- 車載用IC (AECQ グレード)
- LDO
- MPQ20033-AEC1
MPQ20033-AEC1
- 入力電圧(最小) (V)1.6
- 入力電圧 (最大) (V)5.5
- Iout (mA)300
- Vout (min) (V)0.5
- Vout (max) (V)5
- Iq (typ) (µA)26
- PSRR @ 1kHz (dB)59
- Vdropout (mV)78
- Accuracy (±%)1.4
- Noise (µVrms)60
- パッケージ(mm)QFN-8 (2x2), QFN-8 (3x3), SOT563, TQFN-6 (2x2), TSOT23-5
- グレードAutomotive
The MPQ20033-AEC1 is an ultra-low dropout linear regulator that supplies up to 0.3A of current with a 1.6V to 5.5V input range. The device includes a low-dropout voltage, low quiescent supply current (IQ), and provides fast line and load transient performance, making it ideal for automotive battery-powered equipment.
The MPQ20033-AEC1 provides fixed output voltage (VOUT) options: 0.75V, 0.85V, 1.1V, 1.2V, 1.5V, 1.7V, 1.8V, 2.5V, 2.8V, 2.9V, 3V, or 3.3V. The device also provides adjustable-output options from 0.5V to 5V.
The MPQ20033-AEC1 is stable with small ceramic output capacitors, allowing for a small overall solution size. Full protection features include integrated thermal shutdown, current limit foldback, power good (PG), and under-voltage lockout (UVLO).
The MPQ20033-AEC1 family provides different package options, including QFN-8 (3mmx3mm), QFN-8 (2mmx2mm), TQFN-6 (2mmx2mm), TSOT23-5, and SOT563 packages. It is available in AEC-Q100 Grade 1.
- Built to Handle Tough Automotive Transients and Meet AEC-Q100 Requirements:
- Guaranteed Industrial and Automotive Temperature
- 0.5V to 5V Adjustable Output Voltage (VOUT) Option
- Fixed VOUT Options: 0.75V, 0.85V, 1.1V, 1.2V, 1.5V, 1.7V,1.8V, 2.5V, 2.8V, 2.9V, 3V, or 3.3V
- Outputs ±1.4% Over-Temperature Accuracy
- Stable with Low Output Ceramic Capacitance (>1μF)
- 26µA Quiescent Supply Current (IQ)
- Supports Multiple Package Options:
- Available in a Small QFN-8 (3mmx3mm) Package
- Available in a Small QFN-8 (2mmx2mm) Package
- Available in a Small TQFN-6 (2mmx2mm) Package
- Available in a TSOT23-5 Package
- Available in an SOT563 Package
- Additional Features:
- 0.3A Nominal Current
- Current Limit Foldback
- Power Good (PG)
MPQ20033GQE-xxx0-AEC1-Z MPQ20033GQE-xxx0-AEC1-P MPQ20033GQE-xxx1-AEC1-Z MPQ20033GQE-xxx1-AEC1-P MPQ20033GGTE-xxx0-AEC1-Z MPQ20033GGTE-xxx0-AEC1-P MPQ20033GGTE-2900-AEC1-Z MPQ20033GGTE-2900-AEC1-P MPQ20033GGE-xxx0-AEC1-Z MPQ20033GGE-xxx0-AEC1-P MPQ20033GJ-xxx0-AEC1-Z MPQ20033GJ-xxx0-AEC1-P MPQ20033GTF-xxx0-AEC1-Z MPQ20033GTF-xxx0-AEC1-P
MPQ20033-AEC1 Resources
LDO製品カテゴリ -
MPQ20088-AEC1製品40V, 500mA, High-Precision, High PSRR, Adjustable Output Linear Regulator, AEC-Q100 Qualified
MPQ20087-AEC1製品40V, 500mA, High-Accuracy, High-PSRR, Fixed-Output Linear Regulator, AEC-Q100 Qualified
MPQ20086-AEC1製品40V, 500mA, High-Accuracy, High-PSRR, Adjustable-Output Linear Regulator, AEC-Q100 Qualified
MPQ20085-AEC1製品40V, 150mA, High-Accuracy LDO with Power Good Adjustment, AEC-Q100 Qualified
MPQ20032-AEC1製品5.5V, 0.5A, High-Accuracy, Low-IQ LDO with Power Good, AEC-Q100 Qualified
MPQ71000FS-AEC1製品MPSafeTM ASIL-D, 36V, 300mA, Dual LDO with ADC and I2C Interface, AEC-Q100 Qualified
MPQ20083-AEC1製品40V, 150mA, High-Accuracy, High-PSRR LDO, AEC-Q100 Qualified
MPQ2023-AEC1製品ADC内蔵、I2Cインタフェース付き、36V、300mA、デュアルLDO、AEC-Q100認定済み
MPQ20084-AEC1製品40V、150mA、高精度、出力調整可能LDO、AEC-Q100認定済み
MPQ20031-AEC1製品5.5V、1A、高精度、パワーグッド付き低 Iq LDO、AEC-Q100認定
MPQ20082-AEC1製品40V、300mA、低静止電流、調整可能な出力リニアレギュレータ、AEC-Q100認定
MPQ2019A-AEC1製品40V、300mA、低静止電流、調整可能出力付きリニアレギュレータ、AEC-Q100認定
MPQ2013D-AEC1製品40V、100mA、低静止電流リニアレギュレータ、AEC-Q100認定
MPQ2022A-AEC1製品デジタル診断および保護用のシリアル デジタルインタフェースおよびADCを備えた、40V、300mA デュアルチャネルLDO、AEC-Q100認定
MPQ2026A-AEC1製品事前昇圧、業界標準の同期シリアルインタフェース、デジタル診断および保護用ADCを備えた、40V、300mAデュアルチャネルLDO、AEC-Q100認定済み
