MPQ4236-AEC1
36V, 8A, Switching Current Buck-Boost Converter with Four Integrated MOSFETs and I2C-Adjustable OCP, AEC-Q100 Qualified
- 入力電圧(最小) (V)4
- 入力電圧 (最大) (V)36
- Iout (max) (A)5
- Iq (typ) (mA)0.28
- Vfb (V)0 to 2.0475
- fsw(最大)(kHz)2100
- Control ModeCurrent Mode
- パッケージ(mm)QFN-18 (3x4)
- グレードAutomotive
- Isw Limit (typ) (A)10
- Max Duty Cycle (%)80
- Regulated Outputs1
- Vout (max) (V)26
- Vout (min) (V)1
The MPQ4236-AEC1 is a buck-boost converter with four power MOSFETs. The device can deliver up to 60W of output power at certain input supply ranges with excellent efficiency.
The MPQ4236-AEC1 is suitable for battery pre-regulators, USB power delivery (PD), and wireless charging applications. It can work well with external PD or wireless charging controllers via the I2C interface.
The I2C interface and one-time programmable (OTP) memory provide flexibility for configurable parameters.
The adjustable switching frequency (fSW) (up to 2MHz) during continuous conduction mode (CCM) greatly reduces the external inductance and capacitance. Fault condition protections include constant-current (CC) limiting, output and input over-voltage protection (OVP), and thermal shutdown (TSD).
The MPQ4236-AEC1 requires a minimal number of readily available, standard external components. It is available in a small QFN-18 (3mmx4mm) package with wettable flanks, and is available in AEC-Q100 Grade 1.
- 350μA Low Quiescent Current (IQ)
- 8A Average Inductor Current (IL)
- 4V to 36V Operating Input Voltage (VIN) Range
- 1V to 26V Output Voltage (VOUT) Range
- 0V to 2.047V I2C-Configurable Reference Voltage (VREF) Range with 0.5mV Resolution
- SWA/SWB/SWC/SWD On Resistance (RDS(ON)): 15mΩ/21mΩ/14mΩ/13mΩ
- Integrated 5V/60mA Low-Dropout (LDO) Regulator to Supply External Microcontroller Unit (MCU)
- Selectable Input or Output Constant-Current (CC) Limit with 5% Accuracy via Factory Trimming
- Input Over-Voltage Protection (OVP) Function
- Selectable Switching Frequency (fSW) with Frequency Spread Spectrum (FSS): 280kHz, 420kHz, 600kHz,
- 1.2MHz, or 2MHz
- External Clock Synchronization
- Selectable Automatic Pulse-Frequency Modulation (PFM) or Pulse-Width Modulation (PWM) Mode and Forced PWM Mode
- Configurable I2C Target Address Supported by the ADDR Pin and I2C Register
- Line Drop Compensation
- Power Good (PG) Indication
- I2C, Alert, and One-Time Programmable (OTP) Memory
- Enable (EN) Shutdown Passive Discharge
- Available in a QFN-18 (3mmx4mm) Package
MPQ4236GLE-xxxx-AEC1-Z MPQ4236GLE-xxxx-AEC1-P MPQ4236GLE-0000-AEC1-Z MPQ4236GLE-0000-AEC1-P
MPQ4236-AEC1 Resources
ステップダウン / ステップアップコンバータ製品カテゴリ -
USB PD用パワーステージ製品カテゴリ -
ステップダウン / ステップアップコンバータおよびコントローラ製品カテゴリ -
トラクション・インバータアプリケーション電気自動車 (EV) の普及が指数関数的に増加し続けているため、エンジンの轟音は過去のものになりつつあります。間もなく、トラクション・インバータがバッテリから電力を供給するため、EVのモータ音だけが聞こえるようになります。トラクション・インバータは、高電圧バッテリ (400V / 800V) からのエネルギーを3相ACエネルギーに変換して車両のモータを駆動するのに役立ちます。トラクション・インバータは通常、適切な動作を確保するための高度な保護機能を備えた6つのシングルチャネル絶縁型ゲートドライバで構成されています。これらのシステムは、20kW〜400kWのアプリケーション向けに設計されており、プラグインハイブリッド車と完全な電気自動車の両方のモータに瞬時にトルクを供給することができます。 MPSの絶縁型ソリューションの多くの製品一覧には、絶縁型ゲートドライバ、絶縁型ゲートドライバ...
オンボードチャージャモジュール (OBCM)アプリケーション電気自動車 (EV) は日々存在感を増しており、EVの選択は指数関数的な速度で増加しています。オンボード充電 (OBC) は、ACチャージャが車両に接続されている間に可能な最大充電率を決定するため、EVの非常に重要な部分です。完全電気自動車の最大充電能力は通常6.6kW~22kWで、プラグインハイブリッド車の場合は通常3.3kW~7.2kWです。 MPSの車載グレードの絶縁型ソリューションの多数の製品一覧には、絶縁型ゲートドライバ、絶縁型ゲートドライバ電源、デジタルアイソレータ、ホール効果電流センサ、および非絶縁型DC/DCコンバータが含まれます。MPSのソリューションは、高いCMTIと磁気ノイズ耐性のために容量性絶縁を採用することにより、最も厳しい大電力仕様を満たすように設計されています。 MPSの強固な絶縁ソリューションは、次世代のオンボードチャージャに電力を供給す...
DC急速充電ステーションアプリケーション電気自動車の導入の増加に伴い、DC急速充電ステーションがより一般的になってきています。充電ステーションは、主要幹線道路や人口の多い郊外にあるインフラストラクチャの重要な部分であり、電気自動車が長距離移動中や日常の運転中に充電できる場所を確保します。これらのシステムは多くの場合、複数の25kW~75kWモジュールで構成され、150kW~400kWの電力を供給する急速充電システムを構築し、電気自動車のバッテリーを10%~90%まで20分という速さで充電できます。 MPSの絶縁型ソリューションの多数の製品一覧には、絶縁型ゲートドライバ、絶縁型ゲートドライバ電源、デジタルアイソレータ、ホール効果電流センサ、および非絶縁型DC/DCコンバータが含まれます。これらの部品は、SiCとIGBTの両方のバイアスおよび駆動に使用できるだけでなく、トランスをチップスケールのパッケージに統合することで高...
ヘッドライトアプリケーションヘッドライトは、どんな車両においても最も重要な機能安全の1つです。新しい機能ではありませんが、現在、ほとんどの新しい自動車モデルにはLEDヘッドライトが搭載されており、明るさが増し、効率が向上し、ヘッドライトの寿命が長くなりました。そしてもちろん、あらゆる車載アプリケーションと同様に、ヘッドライトの設計は、厳格な熱要件、ISO26262安全規格、およびEMI規制を満たす必要があります。 そのため、MPSではAEC-Q100認定製品の広範な製品ラインアップを提供しています。MPSの非常に効率的で柔軟なライティングソリューションには、ステップアップコンバータ、降圧、昇圧、および昇降圧LEDドライバが含まれます。これらの車載グレードの製品は、最高レベルの安全性と性能を提供すると同時に、市場投入までの時間を短縮します。 MPSの信頼性とコスト効率の高い製品は、次世代の車載用ヘッ...
USB TYPE-C POWER DELIVERYアプリケーションUSB Type-C Power Deliveryは、自動車を含むアプリケーションや市場で人気を集めています。USBポートはほとんどの車種で期待される標準になり、通常、充電機能とデータ機能の両方を提供することが期待されています。USB Type-Cはプラグインを容易にし、USB 3.0の転送速度を2倍にするために、より小さくリバーシブルなポートを提供することで設計された従来のUSBを改善します。USB PDプロトコルにより、USB Type-Cは最大100Wの電力を供給できるため、新製品への急速な採用につながります。ただし、車載用USB Type-Cの設計は、EMCや熱規制などの厳格な自動車安全基準を満たす必要があります。ドライバーと乗員の快適性と利便性を確保するための各新機能により、設計が複雑になり、スペースがさらに貴重となっています。 車載グレード製品のトップクラスのポートフォリ...
MPQ8878-AEC1製品36V, 10A, Four-Switch, Synchronous Buck-Boost Converter with ZDPTM, AEC-Q100 Qualified
MPQ8837-AEC1製品36V, 8A, 4-Switch, Synchronous Buck-Boost Converter with CC/CV Operation and I2C, AEC-Q100 Qualified
MPQ4232A-AEC1製品4個のMOSFETとI2Cインタフェースを内蔵、36V、6Aの昇降圧型コンバータ、AEC-Q100認定済み
MPQ8887-AEC1製品I2Cインタフェース付き、周波数設定可能、調整可能なOCP、65V、9A、高効率降圧型コンバータ、AEC-Q100認定済み
MPQ4201-AEC1製品I2C、バッテリー充電、調整可能なOCPおよびPG表示付き、100V、同期整流双方向昇降圧型コントローラ、AEC-Q100認定済み
