MPQ8878-AEC1
36V, 10A, Four-Switch, Synchronous Buck-Boost Converter with ZDPTM, AEC-Q100 Qualified
- 入力電圧(最小) (V)2.9
- 入力電圧 (最大) (V)36
- Iout (max) (A)10
- Iq (typ) (mA)0.05
- Vfb (V)0.6
- fsw(最大)(kHz)2200
- Control ModeZero-Delay PWM Control (ZDPTM)
- パッケージ(mm)TQFN-23 (4x5)
- グレードAutomotive
The MPQ8878-AEC1 is a 36V, monolithic, synchronous buck-boost DC/DC converter. The wide 2.9V to 36V input voltage (VIN) range makes this device well-suited for multi-purpose automotive and industrial applications. Proprietary Zero-Delay PWMTM (ZDPTM) control and the device's fully integrated, four-switch configuration allow the chip to flexibly change the converter topology between buck, boost, and buck-boost modes. This optimizes performance and efficiency with input votlages that are above, below, or equal to the output voltage (VOUT). It also ensures seamless transitions between the adjacent operational regions.
The MPQ8878-AEC1 can be configured via a standard I2C interface, and UART versions are also available. The parameters can be adjusted by writing settings to the device without any hardware changes required.
The switching frequency (fSW) can be configured to 200kHz, 400kHz, 470kHz, 2200kHz, or it can be synchronized between 250kHz and 2.2MHz via an external clock signal. In addition, the configurable frequency spread spectrum (FSS) function can dither the fSW periodically for improved EMI performance.
Robust fault protections include input under-voltage lockout (UVLO), input over-voltage protection (OVP), cycle-by-cycle peak current limiting, output OVP, output short-circuit protection (SCP), and thermal shutdown. The built-in power good (PG) function can indicate whether VOUT is regulated properly.
The MPQ8878-AEC1 is available in a thermally enhanced TQFN-23 (4mmx5mm) package, and is available in AEC-Q100 Grade 1.
- 2.9V to 36V Wide Input Voltage (VIN) Range
- Load Dump Up to 40V
- Cold Crank Down to 2.9V
- Single-Channel, Four-Switch, Synchronous Buck-Boost Configuration
- Proprietary Zero-Delay PWMTM (ZDPTM) Control for Seamless Transitions
- Up to 10A of Continuous Output Current (IOUT) in Buck Mode
- 1μA Shutdown Current
- 50μA Quiescent Current (IQ)
- Easy-to-Optimize Efficiency and EMI Performance:
- Configurable 200kHz, 400kHz, 470kHz, or 2200kHz Switching Frequency (fSW)
- Synchronizable fSW
- Switching Frequency Spread Spectrum (FSS)
- Reduces Board Size and BOM:
- Integrated Compensation Network
- Fixed Output Voltage (VOUT) Options
- Rich Protections and Diagnostics:
- Configurable Input Under-Voltage Lockout (UVLO)
- Cycle-by-Cycle Current Limiting
- Input Over-Voltage Protection (OVP)
- Output Under-Voltage Protection (UVP)
- Over-Temperature Shutdown
- Power Good (PG) Indication
- Application Flexibility with I2C/UART Interface:
- 1Mb/s I2C Interface with Packet Error Checking (PEC)
- Configurable Parameters:
- Converter On/Off
- 1V to 24V VOUT Range
- fSW
- Switching Slew Rate
- FSS Setting
- Compensation Network
- Soft-Start Time (tSS)
- Dynamic VOUT Adjustment with Slew Rate Control
- Converter Mode Transition Threshold
- Asynchronous Advanced Modluation (AAM) Mode or Forced Continuous Conduction Mode (FCCM)
- Protection Threshold
- Fault Behaviors
- Power Good (PG) Threshold
- Additional Features:
- One-Time Programmable (OTP) for Default Parameter Settings
- Available in a Mesh-ConnectTM Flip-Chip TQFN-23 (4mmx5mm) Package
- Available in Thermal-Enhanced THQFN to Facilitate Top-Side Cooling
- Available with Wettable Flanks
MPQ8878GVTE-xxxx-AEC1-Z MPQ8878GVTE-xxxx-AEC1-P MPQ8878GVTE-0000-AEC1-Z MPQ8878GVTE-0000-AEC1-P MPQ8878GVTHE-xxxx-AEC1-Z MPQ8878GVTHE-xxxx-AEC1-P MPQ8878GVTHE-0000-AEC1-Z MPQ8878GVTHE-0000-AEC1-P
MPQ8878-AEC1 Resources
ステップダウン / ステップアップコンバータおよびコントローラ製品カテゴリ -
USB TYPE-C POWER DELIVERYアプリケーションUSB Type-C Power Deliveryは、自動車を含むアプリケーションや市場で人気を集めています。USBポートはほとんどの車種で期待される標準になり、通常、充電機能とデータ機能の両方を提供することが期待されています。USB Type-Cはプラグインを容易にし、USB 3.0の転送速度を2倍にするために、より小さくリバーシブルなポートを提供することで設計された従来のUSBを改善します。USB PDプロトコルにより、USB Type-Cは最大100Wの電力を供給できるため、新製品への急速な採用につながります。ただし、車載用USB Type-Cの設計は、EMCや熱規制などの厳格な自動車安全基準を満たす必要があります。ドライバーと乗員の快適性と利便性を確保するための各新機能により、設計が複雑になり、スペースがさらに貴重となっています。 車載グレード製品のトップクラスのポートフォリ...
MPQ8837-AEC1製品36V, 8A, 4-Switch, Synchronous Buck-Boost Converter with CC/CV Operation and I2C, AEC-Q100 Qualified
MPQ4232A-AEC1製品4個のMOSFETとI2Cインタフェースを内蔵、36V、6Aの昇降圧型コンバータ、AEC-Q100認定済み
MPQ4201-AEC1製品I2C、バッテリー充電、調整可能なOCPおよびPG表示付き、100V、同期整流双方向昇降圧型コントローラ、AEC-Q100認定済み
MPQ8872-AEC1製品I2Cインタフェース付き、36V、2A、4スイッチ、同期整流昇降圧型コンバータ、AEC-Q100認定済み
MPQ4208-AEC1製品I2Cと調整可能なOCPおよびPG表示付き、80V、同期整流昇降圧型コントローラ、AEC-Q100認定済み
MPQ8835A-AEC1製品I2Cインタフェース付き、36V、6A、4スイッチ、同期整流昇降圧型コンバータ、AEC-Q100認定
MPQ8874-AEC1製品I2Cインタフェース付き、36V、4A、4スイッチ、同期整流昇降圧型コンバータ、AEC-Q100認定済み
MPQ4232-AEC1製品4つのMOSFETとI2Cインタフェースを内蔵した6A昇降圧コンバータ、AEC-Q100認定
MPQ4263-AEC1製品ローサイドFET内蔵、車載用ハイサイド電流検知とI2Cインタフェースに対応、36V、140W、昇降圧型コンバータ、AEC-Q100認定
MPQ4262-AEC1製品車載用 36V、100W、ローサイドMOSFETとI2Cインタフェースを統合した昇降圧コンバータ、AEC-Q100認定
