- 車載用IC (AECQ グレード)
- パワースイッチ
- スマート・ハイサイドスイッチ
- MPQ5882-AEC1
MPQ5882-AEC1
- 入力電圧(最小) (V)7
- 入力電圧 (最大) (V)60
- Iout (max) (A)120
- Iq (mA)0.026
- Channels1
- Enable1
- グレードAutomotive
- パッケージ(mm)QFN-30 (6x8)
The MPQ5882-AEC1 is an automotive-grade, low-resistance e-fuse and smart high-side power switch with low quiescent current (IQ) mode. It is designed for demanding applications such as high-current relay replacements. The protection and diagnostic functions improve system robustness and performance.
The device uses a proprietary, fuse-like over-current protection (OCP), which can emulate the behavior of a passive fuse. Current-sensing and temperature-sensing allow monitoring of the switch status. Open-load detection monitors the load's health. Low-IQ mode can help prolong the battery life when the system is in sleep mode.
The MPQ5882-AEC1 provides robust protection features, including configurable, fuse-like over-current protection (OCP), short-circuit protection (SCP), loss of ground, loss of power supply, over-temperature protection (OTP), reverse battery protection, and reverse load protection.
The device can survive under severe transient pulses. When a bidirectional TVS diode is applied in the system, the MPQ5882-AEC1 can handle the tests defined in ISO 7637-2, ISO 16750-2, and ISO 21780 standards. Under a negative input voltage (VIN), the MPQ5882-AEC1 turns on the MOSFET to achieve the same current capability under a positive VIN, and features a rugged power N-channel MOSFET.
The MPQ5882-AEC1 is available in a QFN-30 (6mmx8mm) package, and is available in AEC-Q100 Grade 1.
- Built to Handle Tough Automotive Transients:
- Load Dump Up to 80V
- Cold Crank Down to 6V
- Reverse-Battery Protection
- Cooler Thermals:
- Integrated MOSFET
- Low Quiescent Current (IQ) Mode
- Extremely Low Shutdown Current (IOFF)
- Full Diagnostics and Robust Protection:
- Configurable, Fuse-Like Over-Current Protection (OCP)
- Fast-Off Short-Circuit Protection (SCP)
- Loss of Ground and Loss of Power Supply Protection
- Switch-off Negative Voltage Clamping
- Self-Protection during Reverse Load
- Thermal Monitor and Over-Temperature Protection (OTP)
- High-Accuracy Current Sense
- Off-State Open-Load Detection
- Fault State Reporting
- Compliant with AEC-Q100-012 Test Grade A
- Additional Features:
- 300mJ Repetitive Unclamped Inductive Switching (UIS) Energy
- Available in a QFN-30 (6mmx8mm) Package
MPQ5882GQY-AEC1-T
MPQ5882-AEC1 Resources
スマート・ハイサイドスイッチ製品カテゴリ -
フロントカメラ(同軸)アプリケーション -
MPQ5870-AEC1製品60V, 0.5A, Single-Channel, Smart High-Side Load Switch with High-Accuracy Current Sense, AEC-Q100 Qualified
MPQ58200-AEC1製品50V, 32-Channel, High-Side Switch for VCSEL, AEC-Q100 Qualified
MPQ5073N-AEC1製品5.5V, 2A, Load Switch, AEC-Q100 Qualified
MPQ5071N-AEC1製品5.5V, 1A Load Switch, AEC-Q100 Qualified
MPQ77240FS-AEC1製品MPSafe、ASIL-B/D、16V、180mΩ、0.8A、クワッドチャネル、ハイサイドスイッチ、AEC-Q100認定済み
MPQ5884-AEC1製品80V、4.5mΩ、電子ヒューズおよびスマートハイサイドパワースイッチ搭載、AEC-Q100認定済み
VIDEO
車載用クワッドチャネル・ハイサイドスイッチ: MPQ77240FS-AEC1ビデオMPQ77240FS-AEC1は、最も要求の厳しい車載アプリケーション向けに設計された、スケーラブルで柔軟な、4チャネルのハイサイドスイッチです。5V~16Vの入力電圧幅とチャネルあたり最大0.8Aの負荷に対応し、バッテリー短絡保護、過電流保護 (OCP)、サーマルシャットダウンなどの機能によりシステムの安全性を確保します。MPQ77240FS-AEC1は、TQFN-17 (3mm x 4mm) パッケージでコンパクトで省スペースの電力制御を提供し、AEC-Q100認定およびASIL-Bに準拠しています。MPQ77240FS-AEC1が車載システムの設計をどのように向上できるかを今すぐご覧ください。 機能: 機能安全性 高精度電流検出機能 豊富な診断と保護 関連する製品ページ: MPQ77240FS-AEC1 MPQ586...
MPQ5862-AEC1製品16V、1.5A、90mΩ RDS(ON)、デュアルチャネル、ハイサイドスイッチ、AEC-Q100認定済み
