MPQ4208-AEC1
80V, Synchronous Buck-Boost Controller with I2C And Adjustable OCP and PG Indication, AEC-Q100 Qualified
- Vin (min) (V)4.75
- Vin (max) (V)80
- Iout (max) (A)25
- Iq (typ) (mA)0.3
- Vfb (V)0.1 to 2.56
- fsw (max) (kHz)1000
- Control ModeCurrent Mode
- Package (mm)QFN-32 (5x6)
- GradeAutomotive
The MPQ4208-AEC1 integrates a synchronous, 4-switch N-channel MOSFET driver supporting GaN, as well as a buck-boost controller capable of regulating different output voltages with a wide input voltage (VIN) range and high efficiency.
The device provides an I2C interface with a one-time programmable (OTP) memory, which supports a configurable output voltage (VOUT), VOUT slew-rate control, and a configurable input and output constant-current (CC) limit. This makes the MPQ4208-AEC1 suitable for USB Power Delivery (PD) Standard Power Range (SPR) and Extended Power Range (EPR) designs, in addition to high-power systems.
The MPQ4208-AEC1 provides forced continuous conduction mode (FCCM) and automatic pulse-frequency modulation (PFM)/pulse-width modulation (PWM) selection mode. The configurable switching frequency (fSW) with frequency spread spectrum (FSS) supports flexible designs for different applications.
It also features configurable input and output over-current protection (OCP) with hiccup mode, continuous CC mode without hiccup mode, short-circuit protection (SCP), configurable input over-voltage protection (OVP) and under-voltage lockout (UVLO) thresholds, output OVP, and thermal shutdown (TSD). The NTC pin can be used to sense the PCB or MOSFET temperature for over-temperature protection.
The MPQ4208-AEC1 is available in a QFN-32 (5mmx6mm) package with wettable flanks, and is available in AEC-Q100 Grade 1.
- 4-Switch Buck-Boost Controller
- 4.75V to 80V Operating Input Voltage (VIN) Range
- Internal Feedback (FB) Supports 3.2V to 80V Output Voltage (VOUT) Range, 20mV/Step
- 1µA Enable (EN) Shutdown Quiescent Current (IQ)
- 300µA IQ when I2C Operation Is Off
- 0.5A to 25A Configurable Input/Output Continuous Current Limit, 50mA/Step
- Supports 2mΩ/5mΩ Configurable Current-Sense (CS) Resistor
- Supports USB Power Delivery (PD) Standard Power Range (SPR), Programmable Power Supply (PPS), and Extended Power Range (EPR) Adjustable Voltage Supply (AVS)
- Configurable 200kHz, 400kHz, 600kHz, or 1MHz Switching Frequency (fSW) with Frequency Spread Spectrum (FSS) and Frequency SYNC Input
- Selectable Pulse-Frequency Modulation (PFM) Mode or Forced Continuous Conduction Mode (FCCM)
- Supports 5V, 1.75A Source and 4.5A Sink Capability via GaN-Compliant Gate Driver
- Configurable VIN Under-Voltage Lockout (UVLO) Threshold via One-Time Programmable (OTP) Memory
- Configurable VOUT Over-Voltage Protection (OVP )
- System:
- I2C Interface with Interrupt Function
- Over-Current Protection (OCP), Short-Circuit Protection (SCP), OVP, Power Good (PG), Negative Temperature Coefficient (NTC), and Thermal Shutdown (TSD) Interrupt
- 10-Bit Analog-to-Digital Converter (ADC) Readout for VIN, Input Current (IIN), VOUT, Output Current (IOUT), and Temperature
- Available in a QFN-32 (5mmx6mm) Package with Wettable Flanks
MPQ4208GQJE-0000-AEC1-Z MPQ4208GQJE-0000-AEC1-P MPQ4208GQJE-0001-AEC1-Z MPQ4208GQJE-0001-AEC1-P MPQ4208GQJE-0002-AEC1-Z MPQ4208GQJE-0002-AEC1-P MPQ4208GQJE-xxxx-AEC1-Z MPQ4208GQJE-xxxx-AEC1-P
MPQ4208-AEC1 Resources
STEP-DOWN/STEP-UP CONVERTERSPRODUCT CATEGORY -
STEP-DOWN/STEP-UP (BUCK-BOOST) CONVERTERS AND CONTROLLERSPRODUCT CATEGORY -
USB TYPE-C POWER DELIVERYAPPLICATIONUSB Type-C power delivery (PD) is gaining popularity across applications and markets, including in automotive. USB ports have become an expected standard in most car models, and are typically expected to offer both charging and data functionality. USB Type-C improves on older USB designed by offering a smaller, reversible port for easy plug-in and double the transfer speed of USB 3.0. USB PD proto...
MPQ8878-AEC1PRODUCT36V, 10A, Four-Switch, Synchronous Buck-Boost Converter with ZDPTM, AEC-Q100 Qualified
MPQ8837-AEC1PRODUCT36V, 8A, 4-Switch, Synchronous Buck-Boost Converter with CC/CV Operation and I2C, AEC-Q100 Qualified
MPQ4232A-AEC1PRODUCT36V, 6A Buck-Boost Converter with Four Integrated MOSFETs and I2C Interface, AEC-Q100 Qualified
MPQ4201-AEC1PRODUCT100V, Synchronous, Bidirectional Buck-Boost Controller with I2C, Battery Charging, and Adjustable OCP and PG Indication, AEC-Q100 Qualified
MPQ8872-AEC1PRODUCT36V, 2A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface, AEC-Q100 Qualified
MPQ8835A-AEC1PRODUCT36V, 6A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface, AEC-Q100 Qualified
MPQ8874-AEC1PRODUCT36V, 4A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface, AEC-Q100 Qualified
MPQ4232-AEC1PRODUCT6A Buck-Boost Converter with Four Integrated MOSFETs and I2C Interface, AEC-Q100 Qualified
MPQ4483-AEC1PRODUCT3A, 36V Step-Down Converter with DCP Mode, CDP Mode, and Ground-to-Battery Short Protection for Automotive, AEC-Q100 Qualified
MPQ4263-AEC1PRODUCT36V, 140W Buck-Boost with Integrated LS-FETs, Supports High-Side Current Sense and I2C Interface for Automotive, AEC-Q100 Qualified
MPQ4262-AEC1PRODUCT36V, 100W, Buck-Boost Converter with Integrated Low-Side MOSFETS and an I2C Interface for Automotive, AEC-Q100 Qualified
