MPQ2933-AEC1
- Regulated Outputs2
- Vin (min) (V)3.6
- Vin (max) (V)36
- Iout (max) (A)40
- fsw (max) (kHz)2200
- Iq (typ) (mA)0.04
- Vfb (V)1.2
- PGYes
- SSExternal
- Max Duty Cycle (%)99
- Package (mm)QFN-38 (5x8)
- GradeAutomotive
The MPQ2933-AEC1 is a highly efficient, current-mode, synchronous buck controller with a wide input voltage (VIN) range. The wide 3.6V to 36V VIN range makes the device well-suited for multi-purpose automotive and industrial applications.
The MPQ2933-AEC1 uses pulse-width modulation (PWM) current control architecture with accurate cycle-by-cycle current limiting and can drive dual N-channel MOSFETs. Advanced asynchronous modulation (AAM) mode enables nonsynchronous operation to optimize light-load efficiency.
The switching frequency (fSW) is resistor-configurable between 200kHz and 2.2MHz. The MPQ2933-AEC1 can also be synchronized to an external clock. Configurable frequency spread spectrum (FSS) improves EMI performance.
An open-drain power good (PG) signal indicates whether the output is within 94% to 106% of its nominal voltage.
Full protection features include precision output over-voltage protection (OVP), input over-voltage protection (OVP), output over-current protection (OCP), and thermal shutdown.
The MPQ2933-AEC1 is available in a QFN-38 (5mmx8mm) package.
- Supports 42V Load Dump
- Supports 6V Warm Crank
- Dual-Channel or Single-Output Multi-Phase
- Junction Temperature (TJ) Operation from -40°C to +150°C
- Increases Battery Life:
- 2.2μA Low Shutdown Current for One Channel
- 20μA Sleep Mode Quiescent Current (IQ) for One Channel
- High performance for Improved Thermals:
- Gate Driver Pull-Up Strength
- Gate Driver Pull-Down Strength
- Optimized for EMC/EMI:
- 200kHz to 2.2MHz Configurable Switching Frequency (fSW)
- External Clock Synchronization
- Additional Features:
- Synchronization Clock Output
- Power Good (PG) Output
- External Soft Start (SS)
- Output Short-Circuit Protection (SCP)
- Available in a QFN-38 (5mmx8mm) Package with Wettable Flanks
- MPSafeTM-Compatible: Functional Safety Supporting Document Available
MPQ2933GRYE-AEC1-Z MPQ2933GRYE-AEC1-P
MPQ2933-AEC1 Resources
HEAD UNITS (MID-RANGE)APPLICATIONAutomotive head unit designs have evolved from the traditional hardware interfaces into sophisticated infotainment systems that offer various in-cabin functionalities. These features include navigation, wireless connections, passenger entertainment, gesture recognition, and voice control. As consumer expectations for infotainment features continue to increase, manufacturers face design challenges ...
STEP-DOWN CONTROLLERSPRODUCT CATEGORY -
MPQ2923U-AEC1PRODUCT36V, 2.2MHz, Low-IQ Buck Controller with Multi-Phase, AEC-Q100 Qualified
MPQ5823A-AEC1PRODUCT36V, High-Efficiency Battery Voltage Limiter, AEC-Q100 Qualified
MPQ2923-AEC1PRODUCT42V, 2.2MHz, Low-IQ Buck Controller with Multi-Phase Capability, AEC-Q100 Qualified
MPQ2908A-AEC1PRODUCTAutomotive Grade. 4V-60V Input, Current Mode, Synchronous Step-Down Controller
MPQ2918-AEC1PRODUCTAutomotive Grade. 4V-40V Input, Current Mode, Synchronous Step-Down Controller
MPQ9934-AEC1PRODUCT80V Input, 30A, Synchronous Buck Controller with Dynamic Voltage Adjustment, AEC-Q100 Qualified
HOW TO DESIGN A THERMALLY BALANCED CURRENT-SHARING SYSTEM FOR MULTI-PHASE POWER DESIGNSARTICLEThe car of tomorrow is envisioned to be an audiovisual wonderland on wheels, including wraparound screens and dozens of speakers. Driving on the road in the future will immerse passengers in an incredible sensory experience with content streamed via ultra-fast 5G. To achieve this content-rich, connectivity-heavy paradigm of future mobility, emerging digital cockpit systems continue to demand expon...
REFERENCE DESIGN
ZYNQ ULTRASCALE+ U4EG/U5EG/U7EG ADAS CENTRAL COMPUTE ENGINE POWER REFERENCE DESIGNREFERENCE DESIGN
