- 車載用IC (AECQ グレード)
- AECQ対応スイッチングコンバータとコントローラ
- ステップダウンコンバータ
- MPQ2279-AEC1
MPQ2279-AEC1
6V, Dual 3A/3A, 2.5MHz, Synchronous Step-Down Converter with Power Good and Soft Start, AEC-Q100 Qualified
- 入力電圧(最小) (V)2.5
- 入力電圧 (最大) (V)6
- Iout (max) (A)3
- Iq (typ) (mA)0.93
- Vfb (V)0.6
- fsw(最大)(kHz)2500
- Control ModeCOT Control
- パッケージ(mm)QFN-16 (2.5x3.5)
- グレードAutomotive
The MPQ2279-AEC1 is a monolithic, dual, step-down switch-mode converter with built-in internal power MOSFETs. The device achieves 3A/3A of output current (IOUT) from a 2.5V to 6V input voltage (VIN) range, with excellent load and line regulation. The output voltage (VOUT) can be regulated to as low as 0.6V.
Constant-on-time (COT) control provides fast transient response and eases loop stabilization. Fault protections include cycle-by-cycle current limiting and thermal shutdown.
The MPQ2279-AEC1 is ideal for a wide range of applications, including automotive infotainment systems, clusters, and telematics.
The MPQ2279-AEC1 requires a minimal number of readily available, standard external components, and is available in a QFN-16 (2.5mmx3.5mm) package.
- Wide 2.5V to 6V Operating Input Voltage (VIN) Range
- 3A/3A Continuous Output Current (IOUT)
- 1% Feedback (FB) Accuracy
- Operation Junction Temperature (TJ) from -40°C to +150°C
- High Performance for Improved Thermals:
- Integrated, Low-Resistance High-Side and Low-Side MOSFETs (HS-FETs and LS-FETs, Respectively)
- Optimized for EMC and EMI Reduction:
- 2.5MHz Switching Frequency (fSW)
- Forced Continuous Conduction Mode (FCCM) Across the Full Load Range
- Optimized for Board Size and BOM:
- Integrated Compensation Network
- Additional Features:
- Enable (EN) for Power Sequencing
- Power Good (PG) Indicators
- 100% Duty On
- External Soft-Start (SS) Control
- Output Discharge
- Short-Circuit Protection (SCP) with Hiccup Mode
- Available in a QFN-16 (2.5mmx3.5mm) Package
- Available with a Wettable-Flank Package
- MPSafeTM Compatible – Functional Safety Supporting Document Available
MPQ2279GRHE-AEC1-Z MPQ2279GRHE-AEC1-P
MPQ2279-AEC1 Resources
オンボードチャージャモジュール (OBCM)アプリケーション電気自動車 (EV) は日々存在感を増しており、EVの選択は指数関数的な速度で増加しています。オンボード充電 (OBC) は、ACチャージャが車両に接続されている間に可能な最大充電率を決定するため、EVの非常に重要な部分です。完全電気自動車の最大充電能力は通常6.6kW~22kWで、プラグインハイブリッド車の場合は通常3.3kW~7.2kWです。 MPSの車載グレードの絶縁型ソリューションの多数の製品一覧には、絶縁型ゲートドライバ、絶縁型ゲートドライバ電源、デジタルアイソレータ、ホール効果電流センサ、および非絶縁型DC/DCコンバータが含まれます。MPSのソリューションは、高いCMTIと磁気ノイズ耐性のために容量性絶縁を採用することにより、最も厳しい大電力仕様を満たすように設計されています。 MPSの強固な絶縁ソリューションは、次世代のオンボードチャージャに電力を供給す...
DC急速充電ステーションアプリケーション電気自動車の導入の増加に伴い、DC急速充電ステーションがより一般的になってきています。充電ステーションは、主要幹線道路や人口の多い郊外にあるインフラストラクチャの重要な部分であり、電気自動車が長距離移動中や日常の運転中に充電できる場所を確保します。これらのシステムは多くの場合、複数の25kW~75kWモジュールで構成され、150kW~400kWの電力を供給する急速充電システムを構築し、電気自動車のバッテリーを10%~90%まで20分という速さで充電できます。 MPSの絶縁型ソリューションの多数の製品一覧には、絶縁型ゲートドライバ、絶縁型ゲートドライバ電源、デジタルアイソレータ、ホール効果電流センサ、および非絶縁型DC/DCコンバータが含まれます。これらの部品は、SiCとIGBTの両方のバイアスおよび駆動に使用できるだけでなく、トランスをチップスケールのパッケージに統合することで高...
ステップダウンコンバータ製品カテゴリ -
MPQ2277A-AEC1製品6V, Dual 1A/1A, AAM Mode, 2.5MHz, Synchronous Step-Down Converter with Power Good and Soft Start, AEC-Q100 Qualified
MPQ2183-AEC1製品6V、1A~3A、2.4MHz、周波数スペクトラム拡散付き同期整流ステップダウンコンバータ、AEC-Q100認定済み
MPQ2279A-AEC1製品6V, Dual 3A/3A, AAM Mode, 2.5MHz, Synchronous Step-Down Converter with Power Good and Soft Start, AEC-Q100 Qualified
MPQ4110-AEC1製品20V、0.5A~1A、低静止電流、同期整流ステップダウンコンバータ、AEC-Q100認定済み
MPQ2294-AEC1製品6V, 30A, Synchronous Buck Converter with ZDPTM, AEC-Q100 Qualified
MPQ4373-AEC1製品36V, 6A to 11A, Low-EMI, Synchronous Step-Down Converter with ZDPTM, AEC-Q100 Qualified
MPQ4583-AEC1製品90V, 3.5A, 9μA IQ, Synchronous Step-Down DC/DC Converter, AEC-Q100 Qualified
MPQ4384-AEC1製品36V, 12A to 18A, Low-EMI, Synchronous Step-Down Converter with ZDPTM, AEC-Q100 Qualified
