MPQ8878-AEC1
36V, 10A, Four-Switch, Synchronous Buck-Boost Converter with ZDPTM, AEC-Q100 Qualified
- Vin (min) (V)2.9
- Vin (max) (V)36
- Iout (max) (A)10
- Iq (typ) (mA)0.05
- Vfb (V)0.6
- fsw (max) (kHz)2200
- Control ModeZero-Delay PWM Control (ZDPTM)
- Package (mm)TQFN-23 (4x5)
- GradeAutomotive
The MPQ8878-AEC1 is a 36V, monolithic, synchronous buck-boost DC/DC converter. The wide 2.9V to 36V input voltage (VIN) range makes this device well-suited for multi-purpose automotive and industrial applications. Proprietary Zero-Delay PWMTM (ZDPTM) control and the device's fully integrated, four-switch configuration allow the chip to flexibly change the converter topology between buck, boost, and buck-boost modes. This optimizes performance and efficiency with input votlages that are above, below, or equal to the output voltage (VOUT). It also ensures seamless transitions between the adjacent operational regions.
The MPQ8878-AEC1 can be configured via a standard I2C interface, and UART versions are also available. The parameters can be adjusted by writing settings to the device without any hardware changes required.
The switching frequency (fSW) can be configured to 200kHz, 400kHz, 470kHz, 2200kHz, or it can be synchronized between 250kHz and 2.2MHz via an external clock signal. In addition, the configurable frequency spread spectrum (FSS) function can dither the fSW periodically for improved EMI performance.
Robust fault protections include input under-voltage lockout (UVLO), input over-voltage protection (OVP), cycle-by-cycle peak current limiting, output OVP, output short-circuit protection (SCP), and thermal shutdown. The built-in power good (PG) function can indicate whether VOUT is regulated properly.
The MPQ8878-AEC1 is available in a thermally enhanced TQFN-23 (4mmx5mm) package, and is available in AEC-Q100 Grade 1.
- 2.9V to 36V Wide Input Voltage (VIN) Range
- Load Dump Up to 40V
- Cold Crank Down to 2.9V
- Single-Channel, Four-Switch, Synchronous Buck-Boost Configuration
- Proprietary Zero-Delay PWMTM (ZDPTM) Control for Seamless Transitions
- Up to 10A of Continuous Output Current (IOUT) in Buck Mode
- 1μA Shutdown Current
- 50μA Quiescent Current (IQ)
- Easy-to-Optimize Efficiency and EMI Performance:
- Configurable 200kHz, 400kHz, 470kHz, or 2200kHz Switching Frequency (fSW)
- Synchronizable fSW
- Switching Frequency Spread Spectrum (FSS)
- Reduces Board Size and BOM:
- Integrated Compensation Network
- Fixed Output Voltage (VOUT) Options
- Rich Protections and Diagnostics:
- Configurable Input Under-Voltage Lockout (UVLO)
- Cycle-by-Cycle Current Limiting
- Input Over-Voltage Protection (OVP)
- Output Under-Voltage Protection (UVP)
- Over-Temperature Shutdown
- Power Good (PG) Indication
- Application Flexibility with I2C/UART Interface:
- 1Mb/s I2C Interface with Packet Error Checking (PEC)
- Configurable Parameters:
- Converter On/Off
- 1V to 24V VOUT Range
- fSW
- Switching Slew Rate
- FSS Setting
- Compensation Network
- Soft-Start Time (tSS)
- Dynamic VOUT Adjustment with Slew Rate Control
- Converter Mode Transition Threshold
- Asynchronous Advanced Modluation (AAM) Mode or Forced Continuous Conduction Mode (FCCM)
- Protection Threshold
- Fault Behaviors
- Power Good (PG) Threshold
- Additional Features:
- One-Time Programmable (OTP) for Default Parameter Settings
- Available in a Mesh-ConnectTM Flip-Chip TQFN-23 (4mmx5mm) Package
- Available in Thermal-Enhanced THQFN to Facilitate Top-Side Cooling
- Available with Wettable Flanks
MPQ8878GVTE-xxxx-AEC1-Z MPQ8878GVTE-xxxx-AEC1-P MPQ8878GVTE-0000-AEC1-Z MPQ8878GVTE-0000-AEC1-P MPQ8878GVTHE-xxxx-AEC1-Z MPQ8878GVTHE-xxxx-AEC1-P MPQ8878GVTHE-0000-AEC1-Z MPQ8878GVTHE-0000-AEC1-P
MPQ8878-AEC1 Resources
STEP-DOWN/STEP-UP (BUCK-BOOST) CONVERTERS AND CONTROLLERSPRODUCT CATEGORY -
USB TYPE-C POWER DELIVERYAPPLICATIONUSB Type-C power delivery (PD) is gaining popularity across applications and markets, including in automotive. USB ports have become an expected standard in most car models, and are typically expected to offer both charging and data functionality. USB Type-C improves on older USB designed by offering a smaller, reversible port for easy plug-in and double the transfer speed of USB 3.0. USB PD proto...
MPQ8837-AEC1PRODUCT36V, 8A, 4-Switch, Synchronous Buck-Boost Converter with CC/CV Operation and I2C, AEC-Q100 Qualified
MPQ4232A-AEC1PRODUCT36V, 6A Buck-Boost Converter with Four Integrated MOSFETs and I2C Interface, AEC-Q100 Qualified
MPQ4201-AEC1PRODUCT100V, Synchronous, Bidirectional Buck-Boost Controller with I2C, Battery Charging, and Adjustable OCP and PG Indication, AEC-Q100 Qualified
MPQ8872-AEC1PRODUCT36V, 2A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface, AEC-Q100 Qualified
MPQ4208-AEC1PRODUCT80V, Synchronous Buck-Boost Controller with I2C And Adjustable OCP and PG Indication, AEC-Q100 Qualified
MPQ8835A-AEC1PRODUCT36V, 6A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface, AEC-Q100 Qualified
MPQ8874-AEC1PRODUCT36V, 4A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface, AEC-Q100 Qualified
MPQ4232-AEC1PRODUCT6A Buck-Boost Converter with Four Integrated MOSFETs and I2C Interface, AEC-Q100 Qualified
MPQ4263-AEC1PRODUCT36V, 140W Buck-Boost with Integrated LS-FETs, Supports High-Side Current Sense and I2C Interface for Automotive, AEC-Q100 Qualified
MPQ4262-AEC1PRODUCT36V, 100W, Buck-Boost Converter with Integrated Low-Side MOSFETS and an I2C Interface for Automotive, AEC-Q100 Qualified
