MPQ70336FS-AEC1
MPSafeTM, ASIL-D, 36V, 4A Buck Converter with 4-Channel Voltage Monitor PMIC, AEC-Q100 Qualifie
- Regulated Outputs5
- Vin (min) (V)3.3
- Vin (max) (V)36
- Iout (max) (A)4
- Package (mm)TQFN-25 (3x6)
- Step-Down DC/DC Controller0
- Step-Down DC/DC Converter1
- Step-Up DC/DC Controller0
- Step-Up DC/DC Converter0
- Internal LDO0
- Iq (typ) (mA)0.02
- fsw (max) (kHz)2500
- Step-Down Converter Current (A)4
- Vfb (V)0.8
- PGYes
- SSInternal
- GradeAutomotive
The MPQ70336FS-AEC1 is an ASIL-D hardware capable power management IC (PMIC) featuring a buck converter and an integrated, 4-channel voltage monitor. It is engineered for automotive safety applications that require an off-battery safety power supply and additional voltage rails monitored for safety.
The MPQ70336FS-AEC1 features a synchronous, step-down switching regulator that provides up to 4A of peak output current (IOUT) with peak current mode control. The configurable switching frequency (fSW) ranges between 350kHz and 2.5MHz.
High power conversion efficiency across a wide load range is achieved by scaling down fSW under light-load conditions to reduce the switching and gate driving losses. Frequency foldback helps prevent inductor current (IL) runaway during start-up. Thermal shutdown provides fault-tolerant operation.
Each of the four voltage monitor inputs has configurable over-voltage (OV) and under-voltage (UV) thresholds. Highly accurate high-frequency (HF) and low-frequency (LF) voltage monitoring can detect when the voltage thresholds are reached. Two of the inputs are differential, making them optimal for remote voltage-sensing to monitor rails with high current levels.
The MPQ70336FS-AEC1 can record the order in which voltage rails are sequenced, as well as their associated timestamps. The device is accessible through an I2C interface.
With the integration of sophisticated functional safety features including built-in self-testing (BIST), diagnostics, and write protection, this device is targeted to support applications with a high automotive safety integrity level up to ASIL-D.
The MPQ70336FS-AEC1 is available in a TQFN-25 (3mmx6mm) package with wettable flanks.
- Load Dump Up to 42V
- Cold Crank Down to 3.1V
- Operating Junction Temperature (TJ) from -40°C to +150°C
- Available in a TQFN-25 (3mmx6mm) Package with Wettable Flanks
- Highly Integrated Safety Power Supply:
- 4A Peak Output Current (IOUT)
- Minimum 65ns On Time and 50ns Off Time
- x4 Voltage Monitors
- x2 Single-Ended Channels, x2 Differential Channels:
- Adjustable Over-Voltage (OV) and Under-Voltage (UV) Thresholds for High-Frequency (HF) and Low-Frequency (LF) Components: 0.2V to 5.5V
- Accuracy: ±0.5% for >1V, ±5mV for <1V
- Power Sequence Recording
- Power Good (PG) Output
- Over-Current Protection (OCP) with Hiccup Mode
- Optimized for EMC/EMI:
- Symmetric VIN Pinout
- CISPR 25 Class 5 Compliant
- 350kHz to 2.5MHz Configurable Switching Frequency (fSW)
- Flexibility with Digital Configurability:
- I2C Interface with Packet Error Checking (PEC)
- Functional Safety:
- Interrupt Output Pin (Fault Reporting)
- Cyclic Redundancy Check (CRC) Protection on Registers
- Write Protection for Critical Registers
- Hardware Capable Up to ASIL-D
- ISO 26262 Functional Safety Certified
MPQ70336FSGRJTE-xxxxAEC-Z MPQ70336FSGRJTE-xxxxAEC-P MPQ70336FSGRJTE-0000AEC-Z MPQ70336FSGRJTE-0000AEC-P
MPQ70336FS-AEC1 Resources
PMICSPRODUCT CATEGORY -
MPQ70156FS-AEC1PRODUCTMPSafeTM, ASIL-B, 6V, 3A, PMIC with Buck Converter and 1-Channel Window Voltage Monitor, AEC-Q100 Qualified
MPQ7936-AEC1PRODUCT5V PMIC with 4 Buck Converters (2A/2.5A/4.5A/4.5A), 4 LDOs, and Flexible System Settings via the I2C and MOTP, AEC-Q100 Qualified
MPQ7907-AEC1PRODUCTMPSafeTM-Compatible PMIC, 5.5V, 5 Bucks and 4 LDOs with User-Configurable State Machine, AEC-Q100 Qualified
MPQ7929-AEC1PRODUCTMPSafeTM Compatible, 18V, 4-Channel PMIC with 3 Bucks, 1 LDO, and Uprated Current, AEC-Q100 Qualified
MPQ7932-AEC1PRODUCTMPSafeTM-Compatible, 5.5V PMIC with 6 Buck Converters, AEC-Q100 Qualified
MPQ70332FS-AEC1PRODUCT45V, 3A HV Buck, 2A LV Buck, 250mA LV Boost, ASIL-B PMIC, AEC-Q100 Qualified
MPQ70160FS-AEC1PRODUCTMPSafeTM ASIL-D, 5.5V, PMIC with 6 Buck Converters, AEC-Q100 Qualified
MPQ70333FS-AEC1PRODUCTMPSafeTM, 45V, 3A Buck and 250mA Boost ASIL-D PMIC, AEC-Q100 Qualified
MPQ7902-AEC1PRODUCT45V Power Management IC with 2 Bucks, 1 Boost, and Flexible System Settings via the SPI, AEC-Q100 Qualified
MPQ7935-AEC1PRODUCT5.5V, 5-Channel PMIC with Four 1A Buck Converters and a 300mA LDO, I2C, and OTP, AEC-Q100 Qualified
MPQ4390-AEC1PRODUCT40V, High Current Output, Synchronous, Dual Buck Converter, AEC-Q100 Qualified
MPQ70171FS-AEC1PRODUCTMPSafeTM, ASIL-B, 5.5V PMIC with 5 Bucks and 4 LDOs for Safety-Relevant Applications, AEC-Q100 Qualified
MPQ7970-AEC1PRODUCTMPSafeTM-Compatible, 5.5V PMIC for SoCs, 5 LDOs, 4 GPIOs, and 2 Voltage Monitors, AEC-Q100 Qualified
MPQ7934-AEC1PRODUCTMPSafeTM-Compatible, 36V, 4-Channel PMIC with 3 Bucks and 1 LDO, AEC-Q100 Qualified
MPQ70244FS-AEC1PRODUCTMPSafeTM, ASIL-B, 18V, 4-Channel PMIC with 3 Bucks and 1 LDO, Enhanced PMBus Interface Logic, AEC-Q100 Qualified
MPQ70342FS-AEC1PRODUCTMPSafeTM ASIL-B, 36V, 3-Channel PMIC, AEC-Q100 Qualified
MPQ70341FS-AEC1PRODUCTMPSafeTM, ASIL-B, 36V, 4-Channel PMIC with 3 Bucks and 1 LDO, AEC-Q100 Qualified
MPQ70701FS-AEC1PRODUCTMPSafeTM ASIL-B, 5.5V PMIC for SoCs with 5 LDOs, 4 GPIOs, and 2 Voltage Monitors, AEC-Q100 Qualified
MPQ70241FS-AEC1PRODUCTMPSafeTM, 18V, 4-Channel PMIC with 3 Bucks and 1 LDO, ASIL-B Rated, AEC-Q100 Qualified
MPQ70430FS-AEC1PRODUCT65V, 3A HV Buck, 2A LV Buck, 250mA LV Boost, ASIL-D PMIC, AEC-Q100 Qualified
MPQ73351FS-AEC1PRODUCTMPSafeTM ASIL-D, 40V, High Output Current, Synchronous, Dual Buck Converter, AEC-Q100 Qualified
