- 車載用IC (AECQ グレード)
- LDO
- MPQ20083-AEC1
MPQ20083-AEC1
- 入力電圧(最小) (V)3
- 入力電圧 (最大) (V)40
- Iout (mA)150
- Vout (min) (V)3.3
- Vout (max) (V)5
- Iq (typ) (µA)41
- PSRR @ 1kHz (dB)77
- Vdropout (mV)210
- Accuracy (±%)1.35
- Noise (µVrms)280
- パッケージ(mm)SOT-223
- グレードAutomotive
The MPQ20083-AEC1 is a low-power, low-dropout (LDO) linear regulator that supplies power to systems that are connected to the battery in automotive applications. It includes a wide 3V to 40V input voltage (VIN) range, making it capable of withstanding transients (such as load dump) that are anticipated in automotive systems.
The device is an optimal solution for powering always-on components such as microcontrollers (MCUs) and controller area network (CAN) transceivers in standby systems. The wide output voltage (VOUT) range allows the device to generate the bias voltage for silicon carbide (SiC) gate drivers and microphones as well as power MCUs and processors.
The device also incorporates exceptionally precise VOUT accuracy of ±1.35% across line, load, and temperature. This allows the device to quickly react to changes in load or line such as during cold-crank conditions.
The MPQ20083-AEC1 is available in an SOT-223 package, and is available in AEC-Q100 Grade 1. The low thermal resistance enables sustained operation against dissipation across the device.
- Versatile Voltage Range:
- Wide 3V to 40V Input Voltage (VIN) Range
- Fixed 3.3V or 5V Output Voltage (VOUT)
- Reduced Board Size:
- Available in an SOT-223 Package
- Additional Features:
- ±1.35% Output Accuracy Over-Temperature
- 210mV Low-Dropout Voltage
- High PSRR (77dB at 1kHz)
MPQ20083GTD-xxxx-AEC1-Z MPQ20083GTD-xxxx-AEC1-P
MPQ20083-AEC1 Resources
LDO製品カテゴリ -
MPQ20088-AEC1製品40V, 500mA, High-Precision, High PSRR, Adjustable Output Linear Regulator, AEC-Q100 Qualified
MPQ20087-AEC1製品40V, 500mA, High-Accuracy, High-PSRR, Fixed-Output Linear Regulator, AEC-Q100 Qualified
MPQ20086-AEC1製品40V, 500mA, High-Accuracy, High-PSRR, Adjustable-Output Linear Regulator, AEC-Q100 Qualified
MPQ20085-AEC1製品40V, 150mA, High-Accuracy LDO with Power Good Adjustment, AEC-Q100 Qualified
MPQ20033-AEC1製品5.5V, 0.3A, High-Accuracy, Low-IQ LDO with Power Good, AEC-Q100 Qualified
MPQ20032-AEC1製品5.5V, 0.5A, High-Accuracy, Low-IQ LDO with Power Good, AEC-Q100 Qualified
MPQ71000FS-AEC1製品MPSafeTM ASIL-D, 36V, 300mA, Dual LDO with ADC and I2C Interface, AEC-Q100 Qualified
MPQ2023-AEC1製品ADC内蔵、I2Cインタフェース付き、36V、300mA、デュアルLDO、AEC-Q100認定済み
MPQ20084-AEC1製品40V、150mA、高精度、出力調整可能LDO、AEC-Q100認定済み
MPQ20031-AEC1製品5.5V、1A、高精度、パワーグッド付き低 Iq LDO、AEC-Q100認定
MPQ20082-AEC1製品40V、300mA、低静止電流、調整可能な出力リニアレギュレータ、AEC-Q100認定
MPQ2019A-AEC1製品40V、300mA、低静止電流、調整可能出力付きリニアレギュレータ、AEC-Q100認定
MPQ2013D-AEC1製品40V、100mA、低静止電流リニアレギュレータ、AEC-Q100認定
MPQ2022A-AEC1製品デジタル診断および保護用のシリアル デジタルインタフェースおよびADCを備えた、40V、300mA デュアルチャネルLDO、AEC-Q100認定
MPQ2026A-AEC1製品事前昇圧、業界標準の同期シリアルインタフェース、デジタル診断および保護用ADCを備えた、40V、300mAデュアルチャネルLDO、AEC-Q100認定済み
MPQ2024A-AEC1製品事前昇圧デジタルインタフェース、デジタル診断および保護用ADCを備えた、40V、300mA、ファントムアンテナLDO、AEC-Q100認定
MPQ2016-AEC1製品40V、30mA、低自己消費電流リニアレギュレータ、AEC-Q100認定
MPQ20073-AEC1製品2A、1.3V~6.0V、DDRメモリ向けターミネーションレギュレータ、AEC-Q100認定
MPQ2019-AEC1製品40V、300mA、低静止電流、調整可能な出力リニアレギュレータ
MPQ2013-AEC1製品40V、150mA、低静止電流リニアレギュレータ
