- MPQ4233A-AEC1
MPQ4233A-AEC1
- Vin (min) (V)3
- Vin (max) (V)36
- Iout (max) (A)3
- Iq (typ) (mA)0.9, 0.13
- Vfb (V)0.33, 0.5, 2
- fsw (max) (kHz)1000
- Control ModeCurrent Mode
- Package (mm)QFN-19 (4x5)
- GradeAutomotive
- Isw Limit (typ) (A)9, 13.2
- Regulated Outputs1
- Vout (max) (V)24
- Vout (min) (V)1
The MPQ4233A-AEC1 is a synchronous, four-switch buck-boost converter with integrated MOSFETs. The device can deliver up to 3A of output current (IOUT) at certain input supply ranges with excellent efficiency.
The MPQ4233A-AEC1 is suitable for USB power delivery (PD) and wireless charging applications. It can work well with external PD or wireless charging controllers through the I2C interface.
The I2C interface and one-time programmable (OTP) memory provide flexibility for configurable parameters.
Fault condition protections include constant-current (CC) limiting, output and input over-voltage protection (OVP), and thermal shutdown (TSD).
The MPQ4233A-AEC1 requires a minimal number of readily available, standard external components, and it is available in a small QFN-19 (4mmx5mm) package with wettable flanks. It is available in AEC-Q100 Grade 1.
- 3A Buck-Boost Converter with Four Integrated MOSFETs
- 3V to 36V Operating Input Voltage (VIN) Range with 2.7V Falling Voltage
- 1V to 24V Output Voltage (VOUT) Range
- I2C-Configurable Reference Voltage (VREF) Range: 0.1V to 2.147V with 1mV Resolution
- Up to 98.14% Peak Efficiency
- Integrated 5V/60mA Low-Dropout (LDO) Regulator to Supply External Microcontroller Unit (MCU)
- Selectable Input or Output Constant-Current (CC) Limit with 5% Accuracy via Factory Trimming
- Accurate Output Current (IOUT) Monitor
- Selectable 280kHz, 420kHz, 600kHz, or 1MHz Switching Frequency (fSW) with Frequency Spread Spectrum (FSS)
- Selectable Automatic Pulse-Frequency Modulation (PFM) or Pulse-Width Modulation (PWM) Mode and Forced PWM Mode
- Configurable I2C Slave Address Supported by the ADDR Pin and I2C Register
- Line Drop Compensation
- I2C, Alert, and One-Time Programmable (OTP) Memory
- Enable (EN) Shutdown Passive Discharge
- Available in a QFN-19 (4mmx5mm) Package with Wettable Flanks
MPQ4233AGVE-0000-AEC1-Z MPQ4233AGVE-0000-AEC1-P MPQ4233AGVE-xxxx-AEC1-Z MPQ4233AGVE-xxxx-AEC1-P
MPQ4233A-AEC1 Resources
STEP-DOWN/STEP-UP CONVERTERSPRODUCT CATEGORY -
USB PD POWER STAGEPRODUCT CATEGORY -
STEP-DOWN/STEP-UP (BUCK-BOOST) CONVERTERS AND CONTROLLERSPRODUCT CATEGORY -
USB TYPE-C POWER DELIVERYAPPLICATIONUSB Type-C power delivery (PD) is gaining popularity across applications and markets, including in automotive. USB ports have become an expected standard in most car models, and are typically expected to offer both charging and data functionality. USB Type-C improves on older USB designed by offering a smaller, reversible port for easy plug-in and double the transfer speed of USB 3.0. USB PD proto...
MPQ8878-AEC1PRODUCT36V, 10A, Four-Switch, Synchronous Buck-Boost Converter with ZDPTM, AEC-Q100 Qualified
MPQ8837-AEC1PRODUCT36V, 8A, 4-Switch, Synchronous Buck-Boost Converter with CC/CV Operation and I2C, AEC-Q100 Qualified
MPQ4232A-AEC1PRODUCT36V, 6A Buck-Boost Converter with Four Integrated MOSFETs and I2C Interface, AEC-Q100 Qualified
MPQ8887-AEC1PRODUCT65V, 9A, High-Efficiency Buck Converter with I2C Interface, Configurable Frequency, and Adjustable OCP, AEC-Q100 Qualified
MPQ4201-AEC1PRODUCT100V, Synchronous, Bidirectional Buck-Boost Controller with I2C, Battery Charging, and Adjustable OCP and PG Indication, AEC-Q100 Qualified
MPQ5038-AEC1PRODUCTUSB PD Source Controller with 7 Configurable PDOs and Load-Shedding, AEC-Q100 Qualified
MPQ8880A-AEC1PRODUCT60V, 4.5A, High-Efficiency, Digital, Configurable, Synchronous Step-Down Converter with PMBus Interface, AEC-Q100 Qualified
MPQ8872-AEC1PRODUCT36V, 2A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface, AEC-Q100 Qualified
MPQ4208-AEC1PRODUCT80V, Synchronous Buck-Boost Controller with I2C And Adjustable OCP and PG Indication, AEC-Q100 Qualified
MPQ8835A-AEC1PRODUCT36V, 6A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface, AEC-Q100 Qualified
