- 車載用IC (AECQ グレード)
- AECQ対応スイッチングコンバータとコントローラ
- ステップダウンコントローラ
- MPQ2933-AEC1
MPQ2933-AEC1
- Regulated Outputs2
- 入力電圧(最小) (V)3.6
- 入力電圧 (最大) (V)36
- Iout (max) (A)40
- fsw(最大)(kHz)2200
- Iq (typ) (mA)0.04
- Vfb (V)1.2
- PGYes
- SSExternal
- Max Duty Cycle (%)99
- パッケージ(mm)QFN-38 (5x8)
- グレードAutomotive
The MPQ2933-AEC1 is a highly efficient, current-mode, synchronous buck controller with a wide input voltage (VIN) range. The wide 3.6V to 36V VIN range makes the device well-suited for multi-purpose automotive and industrial applications.
The MPQ2933-AEC1 uses pulse-width modulation (PWM) current control architecture with accurate cycle-by-cycle current limiting and can drive dual N-channel MOSFETs. Advanced asynchronous modulation (AAM) mode enables nonsynchronous operation to optimize light-load efficiency.
The switching frequency (fSW) is resistor-configurable between 200kHz and 2.2MHz. The MPQ2933-AEC1 can also be synchronized to an external clock. Configurable frequency spread spectrum (FSS) improves EMI performance.
An open-drain power good (PG) signal indicates whether the output is within 94% to 106% of its nominal voltage.
Full protection features include precision output over-voltage protection (OVP), input over-voltage protection (OVP), output over-current protection (OCP), and thermal shutdown.
The MPQ2933-AEC1 is available in a QFN-38 (5mmx8mm) package.
- Supports 42V Load Dump
- Supports 6V Warm Crank
- Dual-Channel or Single-Output Multi-Phase
- Junction Temperature (TJ) Operation from -40°C to +150°C
- Increases Battery Life:
- 2.2μA Low Shutdown Current for One Channel
- 20μA Sleep Mode Quiescent Current (IQ) for One Channel
- High performance for Improved Thermals:
- Gate Driver Pull-Up Strength
- Gate Driver Pull-Down Strength
- Optimized for EMC/EMI:
- 200kHz to 2.2MHz Configurable Switching Frequency (fSW)
- External Clock Synchronization
- Additional Features:
- Synchronization Clock Output
- Power Good (PG) Output
- External Soft Start (SS)
- Output Short-Circuit Protection (SCP)
- Available in a QFN-38 (5mmx8mm) Package with Wettable Flanks
- MPSafeTM-Compatible: Functional Safety Supporting Document Available
MPQ2933GRYE-AEC1-Z MPQ2933GRYE-AEC1-P
MPQ2933-AEC1 Resources
フロントカメラ(同軸)アプリケーション -
ステップダウンコントローラ製品カテゴリ -
MPQ2923U-AEC1製品36V, 2.2MHz, Low-IQ Buck Controller with Multi-Phase, AEC-Q100 Qualified
MPQ5823A-AEC1製品36V, High-Efficiency Battery Voltage Limiter, AEC-Q100 Qualified
MPQ2923-AEC1製品42V、2.2MHz、低自己消費電流 降圧型コントローラ、マルチフェーズ機能、AEC-Q100認定
MPQ2908A-AEC1製品車載グレード 4V~60V 入力、電流モード、同期整流ステップダウンコントローラ
MPQ2918-AEC1製品車載グレード 4V~40V入力、電流モード、同期整流式ステップダウンコントローラ
MPQ9934-AEC1製品80V入力、30A、ダイナミック電圧調整機能付き同期整流降圧型コントローラ、AEC-Q100認定
マルチフェーズ電源設計用のカレントシェアリングシステムの設計方法寄稿文未来の車は、ラップアラウンド式スクリーンや多数のスピーカーを備えた車輪上のオーディオビジュアル・ワンダーランドになると思われています。未来の道路での運転では、超高速の5Gを通じてストリーミングされるコンテンツにより、乗客は信じられないような感覚の体験に浸れます。コンテンツが豊富で接続性が重視される未来のモビリティのパラダイムを実現するために、新しいデジタルコックピット・システムには、飛躍的にすぐれたコンピューティング能力が求め続けられています。これらのコンピューティング要件の高まりは、結果として、より大電力を要求することへとつながります。 そのため、電磁両立性を向上しながらより高い負荷電流を供給できる、インターリーブトポロジーの人気が高まっています。ただし、エンジニアは、これらの車載用電源管理システムを設計する際に、熱、ボードサイズ、およびコストのバランスを最適化する必要があります。特に...
