MPQ29164-AEC1
- Control MethodDigital Control
- System InterfaceI2C
- Memory TypeMTP
- Number of Rails2
- Number of Phases6
- VCC (typ) (V)3.3
- Iq (typ) (mA)8
- fsw (max) (kHz)2000
- Wettable Flank QFN OptionYes
- Package (mm)TQFN-48 (6x6)
The MPQ29164-AEC1 is a dual-rail, multi-phase digital voltage regulator (VR) controller, and it is compliant with IMVP8/IMVP9/IMVP9.1 for Intel microprocessors.
The MPQ29164-AEC1 can work with MPS’s Intelli-PhaseTM products to complete the multi-phase VR solution with minimal external components. The device can be configured for single-rail operation, and can operate in low quiescent current (IQ) mode. Rail A is configurable up to 4 phases, while rail B is configurable up to 2 phases.
The on-chip, multiple-time programmable (MTP) memory stores and restores device configurations. Device configurations and fault parameters can be configured or monitored using the I2C interface. The MPQ29164-AEC1 can monitor and report the output current (IOUT) through the Intelli-PhaseTM current-sense (CS) output.
The MPQ29164-AEC1 is based on unique, digital, multi-phase nonlinear control to provide fast transient response with minimal output capacitors. With only one power loop control method for both the steady state and load transient, power loop compensation is simple to configure.
The MPQ29164-AEC1 is available in a TQFN-48 (6mmx6mm) package, and is available in AEC-Q100 Grade 1.
- Configurable Phase Numbers
- Two Rails with Up to 6-Phase Operation:
- Up to 4 Phases on Rail A
- Up to 2 Phases on Rail B
- Intel IMVP8, IMVP9, and IMVP9.1 Compliant
- I2C Compliant
- Serial VID Interface for Configuring and Monitoring
- Built-In Multiple-Time Programmable (MTP) Memory to Store Customer Configurations
- Automatic Loop Compensation
- Automatic Phase-Shedding (APS) to Improve Overall Efficiency
- Phase-to-Phase Active Current Balancing
- Input Voltage (VIN), Output Voltage (VOUT), Power, and Output Current (IOUT) Monitoring
- Low Quiescent Current (IQ) Function
- Regulator Temperature Monitoring
- Under-Voltage Lockout (UVLO), Over-Voltage Protection (OVP), Under-Voltage Protection (UVP), Over-Current Protection (OCP), Over-Temperature Protection (OTP), and Reverse-Voltage Protection (RVP) with No Action, Latch-Off, Auto-Retry, and Hiccup Options
- Digital, Configurable Load Line
- Supports Fast-V Mode (FVM)
- Available in a TQFN-48 (6mmx6mm) Package
MPQ29164GQKTE-xxxx-AEC1-Z MPQ29164GQKTE-xxxx-AEC1-P
MPQ29164-AEC1 Resources
SOC CORE POWER - DIGITAL MULTI-PHASE CONTROLLERSPRODUCT CATEGORY -
MPQ72963FS-AEC1PRODUCTMPSafeTM, ASIL-D, 3-Rail, 9-Phase Controller with Digital Interface, AEC-Q100 Qualified
MPQ29252-AEC1PRODUCTDigital Multi-Phase Controller, AEC-Q100 Qualified
MPQ29260-AEC1PRODUCT60V, Multi-Phase Step-Down Controller, AEC-Q100 Qualified
USE CASE
MPQ72957FS-AEC1PRODUCTASIL-D, 4-Rail, 8-Phase Controller with I2C Interface, AEC-Q100 Qualified
MPQ29125-AEC1PRODUCT3-Rail, Multi-Phase Controller, AEC-Q100 Qualified
USE CASE
INTELLI-PHASETM SOLUTION USE CASE: CENTRAL COMPUTERSUSE CASEThis use case examines the application of the MPQ2946 and MPQ86760 in central computers for autonomous vehicles. The MPQ2946 and MPQ86760 provide two cutting-edge power conversion solutions for central computers in autonomous vehicles with features including high power density, versatility, and integrated design. Central computers within autonomous vehicles power an intensive workload, inc...
MPQ2946PRODUCTDigital, 8-Phase Controller with Three Rails, AEC-Q100 Qualified
CHALLENGES AND OPPORTUNITIES WHEN POWERING AUTOMOTIVE SOC CORE RAILSARTICLEThe automotive industry is undergoing a major transformation to support electric vehicles (EVs), autonomous driving, high-end infotainment systems, vehicle connectivity, and software-defined vehicles. The goals and benefits of EV transformation, and its impact on the automotive supply chain, are well understood by now. However, the digital transformation towards autonomous driving and high-perfor...
USE CASE
AUTONOMOUS DRIVING USE CASEUSE CASEBetween 2004 and 2007, autonomous driving was launched in the United States with three unmanned driving challenges. As autonomous driving now enters the era of industrialization, it is important to address common challenges and boost performance across complex systems. This use case examines the application of the MPQ2967-AEC1, MPQ86960, MPQ79500FS-AEC1, and MPQ79700FS-AEC1 in autonomous driving. ...
MPQ2977-AEC1PRODUCTDigital 6-Phase Controller with Serial Interface, AEC-Q100 Qualified
MPQ2967-AEC1PRODUCTDual-Rail, Digital, 4-Phase Controller with PMBus Interface, AEC-Q100 Qualified
MPQ79520FS-AEC1PRODUCTMPSafeTM, ASIL-D, 5-Channel Voltage Monitor, AEC-Q100 Qualified
MPQ79505FS-AEC1PRODUCTMPSafeTM, ASIL-D, 6-Channel Voltage Monitor with Integrated Watchdog Timer, AEC-Q100 Qualified
MPQ79731FS-AEC1PRODUCTMPSafeTM, ASIL-B, 6-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79571FS-AEC1PRODUCTMPSafeTM, ASIL-D, Wide 36V VIN, Window Voltage Supervisor, AEC-Q100 Qualified
MPQ1966-AEC1PRODUCT100V, 4A, High-Frequency, Half-Bridge, N-Channel Power Gate Driver
MPQ86761-AEC1PRODUCT60A Intelli-PhaseTM Solution in a TQFN-21 (3.5mmx6mm) Package, AEC-Q100 Qualified
MPQ86725-AEC1PRODUCTIntelli-PhaseTM Solution in TQFN (3.5mmx4mm) Package, AEC-Q100 Qualified
