- 車載用IC (AECQ グレード)
- パワースイッチ
- スマート・ハイサイドスイッチ
- MPQ5071N-AEC1
MPQ5071N-AEC1
- 入力電圧(最小) (V)0.5
- 入力電圧 (最大) (V)5.5
- Iout (max) (A)1
- Ilimit (A)2.8
- Iq (mA)0.18
- Channels1
- EnableYes
- グレードAutomotive
- パッケージ(mm)SOT563
The MPQ5071N-AEC1 is a load switch designed to provide 1A of load protection across 0.5V to 5.5V input voltage (VIN) range. With the small on resistance (RDS(ON)) in a tiny SOT563 package, it provides a highly efficient, space-saving solution for infotainment, advanced driver-assistance systems (ADAS), or other automotive applications.
With the soft start (SS) function, the MPQ5071N-AEC1 can avoid inrush current during start-up. The device also provides a configurable soft-start time, output discharge functions, over-current protection (OCP), and thermal shutdown.
The maximum load at the output (N-channel MOSFET source) is limited via an internal current limit. This is accomplished by utilizing a sensing FET topology. An internal charge pump drives the gate of the power device, allowing a very low RDS(ON) DMOS power FET.
The MPQ5071N-AEC1 is available in a tiny, space-saving SOT563 package, and is available in AEC-Q100 Grade 1.
- Extremely Low 0.01µA Shutdown Current
- • Reduces Board Size:
- Available in an SOT563 Package
- Flexibility:
- Single Channel with 1A of Nominal Current
- Adjustable Start-Up Slew Rate
- Output Discharge
- Full Diagnostics and Protections:
- Internal Current Limit
- Thermal Shutdown
MPQ5071NGTF-AEC1-Z MPQ5071NGTF-AEC1-P
MPQ5071N-AEC1 Resources
スマート・ハイサイドスイッチ製品カテゴリ -
MPQ5870-AEC1製品60V, 0.5A, Single-Channel, Smart High-Side Load Switch with High-Accuracy Current Sense, AEC-Q100 Qualified
MPQ58200-AEC1製品50V, 32-Channel, High-Side Switch for VCSEL, AEC-Q100 Qualified
MPQ5882-AEC1製品80V, E-Fuse and Smart High-Side Power Switch, AEC-Q100 Qualified
MPQ5073N-AEC1製品5.5V, 2A, Load Switch, AEC-Q100 Qualified
MPQ77240FS-AEC1製品MPSafe、ASIL-B/D、16V、180mΩ、0.8A、クワッドチャネル、ハイサイドスイッチ、AEC-Q100認定済み
MPQ5884-AEC1製品80V、4.5mΩ、電子ヒューズおよびスマートハイサイドパワースイッチ搭載、AEC-Q100認定済み
VIDEO
車載用クワッドチャネル・ハイサイドスイッチ: MPQ77240FS-AEC1ビデオMPQ77240FS-AEC1は、最も要求の厳しい車載アプリケーション向けに設計された、スケーラブルで柔軟な、4チャネルのハイサイドスイッチです。5V~16Vの入力電圧幅とチャネルあたり最大0.8Aの負荷に対応し、バッテリー短絡保護、過電流保護 (OCP)、サーマルシャットダウンなどの機能によりシステムの安全性を確保します。MPQ77240FS-AEC1は、TQFN-17 (3mm x 4mm) パッケージでコンパクトで省スペースの電力制御を提供し、AEC-Q100認定およびASIL-Bに準拠しています。MPQ77240FS-AEC1が車載システムの設計をどのように向上できるかを今すぐご覧ください。 機能: 機能安全性 高精度電流検出機能 豊富な診断と保護 関連する製品ページ: MPQ77240FS-AEC1 MPQ586...
MPQ5862-AEC1製品16V、1.5A、90mΩ RDS(ON)、デュアルチャネル、ハイサイドスイッチ、AEC-Q100認定済み
MPQ5864-AEC1製品16V、0.8A、180mΩ RDS(ON)、クワッドチャネル、ハイサイドスイッチ、AEC-Q100認定済み
MPQ5894-AEC1製品36V、3A、クワッドチャネル、スマートハイサイドスイッチ、AEC-Q100認定済み
MPQ5896-AEC1製品60Vロードダンプ、3A、クワッドチャネル、スマートハイサイドスイッチ、AEC-Q100認定済み
