MPQ29260-AEC1
- Control MethodAnalog
- System InterfaceI2C
- Memory TypeMTP
- Number of Rails1
- Number of Phases3
- VCC (typ) (V)3.3
- Iq (typ) (mA)3.3
- fsw (max) (kHz)1000
- Wettable Flank QFN OptionYes
- Package (mm)TQFN-24 (4x4)
The MPQ29260-AEC1 is a multi-phase controller for 48V systems in automotive applications. It can work with MPS's Intelli-PhaseTM products to complete the multi-phase voltage regulator (VR) solution with minimal external components.
The MPQ29260-AEC1 adopts constant-on-time (COT) mode to provide fast transient response and ease loop stabilization.
The operating frequency can be configured between 100kHz and 500kHz via an external resistor and remains constant as the input voltage (VIN) changes.
The MPQ29260-AEC1 is available in a TQFN-24 (4mmx4mm) package, and is available in AEC-Q100 Grade 1.
- 60V Multi-Phase Controller
- 1V to 5V Adjustable Output Voltage Range (VOUT)
- Simple Loop Compensation
- Bias Supply Pin
- Internal Low-Dropout (LDO)
- Phase-to-Phase Active Current Balancing
- Adjustable Switching Frequency (fSW)
- Ability to Sync to External Clock
- Spread Spectrum for Low-EMI Requirements
- Input Voltage (VIN) and VOUT Monitoring
- Output Current (IOUT) Monitoring
- Protections Include Under-Voltage Lockout (UVLO), Over-Voltage Protection (OVP), Under-Voltage Protection (UVP), Over-Current Protection (OCP), and Over-Temperature Protection (OTP)
- Available in a RoHS Compliant TQFN-24 (4mmx4mm) Package
MPQ29260GRTE-AEC1-Z MPQ29260GRTE-AEC1-P
MPQ29260-AEC1 Resources
SOC CORE POWER - DIGITAL MULTI-PHASE CONTROLLERSPRODUCT CATEGORY -
MPQ72963FS-AEC1PRODUCTMPSafeTM, ASIL-D, 3-Rail, 9-Phase Controller with Digital Interface, AEC-Q100 Qualified
MPQ29252-AEC1PRODUCTDigital Multi-Phase Controller, AEC-Q100 Qualified
USE CASE
MPQ72957FS-AEC1PRODUCTASIL-D, 4-Rail, 8-Phase Controller with I2C Interface, AEC-Q100 Qualified
MPQ29164-AEC1PRODUCTDigital, 6-Phase Controller with I2C Interface for IMVP8/9/9.1, AEC-Q100 Qualified
MPQ29125-AEC1PRODUCT3-Rail, Multi-Phase Controller, AEC-Q100 Qualified
USE CASE
INTELLI-PHASETM SOLUTION USE CASE: CENTRAL COMPUTERSUSE CASEThis use case examines the application of the MPQ2946 and MPQ86760 in central computers for autonomous vehicles. The MPQ2946 and MPQ86760 provide two cutting-edge power conversion solutions for central computers in autonomous vehicles with features including high power density, versatility, and integrated design. Central computers within autonomous vehicles power an intensive workload, inc...
MPQ2946PRODUCTDigital, 8-Phase Controller with Three Rails, AEC-Q100 Qualified
CHALLENGES AND OPPORTUNITIES WHEN POWERING AUTOMOTIVE SOC CORE RAILSARTICLEThe automotive industry is undergoing a major transformation to support electric vehicles (EVs), autonomous driving, high-end infotainment systems, vehicle connectivity, and software-defined vehicles. The goals and benefits of EV transformation, and its impact on the automotive supply chain, are well understood by now. However, the digital transformation towards autonomous driving and high-perfor...
USE CASE
AUTONOMOUS DRIVING USE CASEUSE CASEBetween 2004 and 2007, autonomous driving was launched in the United States with three unmanned driving challenges. As autonomous driving now enters the era of industrialization, it is important to address common challenges and boost performance across complex systems. This use case examines the application of the MPQ2967-AEC1, MPQ86960, MPQ79500FS-AEC1, and MPQ79700FS-AEC1 in autonomous driving. ...
MPQ2977-AEC1PRODUCTDigital 6-Phase Controller with Serial Interface, AEC-Q100 Qualified
MPQ2967-AEC1PRODUCTDual-Rail, Digital, 4-Phase Controller with PMBus Interface, AEC-Q100 Qualified
MPQ79731FS-AEC1PRODUCTMPSafeTM, ASIL-B, 6-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79571FS-AEC1PRODUCTMPSafeTM, ASIL-D, Wide 36V VIN, Window Voltage Supervisor, AEC-Q100 Qualified
MPQ1966-AEC1PRODUCT100V, 4A, High-Frequency, Half-Bridge, N-Channel Power Gate Driver
MPQ86761-AEC1PRODUCT60A Intelli-PhaseTM Solution in a TQFN-21 (3.5mmx6mm) Package, AEC-Q100 Qualified
MPQ86725-AEC1PRODUCTIntelli-PhaseTM Solution in TQFN (3.5mmx4mm) Package, AEC-Q100 Qualified
MPQ86720-AEC1PRODUCT65V Intelli-PhaseTM Solution in a TQFN-22 (5mmx6mm) Package, AEC-Q100 Qualified
MPQ79531FS-AEC1PRODUCTMPSafeTM, ASIL-B, 3-Channel Voltage Monitor, AEC-Q100 Qualified
