- 車載用IC (AECQ グレード)
- AECQ対応スイッチングコンバータとコントローラ
- PMIC
- MPQ70336FS-AEC1
MPQ70336FS-AEC1
MPSafeTM, ASIL-D, 36V, 4A Buck Converter with 4-Channel Voltage Monitor PMIC, AEC-Q100 Qualifie
- Regulated Outputs5
- 入力電圧(最小) (V)3.3
- 入力電圧 (最大) (V)36
- Iout (max) (A)4
- パッケージ(mm)TQFN-25 (3x6)
- Step-Down DC/DC Controller0
- Step-Down DC/DC Converter1
- Step-Up DC/DC Controller0
- Step-Up DC/DC Converter0
- Internal LDO0
- Iq (typ) (mA)0.02
- fsw(最大)(kHz)2500
- Step-Down Converter Current (A)4
- Vfb (V)0.8
- PGYes
- SSInternal
- グレードAutomotive
The MPQ70336FS-AEC1 is an ASIL-D hardware capable power management IC (PMIC) featuring a buck converter and an integrated, 4-channel voltage monitor. It is engineered for automotive safety applications that require an off-battery safety power supply and additional voltage rails monitored for safety.
The MPQ70336FS-AEC1 features a synchronous, step-down switching regulator that provides up to 4A of peak output current (IOUT) with peak current mode control. The configurable switching frequency (fSW) ranges between 350kHz and 2.5MHz.
High power conversion efficiency across a wide load range is achieved by scaling down fSW under light-load conditions to reduce the switching and gate driving losses. Frequency foldback helps prevent inductor current (IL) runaway during start-up. Thermal shutdown provides fault-tolerant operation.
Each of the four voltage monitor inputs has configurable over-voltage (OV) and under-voltage (UV) thresholds. Highly accurate high-frequency (HF) and low-frequency (LF) voltage monitoring can detect when the voltage thresholds are reached. Two of the inputs are differential, making them optimal for remote voltage-sensing to monitor rails with high current levels.
The MPQ70336FS-AEC1 can record the order in which voltage rails are sequenced, as well as their associated timestamps. The device is accessible through an I2C interface.
With the integration of sophisticated functional safety features including built-in self-testing (BIST), diagnostics, and write protection, this device is targeted to support applications with a high automotive safety integrity level up to ASIL-D.
The MPQ70336FS-AEC1 is available in a TQFN-25 (3mmx6mm) package with wettable flanks.
- Load Dump Up to 42V
- Cold Crank Down to 3.1V
- Operating Junction Temperature (TJ) from -40°C to +150°C
- Available in a TQFN-25 (3mmx6mm) Package with Wettable Flanks
- Highly Integrated Safety Power Supply:
- 4A Peak Output Current (IOUT)
- Minimum 65ns On Time and 50ns Off Time
- x4 Voltage Monitors
- x2 Single-Ended Channels, x2 Differential Channels:
- Adjustable Over-Voltage (OV) and Under-Voltage (UV) Thresholds for High-Frequency (HF) and Low-Frequency (LF) Components: 0.2V to 5.5V
- Accuracy: ±0.5% for >1V, ±5mV for <1V
- Power Sequence Recording
- Power Good (PG) Output
- Over-Current Protection (OCP) with Hiccup Mode
- Optimized for EMC/EMI:
- Symmetric VIN Pinout
- CISPR 25 Class 5 Compliant
- 350kHz to 2.5MHz Configurable Switching Frequency (fSW)
- Flexibility with Digital Configurability:
- I2C Interface with Packet Error Checking (PEC)
- Functional Safety:
- Interrupt Output Pin (Fault Reporting)
- Cyclic Redundancy Check (CRC) Protection on Registers
- Write Protection for Critical Registers
- Hardware Capable Up to ASIL-D
- ISO 26262 Functional Safety Certified
MPQ70336FSGRJTE-xxxxAEC-Z MPQ70336FSGRJTE-xxxxAEC-P MPQ70336FSGRJTE-0000AEC-Z MPQ70336FSGRJTE-0000AEC-P
MPQ70336FS-AEC1 Resources
PMIC製品カテゴリ -
MPQ7936-AEC1製品5V PMIC with 4 Buck Converters (2A/2.5A/4.5A/4.5A), 4 LDOs, and Flexible System Settings via the I2C and MOTP, AEC-Q100 Qualified
MPQ7907-AEC1製品MPSafeTM-Compatible PMIC, 5.5V, 5 Bucks and 4 LDOs with User-Configurable State Machine, AEC-Q100 Qualified
MPQ7929-AEC1製品MPSafeTM Compatible, 18V, 4-Channel PMIC with 3 Bucks, 1 LDO, and Uprated Current, AEC-Q100 Qualified
MPQ7932-AEC1製品MPSafeTM-Compatible, 5.5V PMIC with 6 Buck Converters, AEC-Q100 Qualified
MPQ70332FS-AEC1製品45V, 3A HV Buck, 2A LV Buck, 250mA LV Boost, ASIL-B PMIC, AEC-Q100 Qualified
MPQ70333FS-AEC1製品MPSafeTM, 45V, 3A Buck and 250mA Boost ASIL-D PMIC, AEC-Q100 Qualified
MPQ7902-AEC1製品45V Power Management IC with 2 Bucks, 1 Boost, and Flexible System Settings via the SPI, AEC-Q100 Qualified
MPQ7935-AEC1製品5.5V, 5-Channel PMIC with Four 1A Buck Converters and a 300mA LDO, I2C, and OTP, AEC-Q100 Qualified
MPQ4390-AEC1製品40V, High Current Output, Synchronous, Dual Buck Converter, AEC-Q100 Qualified
MPQ70171FS-AEC1製品MPSafeTM, ASIL-B, 5.5V PMIC with 5 Bucks and 4 LDOs for Safety-Relevant Applications, AEC-Q100 Qualified
MPQ7970-AEC1製品MPSafeTM-Compatible, 5.5V PMIC for SoCs, 5 LDOs, 4 GPIOs, and 2 Voltage Monitors, AEC-Q100 Qualified
MPQ7934-AEC1製品MPSafeTM-Compatible, 36V, 4-Channel PMIC with 3 Bucks and 1 LDO, AEC-Q100 Qualified
MPQ70244FS-AEC1製品3個の降圧および1個のLDO内蔵、拡張PMBusインタフェースロジック付き、MPSafe、ASIL-B、18 V、4チャネルPMIC、AEC-Q100認定済み
MPQ70342FS-AEC1製品MPSafe、ASIL-B、36V、3チャネルPMIC、AEC-Q100認定済み
MPQ70341FS-AEC1製品MPSafe、ASIL-B、36V、3個の降圧型コンバータおよび1個のLDO内蔵、4チャネルPMIC、AEC-Q100認定済み
MPQ70701FS-AEC1製品5個のLDO、4個のGPIO、2個の電圧モニタ内蔵、MPSafe、ASIL-D、SoC向け、5.5V、PMIC、AEC-Q100認定済み
MPQ70241FS-AEC1製品3個の降圧と1個のLDO内蔵、MPSafe、18V、4チャネル、PMIC、ASIL-B評価、AEC-Q100認定済み
MPQ70430FS-AEC1製品65V、3A HV降圧、2A LV降圧、250mA LV昇圧、ASIL-D PMIC、AEC-Q100認定済み
MPQ73351FS-AEC1製品MPSafe、ASIL-D、40V、高出力電流、同期整流、デュアル降圧コンバータ、AEC-Q100認定済み
