- Products
- Power Management
- Display Power and Control
- LCD Bias Supplies
- MPQ5613D-AEC1
MPQ5613D-AEC1
Automotive TFT LCD Bias Driver with Gate Voltage Shaping and VCOM Buffer, AEC-Q100 Qualified
- Vin (min) (V)2.7
- Vin (max) (V)12
- GradeAutomotive
- Package (mm)QFN-28 (4x5)
The MPQ5613D-AEC1 is an integrated power supply for an automotive TFT LCD bias. The device integrates a boost converter, a synchronous buck-boost inverter, an adjustable positive charge pump output, and an adjustable negative charge pump output for the gate voltages. It also includes a VCOM buffer and gate voltage shaping function to minimize the external components. The MPQ5613D-AEC1 is designed to power TFT LCD panels from a regulated 3.3V or 5V supply, or the 12V battery directly.
The VDDP can output a maximum 21.8V voltage, the VDDN can output a minimum -16.6V negative voltage, the VGH can output a maximum 35V voltage, and the VGL can output a minimum -15.9V negative voltage.
The I2C interface and configurable power-on sequences for VDDP, VDDN, VGH, and VGL make the IC suitable for different applications.
An internal soft-start function prevents input overload at start-up. The cycle-by-cycle current-limit protection for SWP and SWN reduces component stress.
Robust protections are designed to guarantee safe operation of the device. Protection modes include input under-voltage lockout (UVLO), cycle-by-cycle current-limit protection for SWP and SWN, over-temperature protection (OTP), under-voltage protection (UVP) for VDDP, VDDN, VGH, and VGL, output over-current protection (OCP) for VCOM, and output current-limit protection for VDDP.
The MPQ5613D-AEC1 is available in a tiny QFN-28 (4mmx5mm) package. It is available in AEC-Q100 Grade 1.
- 2.7 to 12V Operating Input Voltage (VIN) Range
- 2A Current Limit for Boost Converter
- 2.5A Current Limit for Sync-Buck-Boost Inverter
- 250mΩ Low-Side MOSFET (LS-FET) for Boost, 200mΩ High-Side MOSFET (HS-FET), and 250mΩ LS-FET for Sync Buck-Boost
- I2C Interface, One-Time Programmable (OTP) Memory for Registers
- Configurable Switching Frequency (fSW) Up to 3MHz and Spread Spectrum for Better EMI
- Frequency Synchronization and Interleave (180°) Buck-Boost and Boost Control for Better EMI
- Input and Output Disconnection
- Configurable VDDP: 2.7V to 21.8V
- Configurable VDDN: -0.7V to -16.6V
- VDDP and VDDN Support Max 500mA of Continuous Load Current (Limited by the Cycle-by-Cycle Current-Limit Protection)
- Configurable VGH: 5V to 35V, 50mA
- Configurable VGL: 0V to -15.9V, 50mA
- Configurable VCOM Buffer: VDDN + 2V to VDDP - 2V, 25mA
- Gate Voltage Shaping with Configurable Falling Time and Minimum Level
- High Efficiency
- Configurable Power-On/Off Sequence
- VIN Under-Voltage Lockout (UVLO)
- Under-Voltage Protection (UVP) for VDDP, VDDN, VGH, and VGL
- Cycle-by-Cycle Current-Limit Protection for SWP and SWN
- Over-Temperature Protection (OTP), Output Over-Current Protection (OCP) for VCOM
- Output Current-Limit Protection for VDDP
- Fault Flag
- Available in AEC-Q100 Qualified Grade 1
- Available in a QFN-28 (4mmx5mm) Package
MPQ5613DGVE-xxxx-AEC1-Z MPQ5613DGVE-xxxx-AEC1-P MPQ5613DGVE-0000-AEC1-Z MPQ5613DGVE-0000-AEC1-P
MPQ5613D-AEC1 Resources
LCD BIAS SUPPLIESPRODUCT CATEGORY -
MPQ5613BPRODUCTAutomotive LCD TFT Bias Driver with I2C and VCOM Buffer
MPQ5613CPRODUCTAutomotive TFT LCD Bias Driver with I2C, AEC-Q100 Qualified
MPQ1530-AEC1PRODUCTTriple Outputs Boost Plus Linear Regulators for TFT Bias with AEC-Q100 qualification
MP1531PRODUCTLow Power Triple Outputs Boost Plus Charge Pumps for TFT Bias
MP1530PRODUCTTriple Outputs Boost Plus Linear Regulators for TFT Bias
MPQ1530PRODUCTIndustrial Grade, Triple Outputs Boost Plus Linear Regulators for TFT Bias
MP5610PRODUCT2.7V-5.5Vin, 1.2MHz, Dual Channel LCD Bias Supply for Smart Phone and Tablet
FILTERING HIGH-FREQUENCY INTERFERENCE IN STEP-DOWN CONVERTER DESIGNS WITH HOT-LOOP COMPONENTSARTICLEModern step-down converters are becoming increasingly efficient. In the frequency range of several hundred MHz, step-down converters can emit higher levels of interference. New IC designs and clever layouts are already able to compensate for such disturbances. By implementing high-frequency ferrite beads, interferences can be further effectively eliminated. In this article, an automotive expert d...
MPQ6609A-AEC1PRODUCT32V, 1A, Stepper Motor Driver, AEC-Q100 Qualified
MPQ3368-AEC1PRODUCT8-Channel, Max 200mA/Channel, Boost WLED Controller with 10000:1 Dimming Ratio and I2C, AEC-Q100 Qualified
MPQ3321A-AEC1PRODUCT48-Channel, Max 80mA/Channel, Current-Source LED Driver with Independent Analog and PWM Dimming, AEC-Q100 Qualified
MPQ5895-AEC1PRODUCT60V Load Dump, 3A, Dual-Channel, Smart High-Side Switch, AEC-Q100 Qualified
MPQ7936-AEC1PRODUCT5V PMIC with 4 Buck Converters (2A/2.5A/4.5A/4.5A), 4 LDOs, and Flexible System Settings via the I2C and MOTP, AEC-Q100 Qualified
MPQ2923U-AEC1PRODUCT36V, 2.2MHz, Low-IQ Buck Controller with Multi-Phase, AEC-Q100 Qualified
MPQ7907-AEC1PRODUCTMPSafeTM-Compatible PMIC, 5.5V, 5 Bucks and 4 LDOs with User-Configurable State Machine, AEC-Q100 Qualified
MPQ8878-AEC1PRODUCT36V, 10A, Four-Switch, Synchronous Buck-Boost Converter with ZDPTM, AEC-Q100 Qualified
MP4334PRODUCT36V, 0.5A to 4A, Low Quiescent Current, Synchronous Step-Down Converter
