate battery voltage regulation, as well as pre-charge, constant-current (CC) and constant-voltage (CV) charge, termination charge detection, and status indication.
The MPQ4201-AEC1 also features configurable IIN and IOUT over-current protection (OCP) hiccup mode or continuous CC mode without hiccup, short-circuit protection (SCP), configurable input over-voltage protection (OVP) and under-voltage lockout (UVLO) thresholds, output OVP, and thermal shutdown (TSD). The NTC pin can be used to sense the PCB board or MOSFET temperature for over-temperature protection.
The MPQ4201-AEC1 is available in a QFN-32 (5mmx6mm) package with wettable flanks, and is AEC-Q100 qualified.
- 4-Switch, Bidirectional Buck-Boost Controller
- 4.75V to 100V Operating Input Voltage (VIN) Range Supports VIN <6V with a 7.7V to 14V External Bias via the VDDH Pin
- External Feedback Supports 100V Output Voltage (VOUT), Internal Feedback Supports 3.2V to 81.92V VOUT Range, with 20mV/Step
- 1µA Enable (EN) Shutdown Quiescent Current (IQ)
- 300µA IQ when I2C Operation Is Off
- Configurable, 0.5A to 25A Input/Output Continuous Current (CC) Limit, with 50mA/Step
- Supports 2mΩ/5mΩ Configurable Current-Sense (CS) Resistor
- Supports USB Power Delivery (PD) Standard Power Range (SPR) Programmable Power Supplies (PPS) and Extended Power Range (EPR) Adjustable Voltage Supplies (AVS)
- 200kHz, 400kHz, 600kHz, or 1MHz Switching Frequency (fSW) with Frequency Spread Spectrum (FSS) and Frequency SYNC Input
- Pulse-Frequency Modulation (PFM) or Forced Continuous Conduction Mode (FCCM) Selection
- Support 5V, 1.75A Source/4.5A Sink Ability Gate Driver Compliant with GaN
- Configurable VIN Under-Voltage Lockout (UVLO) via the One-Time Programmable (OTP) Memory
- Configurable VOUT Over-Voltage Protection (OVP)
- Configurable Input Regulation Threshold for Maximum Power Point Tracking (MPPT)
- System:
- Battery Charge Cycle Control with Status Indication
- I2C Interface with Interrupt Function
- Over-Current Protection (OCP), OVP, Power Good (PG), Negative Temperature Coefficient (NTC), and Thermal Shutdown Interrupt
- 10-Bit Analog-to-Digital Converter (ADC) Readout Function for VIN, Input Current (IIN), VOUT, Output Current (IOUT), and Temperature
- Available in a QFN-32 (5mmx6mm) Package with Wettable Flanks
- Available in AEC-Q100 in Grade 1
MPQ4201GQJE-xxxx-AEC1-Z MPQ4201GQJE-xxxx-AEC1-P MPQ4201GQJE-0000-AEC1-Z MPQ4201GQJE-0000-AEC1-P
MPQ4201-AEC1 Resources
STEP-DOWN/STEP-UP CONVERTERSPRODUCT CATEGORY -
STEP-DOWN/STEP-UP (BUCK-BOOST) CONVERTERS AND CONTROLLERSPRODUCT CATEGORY -
USB TYPE-C POWER DELIVERYAPPLICATIONUSB Type-C power delivery (PD) is gaining popularity across applications and markets, including in automotive. USB ports have become an expected standard in most car models, and are typically expected to offer both charging and data functionality. USB Type-C improves on older USB designed by offering a smaller, reversible port for easy plug-in and double the transfer speed of USB 3.0. USB PD proto...
MPQ8878-AEC1PRODUCT36V, 10A, Four-Switch, Synchronous Buck-Boost Converter with ZDPTM, AEC-Q100 Qualified
MPQ8837-AEC1PRODUCT36V, 8A, 4-Switch, Synchronous Buck-Boost Converter with CC/CV Operation and I2C, AEC-Q100 Qualified
MPQ4232A-AEC1PRODUCT36V, 6A Buck-Boost Converter with Four Integrated MOSFETs and I2C Interface, AEC-Q100 Qualified
MPQ8872-AEC1PRODUCT36V, 2A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface, AEC-Q100 Qualified
MPQ4208-AEC1PRODUCT80V, Synchronous Buck-Boost Controller with I2C And Adjustable OCP and PG Indication, AEC-Q100 Qualified
MPQ8835A-AEC1PRODUCT36V, 6A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface, AEC-Q100 Qualified
MPQ8874-AEC1PRODUCT36V, 4A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface, AEC-Q100 Qualified
MPQ4232-AEC1PRODUCT6A Buck-Boost Converter with Four Integrated MOSFETs and I2C Interface, AEC-Q100 Qualified
MPQ4483-AEC1PRODUCT3A, 36V Step-Down Converter with DCP Mode, CDP Mode, and Ground-to-Battery Short Protection for Automotive, AEC-Q100 Qualified
MPQ4263-AEC1PRODUCT36V, 140W Buck-Boost with Integrated LS-FETs, Supports High-Side Current Sense and I2C Interface for Automotive, AEC-Q100 Qualified
MPQ4262-AEC1PRODUCT36V, 100W, Buck-Boost Converter with Integrated Low-Side MOSFETS and an I2C Interface for Automotive, AEC-Q100 Qualified
