MPQ2923-AEC1
42V, 2.2MHz, Low-IQ Buck Controller with Multi-Phase Capability, AEC-Q100 Qualified
- Regulated Outputs1
- Vin (min) (V)3.6
- Vin (max) (V)36
- Iout (max) (A)20
- fsw (max) (kHz)2200
- Iq (typ) (mA)0.02
- Vfb (V)1.2
- PGYes
- SSExternal
- Max Duty Cycle (%)99
- Package (mm)QFN-24 (4x4)
- GradeAutomotive
The MPQ2923-AEC1 is a highly efficient, current-mode, synchronous buck controller with a wide input voltage (VIN) range. The wide 3.6V to 36V VIN range makes the device well-suited for multi-purpose automotive and industrial applications, and the VBIAS pin allows for operation under cold-crank conditions if a regulated 5V supply is available.
The MPQ2923-AEC1 uses pulse-width modulation (PWM) current control architecture with accurate cycle-by-cycle current limiting and is capable of driving dual N-channel MOSFETs. Advanced asynchronous modulation (AAM) mode enables nonsynchronous operation to optimize light-load efficiency.
The switching frequency (fSW) is resistor-configurable between 200kHz and 2.2MHz. The MPQ2923-AEC1 can also be synchronized to an external clock. Configurable frequency spread spectrum (FSS) improves EMI performance.
An open-drain power good (PG) signal indicates whether the output is within 94% to 106% of its nominal voltage.
Full protection features include precision output over-voltage protection (OVP), input OVP, output over-current protection (OCP), and thermal shutdown.
The MPQ2923-AEC1 is available in a QFN-24 (4mmx4mm) package, and is available in AEC-Q100 Grade 1.
- Supports 42V Load Dump
- Supports >0V Cold Crank (with External VBIAS)
- Supports 6V Warm Crank
- Junction Temperature (TJ) Operation from -40°C to +150°C
- Increases Battery Life:
- 2.2μA Low Shutdown Current
- 20μA Sleep-Mode Quiescent Current (IQ)
- High Performance for Improved Thermals:
- 3Ω Gate Driver Pull-Up Strength
- 1.5Ω Gate Driver Pull-Down Strength
- Multi-Phase Capability
- Optional External VBIAS
- Optimized for EMC/EMI:
- 200kHz to 2.2MHz Configurable Switching Frequency (fSW)
- External Clock Synchronization
- Additional Features:
- Synchronization Clock Output
- Power Good (PG) Output
- External Soft Start (SS)
- Output Short-Circuit Protection (SCP)
- Available in a QFN-24 (4mmx4mm) Package with Wettable Flanks
- MPSafeTM QM - Documentation Available
MPQ2923GRE-xxxx-AEC1-Z MPQ2923GRE-xxxx-AEC1-P MPQ2923GRE-0000-AEC1-Z MPQ2923GRE-0000-AEC1-P MPQ2923GRE-0001-AEC1-Z MPQ2923GRE-0001-AEC1-P
MPQ2923-AEC1 Resources
HEAD UNITS (MID-RANGE)APPLICATIONAutomotive head unit designs have evolved from the traditional hardware interfaces into sophisticated infotainment systems that offer various in-cabin functionalities. These features include navigation, wireless connections, passenger entertainment, gesture recognition, and voice control. As consumer expectations for infotainment features continue to increase, manufacturers face design challenges ...
STEP-DOWN CONTROLLERSPRODUCT CATEGORY -
MPQ2923U-AEC1PRODUCT36V, 2.2MHz, Low-IQ Buck Controller with Multi-Phase, AEC-Q100 Qualified
MPQ5823A-AEC1PRODUCT36V, High-Efficiency Battery Voltage Limiter, AEC-Q100 Qualified
MPQ2933-AEC1PRODUCT36V, 2.2MHz, Low-IQ Buck Controller with Multiple Phases, AEC-Q100 Qualified
MPQ2908A-AEC1PRODUCTAutomotive Grade. 4V-60V Input, Current Mode, Synchronous Step-Down Controller
MPQ2918-AEC1PRODUCTAutomotive Grade. 4V-40V Input, Current Mode, Synchronous Step-Down Controller
MPQ9934-AEC1PRODUCT80V Input, 30A, Synchronous Buck Controller with Dynamic Voltage Adjustment, AEC-Q100 Qualified
HOW TO DESIGN A THERMALLY BALANCED CURRENT-SHARING SYSTEM FOR MULTI-PHASE POWER DESIGNSARTICLEThe car of tomorrow is envisioned to be an audiovisual wonderland on wheels, including wraparound screens and dozens of speakers. Driving on the road in the future will immerse passengers in an incredible sensory experience with content streamed via ultra-fast 5G. To achieve this content-rich, connectivity-heavy paradigm of future mobility, emerging digital cockpit systems continue to demand expon...
REFERENCE DESIGN
ZYNQ ULTRASCALE+ U4EG/U5EG/U7EG ADAS CENTRAL COMPUTE ENGINE POWER REFERENCE DESIGNREFERENCE DESIGN
