- MPQ9934-AEC1
MPQ9934-AEC1
- Regulated Outputs1
- Vin (min) (V)7
- Vin (max) (V)80
- Iout (max) (A)30
- fsw (max) (kHz)1000
- Iq (typ) (mA)0.4
- Vfb (V)0.17 to 1.6
- PGYes
- SSExternal
- Max Duty Cycle (%)99
- Package (mm)QFN-23 (4x4)
- GradeAutomotive
- Vout (max) (V)80
- Vout (min) (V)0.5
- Control ModeCOT Control
The MPQ9934-AEC1 is a high-voltage, synchronous, step-down switching regulator controller that can directly step down voltages from 80V. It integrates the gate driver of two N-channel MOSFETs for high-side (HS) and low-side (LS) switches, which can be used for high-power applications.
The MPQ9934-AEC1's adaptive constant-on-time (COT) control architecture provides fast transient response and eases loop stabilization. The DC auto-tune loop provides excellent load and line regulation. In addition, the device can support dynamic output voltage (VOUT) adjustments through the VSELx pins with ramping up and ramping down slew rate control.
The 100kHz to 1MHz switching frequency (fSW) can be configured via an external resistor for different system requirements. The MPQ9934-AEC1 offers a configurable soft start (SS) via an external SS capacitor.
Available fault protections include precision output over-voltage protection (OVP), output over-current protection (OCP), and thermal shutdown.
The MPQ9934-AEC1 is available in a QFN-23 (4mmx4mm) package with wettable flanks, and is available in AEC-Q100 Grade 1.
- 7V to 80V Input Voltage (VIN) Range
- Up to 80V Output Voltage (VOUT) Range
- Configurable 0.17V to 1.6V FB Reference Voltage Range
- 30A of Output Current (IOUT)
- Low-Dropout Operation: 99% Maximum Operation Duty Cycle
- Selectable Pulse-Skip Mode (PSM)/Forced Continuous Conduction Mode (FCCM) via the MODE Pin
- Configurable 100kHz to 1000kHz Switching Frequency (fSW) with Spread Spectrum Function
- Biased VDRV via External Power Supply to Improve Efficiency
- Lossless Low-Side On Resistance (RDS(ON)) or Shunt Current-Sensing
- Constant-On-Time (COT) Control Offers Fast Load Transient Response
- 10V N-Channel MOSFET Gate Driver Capability, with 4.2A Source and 5.2A Sink Capability
- Supports Line-Drop Compensation
- Dynamic Output Transition (VSELx) with Slew Rate Control
- Configurable Valley Current Limit via ILIM
- Output Passive Discharge Function
- Output Over-Current Protection (OCP)/Short-Circuit Protection (SCP), Output Over-Voltage Protection (OVP), and Over-Temperature Protection (OTP)
- Power Good (PG) Indicator
- Available in a QFN-23 (4mmx4mm) Package with Wettable Flanks
MPQ9934GRE-AEC1-Z MPQ9934GRE-AEC1-P
MPQ9934-AEC1 Resources
USB PD POWER STAGEPRODUCT CATEGORY -
HEAD UNITS (MID-RANGE)APPLICATIONAutomotive head unit designs have evolved from the traditional hardware interfaces into sophisticated infotainment systems that offer various in-cabin functionalities. These features include navigation, wireless connections, passenger entertainment, gesture recognition, and voice control. As consumer expectations for infotainment features continue to increase, manufacturers face design challenges ...
USB TYPE-C POWER DELIVERYAPPLICATIONUSB Type-C power delivery (PD) is gaining popularity across applications and markets, including in automotive. USB ports have become an expected standard in most car models, and are typically expected to offer both charging and data functionality. USB Type-C improves on older USB designed by offering a smaller, reversible port for easy plug-in and double the transfer speed of USB 3.0. USB PD proto...
STEP-DOWN CONTROLLERSPRODUCT CATEGORY -
MPQ2923U-AEC1PRODUCT36V, 2.2MHz, Low-IQ Buck Controller with Multi-Phase, AEC-Q100 Qualified
MPQ5823A-AEC1PRODUCT36V, High-Efficiency Battery Voltage Limiter, AEC-Q100 Qualified
MPQ2933-AEC1PRODUCT36V, 2.2MHz, Low-IQ Buck Controller with Multiple Phases, AEC-Q100 Qualified
MPQ4232A-AEC1PRODUCT36V, 6A Buck-Boost Converter with Four Integrated MOSFETs and I2C Interface, AEC-Q100 Qualified
MPQ8887-AEC1PRODUCT65V, 9A, High-Efficiency Buck Converter with I2C Interface, Configurable Frequency, and Adjustable OCP, AEC-Q100 Qualified
MPQ5038-AEC1PRODUCTUSB PD Source Controller with 7 Configurable PDOs and Load-Shedding, AEC-Q100 Qualified
MPQ8880A-AEC1PRODUCT60V, 4.5A, High-Efficiency, Digital, Configurable, Synchronous Step-Down Converter with PMBus Interface, AEC-Q100 Qualified
MPQ2923-AEC1PRODUCT42V, 2.2MHz, Low-IQ Buck Controller with Multi-Phase Capability, AEC-Q100 Qualified
