- 電源モジュール
- Intelli-Module
- MPC22157-A-130
MPC22157-A-130
- Module AssemblyOpen Frame
- 入力電圧(最小) (V)4
- 入力電圧 (最大) (V)16
- Vout (min) (V)0.5
- Vout (max) (V)2
- Iout (max) (A)130
- fsw(最小)(kHz)500
- fsw(最大)(kHz)1500
- Dimension WxL (mm)9x9.9
- Dimension (H) (mm)7.85
- Mounting TypeSurface Mount
- グレードIndustrial
- Dimension (H) (Max) (mm)8
The MPC22157-A-130 is a dual-phase, non-isolated, high-efficiency step-down power module. It integrates the driver MOSFETs (DrMOS) and inductors to provide high efficiency and a small footprint, which is ideal for server applications.
The device has two independent outputs, which can be used separately or in parallel. It can achieve up to 130A (65A/phase) of output current (IOUTx) across a wide input voltage (VIN) range.
The MPC22157-A-130 offers many features to simplify system design. The device works with tri-state pulse-width modulation (PWM) signal controllers, has Accu-SenseTM current-sensing to monitor the inductor current (IL), and has temperature-sensing to report the junction temperature (TJ).
The MPC22157-A-130 is available in an LGA-72 (9mmx9.9mmx7.85mm) package.
- Up to 130A of Continuous Output Current (IOUT)
- Temperature Sense
- Fault Reporting
- Typical Weight: 3.8g
- Available in an LGA-72(9mmx9.9mmx7.85mm) Package
MPC22157-A-130-T
MPC22157-A-130 Resources
スイッチ用電源ソリューションアプリケーション -
AI (人工知能) ソリューションアプリケーション -
プロセッサ用コア電源 INTELLI-MODULE (DRMOS + インダクタ)製品カテゴリ -
INTELLI-MODULE製品カテゴリ -
MPC22174-170製品Dual-Phase, TLVR Intelli-ModuleTM with Quiet SwitcherTM Technology
MPC22154-170製品170A, Dual-Phase Intelli-ModuleTM with Quiet SwitcherTM Technology
MPC24180-260製品260A, Four-Phase Intelli-ModuleTM with Quiet SwitcherTM Technology
MPC22175-130製品130A, Dual-Phase TLVR Intelli-ModuleTM with Quiet SwitcherTM Technology
MPC22166-D-130製品5mm, 130A, Dual-Phase Intelli-ModuleTM with Quiet SwitcherTM Technology
MPC22158-130製品130A、8mm x 8mm x 4mm、Quiet Switcherテクノロジー搭載、デュアルフェーズ Intelli-Module
MPC24380-260製品260A、Quiet Switcher™ テクノロジーを備えた4フェーズIntelli-Module™
MPC22164-A-130製品9mm x 9.9mm x 10mm、130A、2相、高電力密度、電源モジュール
MPC22165-A-170製品的確な高電流密度、9mm x 9.9mm x 10mm、170A、2フェーズ、高電力密度、Intelli-Module
MPC22157-130製品両面冷却機能付き、130A、8mm、デュアルフェーズIntelli-Module
MPC22166-B-130製品1130A、両面冷却機能付き、デュアルフェーズIntelli-Module
MPC22166-A-130製品1130A、Quiet Switcherテクノロジー搭載、2フェーズIntelli-Module
MPSオープンアクセラレータモジュール (OAM) 電源システムの紹介寄稿文世界がより持続可能な未来へと移行するにつれ、炭素排出量を削減するエネルギー効率の高いソリューションに対する需要が高まっており、人工知能 (AI) などの新興分野も例外でないことが証明されています。MPSは、エネルギー効率の高いソリューションを求める動向に応えて、炭素排出量の削減に向けたより効率の高い電源ソリューションの提供に取り組んでいます。これは、顧客がAIとハイパフォーマンスコンピューティング (HPC) において、ますます緊急性が増すエネルギー節約と排出削減の目標を達成するのに役立ちます。 MPSの電源製品は、効率性と安定したパフォーマンスを発揮する環境にやさしい省エネなデータセンターの構築を目標にして、モジュール化とAIの方向性に従っています。図1は、MPSの48Vオープンアクセラレータモジュール (OAM) 電源システムを示しています。 AI OAM 電源シス...
USE CASE
INTELLI-MODULETM 使用事例 : OAMフォームファクタのAIプロセッサ使用例この使用事例では、オープンアクセラレータ モジュール (OAM) フォームファクタのAIプロセッサ向けMPC22167-130のアプリケーションについて検討します (図1参照)。 複数のMPC22167-130デバイスを第1段の電源モジュールとペアリングして、オープン アクセラレータ モジュールフォームファクタのAIプロセッサの高電力要件を満たすエンドツーエンドの電源ソリューションに対応できます。 市場では、自動運転、自動化された顧客サービス業務、予測メンテナンスなどの新しいアプリケーションにスーパーコンピュータを使用するための洗練された方法がますます増えており、AIコンピューティングへの関心は急激に高まっています。これらのアプリケーションにより、スーパーコンピュータの電力要件が増加しました。CPUとGPUの現在の需要が増加するにつれて、設計者は、電圧レギュレータ (VR)...
MPC22168-170製品16V、170A、Quiet Switcherテクノロジー搭載、デュアルフェーズ Intelli-Module
MPC22165-170製品Quiet Switcherテクノロジー搭載、170A、2フェーズIntelli-Phase電源モジュール
MPC22167-130製品16V、130A、Quiet Switcherテクノロジー搭載、デュアルフェーズIntelli-Module
MPC22164-130製品Quiet Switcherテクノロジー搭載、130A、2相、Intelli-Phase電源モジュール
MPC22163-130製品130A、Quiet Switcherテクノロジー搭載、デュアルフェーズIntelli-Module
MPC22161-120製品120A、Quiet Switcherテクノロジー搭載、デュアルフェーズIntelli-Module
