- 車載用IC (AECQ グレード)
- システム監視
- 電圧スーパーバイザまたはモニタ (リセットIC)
- MPQ79520FS-AEC1
MPQ79520FS-AEC1
- チャンネル数5
- 入力電圧(最小) (V)2.7
- 入力電圧 (最大) (V)5.5
- Reset Threshold (V)Adj
- Threshold Accuracy (%)±0.5
- Iq (typ) (µA)600
- Reset Time DelayAdjustable
- パッケージ(mm)QFN-16 (3x3)
The MPQ79520FS-AEC1 is a 5-channel voltage monitor. It is engineered for automotive applications that require voltage rails to be monitored for safety, such as advanced driver-assistance systems (ADAS) and autonomous driving platforms.
Each voltage monitor input has configurable over-voltage (OV) and under-voltage (UV) thresholds. Highly accurate high-frequency (HF) and low-frequency (LF) voltage monitoring can detect when the voltage thresholds are reached. One of the inputs is a differential voltage-sensing input pair that is well-suited to monitor voltage rails with high current levels.
The MPQ79520FS-AEC1 can record the order in which voltage rails are sequenced, as well as their associated timestamps. The device also provides a sync input/output (I/O) function, which allows multiple devices to be connected together to increase the number of voltage rails that can perform these functions. The device is accessible through an I2C interface.
With the integration of sophisticated functional safety features, including built-in self-test (BIST), diagnostics, and write protection, this device is targeted to support applications with a high automotive safety integrity level up to ASIL-D.
The MPQ79520FS-AEC1 is available in a QFN-16 (3mmx3mm) package with wettable flanks, and is available in AEC-Q100 Grade 1.
- Precision Monitoring and Recording:
- 5 Voltage Monitor Inputs: 4 Single-Ended, 1 Differential
- Absolute Over-Voltage (OV)/Under-Voltage (UV) Thresholds for High-Frequency and Low-Frequency Components:
- 0.2V to 1.475V, 5mV/Step
- 0.8V to 5.5V, 20mV/Step
- High DC Accuracy across the Entire Temperature Range:
- >1V, ±1%
- <1V, ±10mV
- Analog-to-Digital Converter (ADC) for Voltage-Level Readback
- Power Sequence Recording for Power-On, Power-Off, and Sleep Entry/Exit
- Sync Input/Output (I/O) for Multi-Device Sequence Synchronization
- Functional Safety:
- Built-In Self-Test (BIST)
- Interrupt Output Pin (Fault Reporting)
- Cyclic Redundancy Check (CRC) Protection on Registers
- Write Protection for Critical Registers
- ISO 26262 Functional Safety Compliant
- Configurability for Vast Flexibility:
- I2C Interface with Packet Error Checking (PEC)
- Additional Features:
- Available in a QFN-16 (3mmx3mm) Package with 0.5mm Pitch and Wettable Flanks
MPQ79520FSGQE-xxxx-AEC1-Z MPQ79520FSGQE-xxxx-AEC1-P MPQ79520FSGQE-0000-AEC1-Z MPQ79520FSGQE-0000-AEC1-P
MPQ79520FS-AEC1 Resources
電圧スーパーバイザまたはモニタ (リセットIC)製品カテゴリ -
MPQ79505FS-AEC1製品MPSafeTM, ASIL-D, 6-Channel Voltage Monitor with Integrated Watchdog Timer, AEC-Q100 Qualified
MPQ79530FS-AEC1製品MPSafeTM, ASIL-D, 3-Channel Voltage Monitor, AEC-Q100 Qualified
MPQ7944-AEC1製品1-Channel Voltage Monitor, AEC-Q100 Qualified
MPQ79575FS-AEC1製品MPSafeTM ASIL-D, Point-of-Load (≤6.5V) Window Voltage Supervisor, AEC-Q100 Qualified
MPQ79521FS-AEC1製品MPSafeTM, ASIL-B, 5-Channel Voltage Monitor, AEC-Q100 Qualified
MPQ79570FS-AEC1製品MPSafeTM, ASIL-D, Wide 70V VIN, Window Voltage Supervisor, AEC-Q100 Qualified
MPQ79500FS-AEC1製品MPSafe™ 6チャネルASIL - D電圧モニタ、AEC-Q100認定
MPQ6400-AEC1製品低静止電流プログラマブル遅延監視回路 AEC-Q100認定
