- 車載用IC (AECQ グレード)
- パワースイッチ
- スマート・ハイサイドスイッチ
- MPQ5870-AEC1
MPQ5870-AEC1
60V, 0.5A, Single-Channel, Smart High-Side Load Switch with High-Accuracy Current Sense, AEC-Q100 Qualified
- 入力電圧(最小) (V)3.5
- 入力電圧 (最大) (V)36
- Iout (max) (A)0.5
- Ilimit (A)0.6
- Iq (mA)0.5
- Channels1
- EnableYes
- グレードAutomotive
- パッケージ(mm)QFN-8 (2x2.5), SOT583
The MPQ5870-AEC1 is designed as a smart high-side power switch for a nominal 0.5A load. The device supports a wide 3.5V to 60V input voltage (VIN) range. The MPQ5870-AEC1 provides a highly efficient and compact solution with a small on resistance (RDS(ON)).
As a functional safety-capable device, the MPQ5870-AEC1 provides related safety documentation to aid in functional safety design.
The MPQ5870-AEC1 supports both internal and configurable, high-accuracy external current limits. The device helps clamp inrush current during short circuits, which improves system reliability. An adjustable start-up slew rate also helps reduce inrush current during start-up.
The CS/FT pin provides high-accuracy current-sense (CS), which achieves real-time and accurate diagnostics without further calibration. The voltage on the CS/FT pin represents 1 / KCS of the load current, where KCS is a constant value across the temperature and supply voltage. In addition, the CS/FT pin can report a fault by pulling up its voltage.
Full diagnostics during on and off states are developed for the MPQ5870-AEC1. By pulling the DIAG_EN pin up or down, the diagnostic functions (current sensing and off-state open load/short-to-battery detection) can be enabled or disabled. If off-state diagnostics are not required in the system, connecting to the EN pin can disable the function to further reduce quiescent current (IQ).
The MPQ5870-AEC1 is available in QFN-8 (2mmx2.5mm) and SOT583 packages, and is available in AEC-Q100 Grade 1 and AEC-Q100-012 Test Grade A.
- Built to Handle Tough Automotive Transients:
- Load Dump Up to 60V
- Cold Crank Down to 3.5V
- Cooler Thermals:
- Integrated MOSFET
- Extremely Low Standby Current: 0.5μA
- Low Quiescent Current (IQ) Mode: 500μA
- Reduces Board Size:
- Available in a QFN-8 (2.0mmx2.5mm) Package and a SOT583 Package
- Flexibility:
- Configurable External Current Limit
- Adjustable Start-up Slew Rate
- Compatible with 1.8V and 3.3V Logic
- Full Diagnostics and Protections:
- High-Accuracy Current Sense: ±1% at 0.5A and ±20% at 10mA
- Loss of GND Protection
- Drain-Source Voltage (VDS) Clamp for Inductive Load Switching
- On-State and Off-State Open Load And Battery Short Detection
- Thermal Shutdown
- Available in AEC-Q100-012 Test Grade A
- Documents Available for MPSafeTM QM System Design
MPQ5870GRPE-AEC1-Z MPQ5870GRPE-AEC1-P MPQ5870GTL-AEC1-Z MPQ5870GTL-AEC1-P
MPQ5870-AEC1 Resources
スマート・ハイサイドスイッチ製品カテゴリ -
フロントカメラ(同軸)アプリケーション -
MPQ58200-AEC1製品50V, 32-Channel, High-Side Switch for VCSEL, AEC-Q100 Qualified
MPQ5882-AEC1製品80V, E-Fuse and Smart High-Side Power Switch, AEC-Q100 Qualified
MPQ5073N-AEC1製品5.5V, 2A, Load Switch, AEC-Q100 Qualified
MPQ5071N-AEC1製品5.5V, 1A Load Switch, AEC-Q100 Qualified
MPQ77240FS-AEC1製品MPSafe、ASIL-B/D、16V、180mΩ、0.8A、クワッドチャネル、ハイサイドスイッチ、AEC-Q100認定済み
MPQ5884-AEC1製品80V、4.5mΩ、電子ヒューズおよびスマートハイサイドパワースイッチ搭載、AEC-Q100認定済み
VIDEO
車載用クワッドチャネル・ハイサイドスイッチ: MPQ77240FS-AEC1ビデオMPQ77240FS-AEC1は、最も要求の厳しい車載アプリケーション向けに設計された、スケーラブルで柔軟な、4チャネルのハイサイドスイッチです。5V~16Vの入力電圧幅とチャネルあたり最大0.8Aの負荷に対応し、バッテリー短絡保護、過電流保護 (OCP)、サーマルシャットダウンなどの機能によりシステムの安全性を確保します。MPQ77240FS-AEC1は、TQFN-17 (3mm x 4mm) パッケージでコンパクトで省スペースの電力制御を提供し、AEC-Q100認定およびASIL-Bに準拠しています。MPQ77240FS-AEC1が車載システムの設計をどのように向上できるかを今すぐご覧ください。 機能: 機能安全性 高精度電流検出機能 豊富な診断と保護 関連する製品ページ: MPQ77240FS-AEC1 MPQ586...
MPQ5862-AEC1製品16V、1.5A、90mΩ RDS(ON)、デュアルチャネル、ハイサイドスイッチ、AEC-Q100認定済み
