- パワーマネジメント
- ディスプレイ用電源とコントローラ
- LCDバイアス電源
- MPQ5613D-AEC1
MPQ5613D-AEC1
Automotive TFT LCD Bias Driver with Gate Voltage Shaping and VCOM Buffer, AEC-Q100 Qualified
- 入力電圧(最小) (V)2.7
- 入力電圧 (最大) (V)12
- グレードAutomotive
- パッケージ(mm)QFN-28 (4x5)
The MPQ5613D-AEC1 is an integrated power supply for an automotive TFT LCD bias. The device integrates a boost converter, a synchronous buck-boost inverter, an adjustable positive charge pump output, and an adjustable negative charge pump output for the gate voltages. It also includes a VCOM buffer and gate voltage shaping function to minimize the external components. The MPQ5613D-AEC1 is designed to power TFT LCD panels from a regulated 3.3V or 5V supply, or the 12V battery directly.
The VDDP can output a maximum 21.8V voltage, the VDDN can output a minimum -16.6V negative voltage, the VGH can output a maximum 35V voltage, and the VGL can output a minimum -15.9V negative voltage.
The I2C interface and configurable power-on sequences for VDDP, VDDN, VGH, and VGL make the IC suitable for different applications.
An internal soft-start function prevents input overload at start-up. The cycle-by-cycle current-limit protection for SWP and SWN reduces component stress.
Robust protections are designed to guarantee safe operation of the device. Protection modes include input under-voltage lockout (UVLO), cycle-by-cycle current-limit protection for SWP and SWN, over-temperature protection (OTP), under-voltage protection (UVP) for VDDP, VDDN, VGH, and VGL, output over-current protection (OCP) for VCOM, and output current-limit protection for VDDP.
The MPQ5613D-AEC1 is available in a tiny QFN-28 (4mmx5mm) package. It is available in AEC-Q100 Grade 1.
- 2.7 to 12V Operating Input Voltage (VIN) Range
- 2A Current Limit for Boost Converter
- 2.5A Current Limit for Sync-Buck-Boost Inverter
- 250mΩ Low-Side MOSFET (LS-FET) for Boost, 200mΩ High-Side MOSFET (HS-FET), and 250mΩ LS-FET for Sync Buck-Boost
- I2C Interface, One-Time Programmable (OTP) Memory for Registers
- Configurable Switching Frequency (fSW) Up to 3MHz and Spread Spectrum for Better EMI
- Frequency Synchronization and Interleave (180°) Buck-Boost and Boost Control for Better EMI
- Input and Output Disconnection
- Configurable VDDP: 2.7V to 21.8V
- Configurable VDDN: -0.7V to -16.6V
- VDDP and VDDN Support Max 500mA of Continuous Load Current (Limited by the Cycle-by-Cycle Current-Limit Protection)
- Configurable VGH: 5V to 35V, 50mA
- Configurable VGL: 0V to -15.9V, 50mA
- Configurable VCOM Buffer: VDDN + 2V to VDDP - 2V, 25mA
- Gate Voltage Shaping with Configurable Falling Time and Minimum Level
- High Efficiency
- Configurable Power-On/Off Sequence
- VIN Under-Voltage Lockout (UVLO)
- Under-Voltage Protection (UVP) for VDDP, VDDN, VGH, and VGL
- Cycle-by-Cycle Current-Limit Protection for SWP and SWN
- Over-Temperature Protection (OTP), Output Over-Current Protection (OCP) for VCOM
- Output Current-Limit Protection for VDDP
- Fault Flag
- Available in AEC-Q100 Qualified Grade 1
- Available in a QFN-28 (4mmx5mm) Package
MPQ5613DGVE-xxxx-AEC1-Z MPQ5613DGVE-xxxx-AEC1-P MPQ5613DGVE-0000-AEC1-Z MPQ5613DGVE-0000-AEC1-P
MPQ5613D-AEC1 Resources
LCDバイアス電源製品カテゴリ -
MPQ5613B製品I2CおよびVCOMバッファ付き、車載用LCD TFTバイアスドライバ
MPQ5613C製品I2C付き車載用TFT LCDバイアスドライバ、AEC-Q100認定
MPQ1530-AEC1製品AEC-Q100認定、TFTバイアス用、トリプル出力、昇圧型コンバータおよびリニアレギュレータ
MP1531製品TFTバイアス用、低消費電力、トリプル出力、昇圧型コンバータおよびチャージポンプ
MP1530製品TFTバイアス用、トリプル出力昇圧型コンバータおよびリニアレギュレータ
MPQ1530製品産業グレード、TFTバイアス用、トリプル出力、昇圧型コンバータおよびリニアレギュレータ
MP5610製品スマートフォンおよびタブレット用、2.7V~5.5Vin、1.2MHz、デュアルチャネルLCDバイアス電源
MPQ6609A-AEC1製品32V, 1A, Stepper Motor Driver, AEC-Q100 Qualified
MPQ3368-AEC1製品8-Channel, Max 200mA/Channel, Boost WLED Controller with 10000:1 Dimming Ratio and I2C, AEC-Q100 Qualified
MPQ20088-AEC1製品40V, 500mA, High-Precision, High PSRR, Adjustable Output Linear Regulator, AEC-Q100 Qualified
MPQ3321A-AEC1製品48-Channel, Max 80mA/Channel, Current-Source LED Driver with Independent Analog and PWM Dimming, AEC-Q100 Qualified
MPQ7936-AEC1製品5V PMIC with 4 Buck Converters (2A/2.5A/4.5A/4.5A), 4 LDOs, and Flexible System Settings via the I2C and MOTP, AEC-Q100 Qualified
MPQ2923U-AEC1製品36V, 2.2MHz, Low-IQ Buck Controller with Multi-Phase, AEC-Q100 Qualified
MPQ7907-AEC1製品MPSafeTM-Compatible PMIC, 5.5V, 5 Bucks and 4 LDOs with User-Configurable State Machine, AEC-Q100 Qualified
MPQ8878-AEC1製品36V, 10A, Four-Switch, Synchronous Buck-Boost Converter with ZDPTM, AEC-Q100 Qualified
MP4334製品36V, 0.5A to 4A, Low Quiescent Current, Synchronous Step-Down Converter
