- 車載用IC (AECQ グレード)
- パワースイッチ
- スマート・ハイサイドスイッチ
- MPQ58200-AEC1
MPQ58200-AEC1
- 入力電圧(最小) (V)3
- 入力電圧 (最大) (V)3.6
- Ilimit (A)2
- Iq (mA)0.38
- Channels32
- EnableYes
- グレードAutomotive
- パッケージ(mm)WLCSP-45 (2.5x4.5)
The MPQ58200-AEC1 is a 32-channel, high-side (HS) switch for VCSEL applications. It is designed to pre-charge the input capacitors of VCSEL diodes. By working with a proper low-side (LS) FET, the device provides a compact and flexible solution for LiDAR applications.
The device integrates an open-loop boost converter, and its duty cycle is controlled by an external pulse-width modulation (PWM) waveform. When the boost converter's LS FET is on, the inductor current increases; when the LS FET is off, the inductor current charges the output capacitor of one channel, which is selectable via the SEL pins. In this way, the energy delivered to each output can be adjusted by changing the width of the PWM signal. This process also helps to compensate for the inconsistency of the parasitic inductance related to the VCSEL diode's discharging loop. Therefore, the VCSEL diode distributes currents among various channels, allowing it to achieve the same pulse value.
The MPQ58200-AEC1 integrates thorough protection features to ensure that the device can protect itself and detect various fault conditions, including input over-voltage protection (OVP) and under-voltage lockout (UVLO), output OVP, and over-current protection (OCP) for the boost converter.
The MPQ58200-AEC1 is available in a WLCSP-45 (2.5mmx4.5mm) package.
- Extend Battery Life:
- 1μA Shutdown Quiescent Current
- 380μA Supply Quiescent Current
- Vast Flexibility:
- Integrated Boost Converter
- Configurable Output Voltage with Pulse-Width Modulation (PWM) Input
- Independent Output Channel Control
- Selectable Pre-Defined Sequence
- Full Protection and Diagnostics:
- Over-Current Protection (OCP) for Boost
- Input Over-Voltage Protection (OVP) and Under-Voltage Lockout (UVLO)
- Output OVP
- Output Discharge
- Report Fault with Hardware Pin
- Other Features:
- High-Side (HS) Charging FET
- Low-Side (LS) Discharging FET
- 3.3V/1.8V Microcontroller Unit (MCU) Compatible
- MPSafeTM Compatible - Functional Safety Supporting Document Available
MPQ58200GC-xxxx-AEC1-Z MPQ58200GC-xxxx-AEC1-P
MPQ58200-AEC1 Resources
スマート・ハイサイドスイッチ製品カテゴリ -
フロントカメラ(同軸)アプリケーション -
MPQ5870-AEC1製品60V, 0.5A, Single-Channel, Smart High-Side Load Switch with High-Accuracy Current Sense, AEC-Q100 Qualified
MPQ5882-AEC1製品80V, E-Fuse and Smart High-Side Power Switch, AEC-Q100 Qualified
MPQ5073N-AEC1製品5.5V, 2A, Load Switch, AEC-Q100 Qualified
MPQ5071N-AEC1製品5.5V, 1A Load Switch, AEC-Q100 Qualified
MPQ77240FS-AEC1製品MPSafe、ASIL-B/D、16V、180mΩ、0.8A、クワッドチャネル、ハイサイドスイッチ、AEC-Q100認定済み
MPQ5884-AEC1製品80V、4.5mΩ、電子ヒューズおよびスマートハイサイドパワースイッチ搭載、AEC-Q100認定済み
VIDEO
車載用クワッドチャネル・ハイサイドスイッチ: MPQ77240FS-AEC1ビデオMPQ77240FS-AEC1は、最も要求の厳しい車載アプリケーション向けに設計された、スケーラブルで柔軟な、4チャネルのハイサイドスイッチです。5V~16Vの入力電圧幅とチャネルあたり最大0.8Aの負荷に対応し、バッテリー短絡保護、過電流保護 (OCP)、サーマルシャットダウンなどの機能によりシステムの安全性を確保します。MPQ77240FS-AEC1は、TQFN-17 (3mm x 4mm) パッケージでコンパクトで省スペースの電力制御を提供し、AEC-Q100認定およびASIL-Bに準拠しています。MPQ77240FS-AEC1が車載システムの設計をどのように向上できるかを今すぐご覧ください。 機能: 機能安全性 高精度電流検出機能 豊富な診断と保護 関連する製品ページ: MPQ77240FS-AEC1 MPQ586...
MPQ5862-AEC1製品16V、1.5A、90mΩ RDS(ON)、デュアルチャネル、ハイサイドスイッチ、AEC-Q100認定済み
