MPQ7902-AEC1
45V Power Management IC with 2 Bucks, 1 Boost, and Flexible System Settings via the SPI, AEC-Q100 Qualified
- Regulated Outputs3
- Vin (min) (V)4.5
- Vin (max) (V)42
- Iout (max) (A)3
- Package (mm)QFN-34 (6x6)
- Step-Down DC/DC Controller0
- Step-Down DC/DC Converter2
- Step-Up DC/DC Controller0
- Step-Up DC/DC Converter1
- Internal LDO0
- Iq (typ) (mA)0.38
- fsw (max) (kHz)2500
- Step-Down Converter Current (A)3, 2
- Vfb (V)0.85, 0.65, 0.85
- PGYes
- SSInternal
- GradeAutomotive
The MPQ7902-AEC1 is a power management IC (PMIC) with abundant protection features for automotive applications. It consists of a high-voltage (HV) primary synchronous buck converter, a low-voltage (LV) secondary synchronous buck converter, and a synchronous boost converter with excellent transient response and high efficiency.
Full protection features include under-voltage lockout (UVLO), over-current protection (OCP), over-voltage protection (OVP), and thermal shutdown.
The MPQ7902-AEC1 implements a configurable watchdog with window and Q&A modes. In addition, different configurations can be easily obtained via the serial peripheral interface (SPI). The one-time programmable (OTP) memory allows the desired settings to be permanently stored. SPI transactions are protected using cyclic redundancy check (CRC).
The MPQ7902-AEC1 is available in a QFN-34 (6mmx6mm) package, and is AEC-Q100 qualified.
- Built for Tough Automotive Transients:
- Load Dump Up to 45V
- Cold Crank Down to 4.5V
- Low Quiescent Current (IQ) and Shutdown Current (ISD)
- Reduces Board Size and BOM:
- High-Voltage (HV) Synchronous Buck Regulator:
- 3A Continuous Output Current (IOUT)
- Low-Voltage (LV) Synchronous Buck Regulator:
- 2A Continuous IOUT
- LV Synchronous Boost Regulator:
- 250mA Continuous IOUT
- Integrated and Adjustable Compensation Network
- Optimized for EMC/EMI:
- Frequency Synchronization Up to 2.5MHz
- Spread Spectrum for EMI Reduction
- CISPR 25 Class 5 Compliant
- Protections:
- Output Under-Voltage Protection (UVP)
- Thermal Warning and Shutdown
- Reset to Microcontroller Unit (MCU)
- Protected Memory and Registers
- Additional Features:
- Window or Q&A Watchdog
- Serial Peripheral Interface (SPI) with Cyclic Redundancy Check (CRC)
- Available in a QFN-34 (6mmx6mm) Package with Wettable Flanks
MPQ7902GQKTE-xxxx-AEC1-Z MPQ7902GQKTE-xxxx-AEC1-P MPQ7902GQKTE-0000-AEC1-Z MPQ7902GQKTE-0000-AEC1-P
MPQ7902-AEC1 Resources
PMICSPRODUCT CATEGORY -
MPQ70156FS-AEC1PRODUCTMPSafeTM, ASIL-B, 6V, 3A, PMIC with Buck Converter and 1-Channel Window Voltage Monitor, AEC-Q100 Qualified
MPQ7936-AEC1PRODUCT5V PMIC with 4 Buck Converters (2A/2.5A/4.5A/4.5A), 4 LDOs, and Flexible System Settings via the I2C and MOTP, AEC-Q100 Qualified
MPQ7907-AEC1PRODUCTMPSafeTM-Compatible PMIC, 5.5V, 5 Bucks and 4 LDOs with User-Configurable State Machine, AEC-Q100 Qualified
MPQ7929-AEC1PRODUCTMPSafeTM Compatible, 18V, 4-Channel PMIC with 3 Bucks, 1 LDO, and Uprated Current, AEC-Q100 Qualified
MPQ7932-AEC1PRODUCTMPSafeTM-Compatible, 5.5V PMIC with 6 Buck Converters, AEC-Q100 Qualified
MPQ70332FS-AEC1PRODUCT45V, 3A HV Buck, 2A LV Buck, 250mA LV Boost, ASIL-B PMIC, AEC-Q100 Qualified
MPQ70160FS-AEC1PRODUCTMPSafeTM ASIL-D, 5.5V, PMIC with 6 Buck Converters, AEC-Q100 Qualified
MPQ70333FS-AEC1PRODUCTMPSafeTM, 45V, 3A Buck and 250mA Boost ASIL-D PMIC, AEC-Q100 Qualified
MPQ7935-AEC1PRODUCT5.5V, 5-Channel PMIC with Four 1A Buck Converters and a 300mA LDO, I2C, and OTP, AEC-Q100 Qualified
MPQ4390-AEC1PRODUCT40V, High Current Output, Synchronous, Dual Buck Converter, AEC-Q100 Qualified
MPQ70171FS-AEC1PRODUCTMPSafeTM, ASIL-B, 5.5V PMIC with 5 Bucks and 4 LDOs for Safety-Relevant Applications, AEC-Q100 Qualified
MPQ7970-AEC1PRODUCTMPSafeTM-Compatible, 5.5V PMIC for SoCs, 5 LDOs, 4 GPIOs, and 2 Voltage Monitors, AEC-Q100 Qualified
MPQ7934-AEC1PRODUCTMPSafeTM-Compatible, 36V, 4-Channel PMIC with 3 Bucks and 1 LDO, AEC-Q100 Qualified
MPQ70244FS-AEC1PRODUCTMPSafeTM, ASIL-B, 18V, 4-Channel PMIC with 3 Bucks and 1 LDO, Enhanced PMBus Interface Logic, AEC-Q100 Qualified
MPQ70342FS-AEC1PRODUCTMPSafeTM ASIL-B, 36V, 3-Channel PMIC, AEC-Q100 Qualified
MPQ70341FS-AEC1PRODUCTMPSafeTM, ASIL-B, 36V, 4-Channel PMIC with 3 Bucks and 1 LDO, AEC-Q100 Qualified
MPQ70701FS-AEC1PRODUCTMPSafeTM ASIL-B, 5.5V PMIC for SoCs with 5 LDOs, 4 GPIOs, and 2 Voltage Monitors, AEC-Q100 Qualified
MPQ70241FS-AEC1PRODUCTMPSafeTM, 18V, 4-Channel PMIC with 3 Bucks and 1 LDO, ASIL-B Rated, AEC-Q100 Qualified
MPQ70430FS-AEC1PRODUCT65V, 3A HV Buck, 2A LV Buck, 250mA LV Boost, ASIL-D PMIC, AEC-Q100 Qualified
MPQ73351FS-AEC1PRODUCTMPSafeTM ASIL-D, 40V, High Output Current, Synchronous, Dual Buck Converter, AEC-Q100 Qualified
MPQ70166FS-AEC1PRODUCT5V PMIC with Six 1A/1A/1A/1A/2A/2A Buck Converters and Flexible System Settings via PMBus, AEC-Q100 Qualified
MPQ74201FS-AEC1PRODUCTMPSafeTM, ASIL-D, 2.7V to 5.5V, Quad 6A, Synchronous Buck Converters and Dual LDOs with I2C Interface, AEC-Q100 Qualified
MPQ7933-AEC1PRODUCTMPSafeTM-Compatible, 5.5V PMIC with 6 Buck Converters, AEC-Q100 Qualified
