- モータ・ドライバ / モータ・コントローラ
- ファンドライバ
- MPQ6653C-AEC1
MPQ6653C-AEC1
- 入力電圧(最小) (V)3.5
- 入力電圧 (最大) (V)35
- Number of Phase1
- Iout (max) (A)1.2
- Integrated Hall SensorYes
- Integrated Power MOSFETsYes
- Speed Close LoopYes
- グレードAutomotive
- パッケージ(mm)TQFN-6 (2x3), TSOT23-6, TSOT23-6-SL
- Integrated Current Sense AmplifiersNo
- InputsPWM or DC
The MPQ6653C-AEC1 is a single-phase brushless DC (BLDC) motor driver with integrated power MOSFETs and an embedded Hall sensor. It drives a single-phase BLDC motor, with up to 1.2A of peak coil current. The input voltage (VCC) range is between 3.5V and 35V.
The MPQ6653C-AEC1 controls the motor speed through the pulse-width modulation (PWM) signal or the DC voltage on the PWM pin. The device features configurable soft commutation, a Hall offset angle, and speed curve configurations.
The FG/RD pin acts as either a rotating speed indicator (FG) based on the embedded Hall sensor’s output, or a locked-rotor indicator (RD) if locked-rotor protection is triggered.
Rich protections include input over-voltage protection (OVP), under-voltage lockout (UVLO), locked-rotor protection, over-current limiting (OCL), and thermal shutdown protection.
The MPQ6653C-AEC1 is available in TSOT23-6-SL, TSOT23-6, and wettable-flank TQFN-6 (2mmx3mm) packages. It is available in AEC-Q100 Grade 1.
- 3.5V to 35V Operating Input Voltage (VCC) Range
- On-Chip Hall Sensor
- Integrated High-Side and Low-Side MOSFETs (HS-FET and LS-FET, Respectively): 960mΩ
- Selectable Open-Loop or Closed-Loop Speed Control
- Configurable Curves
- Configurable Starting Duty Cycle
- Configurable Stopping Duty Cycle
- Soft Commutation
- Configurable Soft Acceleration Time
- Configurable Hall Leading/Lag Angle
- Supports 50Hz to 100kHz Pulse-Width Modulation (PWM) Input Frequency or DC Input
- Automatic Reverse Current Block
- 24kHz PWM Output Frequency
- Configurable Current Limit
- Over Current Protection (OCP)
- Standby Mode
- Selectable FG or RD Output
- Available in TSOT23-6-SL, TSOT23-6, and TQFN-6 (2mmx3mm) Wettable-Flank Packages
MPQ6653CGJS-xxxx-AEC1-Z MPQ6653CGJS-xxxx-AEC1-P MPQ6653CGJS-0000-AEC1-Z MPQ6653CGJS-0000-AEC1-P MPQ6653CGJ-xxxx-AEC1-Z MPQ6653CGJ-xxxx-AEC1-P MPQ6653CGJ-0000-AEC1-Z MPQ6653CGJ-0000-AEC1-P MPQ6653CGDTE-xxxx-AEC1-Z MPQ6653CGDTE-xxxx-AEC1-P MPQ6653CGDTE-0000-AEC1-Z MPQ6653CGDTE-0000-AEC1-P
MPQ6653C-AEC1 Resources
シートコンフォート制御アプリケーションシートコンフォート制御テクノロジーにより、ユーザーは車の座席の快適さの設定を正確に調整およびカスタマイズできるため、最適な運転体験が保証されます。ランバーサポート、シートヒーター、換気のいずれを調整する場合でも、シートコンフォート制御システムはシームレスで応答性の高いエクスペリエンスを提供し、車内全体の快適性を向上させます。 MPSの包括的なソリューションには、モータ・ドライバ、電流センサ、位置センサ、LDO、ウォッチドッグタイマー、監視回路が含まれます。これらの製品は、基本的な座席調整から洗練された快適機能に至るまで、あらゆる機能を強化し、すぐれた運転体験に貢献し、シートコンフォート制御のあらゆる面で効率、信頼性、精度を提供します。 MPSのソリューションポートフォリオは、次世代のシートコンフォート制御システムを駆動するために必要なすべてを提供します。
アダプティブヘッドライトアプリケーションアダプティブヘッドライトシステムは、自動車の安全性と利便性の大きな進歩を示しています。これらのシステムは、さまざまな運転状況に応じて車両のヘッドライトの方向と強度をインテリジェントに調整し、視認性を高め、運転手と対向車の両方のまぶしさを軽減します。アダプティブヘッドライトは、運転手が障害物や歩行者をより迅速かつ正確に検出するのに役立つため、夜間の運転に特に役立ちます。 MPSの革新的なソリューション一式には、モータ・ドライバ、LEDドライバ、スマートダイオードコントローラ、低ドロップアウト (LDO) レギュレータ、ウォッチドッグタイマー、監視回路など、アダプティブヘッドライト アプリケーション向けにカスタマイズされた幅広い半導体部品が含まれています。これらの部品は、優れた効率性、信頼性、コンパクトなフォームファクタを提供するように細心の注意を払って設計されています。 MP...
機能集積型BLDCモータ・ドライバ製品カテゴリ -
ファンドライバ製品カテゴリ -
MP6616D製品18V、6Aピーク、MOSFETとホールセンサ内蔵、シングルフェーズBLDCモータ・ドライバ
MP6630E製品16V, 3-Phase BLDC Motor Driver with Integrated Hall Sensor
MP6658製品32V, 2.7A Peak, 1-Phase BLDC Motor Driver with Integrated MOSFETs and Hall Sensor
MP6652B製品18V, Single-Phase BLDC Motor Driver with Integrated Hall Sensor
MPQ6632-AEC1製品50V, 3-Phase BLDC Motor Driver with 1A Gate Driver, AEC-Q100 Qualified
MPQ6653B-AEC1製品35V/1.2A, Single-Phase BLDC Motor Driver with Integrated Hall Sensor and MOSFETs, AEC-Q100 Qualified
MP6617A製品18V, 6A Peak, 1-Phase BLDC Motor Driver with Integrated MOSFETS and Hall Sensor
MP6617製品18V, 6A Peak, 1-Phase BLDC Motor Driver with Integrated MOSFETS and Hall Sensor
MP6653B製品35V/1.2A, Single-Phase BLDC Motor Driver with Integrated Hall Sensor and MOSFETs
MP6638製品16V, 1.7A Peak, 3-Phase, Sensorless BLDC Motor Driver with Integrated MOSFETs
MP6635製品35V, 3-Phase, Sensorless BLDC Motor Driver with Configurable Gate Driver, Non AEC-Q100 Version
MP6642製品35V, 5A Peak, Three-Phase, Sensorless BLDC Motor Driver
MPQ6635-AEC1製品35V, 3-Phase, Sensorless BLDC Motor Driver with Configurable Gate Driver
MPQ6547A-AEC1製品4V to 32V, 4A Peak Current, Three-Phase Power Stage, AEC-Q100 Qualified
MP6634製品35V、2Aピーク、3相、センサレスBLDCモータ・ドライバ
MP6636製品MOSFET内蔵、18V、4Aピーク、3フェーズ、センサレスBLDCモータ・ドライバ
MP6631H製品35V入力、3Aピーク相電流、3相BLDCモータ・ドライバ
MP6616B製品クローズドループ / オープンループ速度制御と強化ESD機能付き、18V、2A のシングルフェーズBLDCモータドライバIC
MP6655製品18V、2.5Aピーク、MOSFETとホールセンサを内蔵したシングルフェーズBLDCファンドライバ
MP6637製品5.5V、1.3Aピーク、三相、センサレスBLDCモータドライバ、MOSFET内蔵
MP6653A製品TSOT23-6-SL、および、TSOT23-6パッケージにホールセンサとMOSFETを内蔵した35V、1.2A、単相BLDCモータドライバ
注文
