- 車載用IC (AECQ グレード)
- システム監視
- Power Sequencers
- MPQ79720FS-AEC1
MPQ79720FS-AEC1
- Number of Channels8
- 入力電圧(最小) (V)2.7
- 入力電圧 (最大) (V)5.5
- 32kHz Crystal Oscillator DriverYes
- RTCYes
- System Reset SignalYes
- Watchdog TimerYes
- パッケージ(mm)QFN-24 (4x4)
- グレードAutomotive
The MPQ79720FS-AEC1 is an 8-channel, functional safety power sequencer engineered to provide precise power sequencing and safety functions for automotive advanced driver-assistance systems (ADAS) and autonomous driving platforms.
The device’s configurability and flexibility enable design reuse across different applications and system-on-chip (SoC) generations.
The MPQ79720FS-AEC1 contains a crystal driver, a real-time clock (RTC) with an alarm function, a configurable watchdog that can be accessed through the I2C interface, and active-low system reset and interrupt outputs.
Safety mechanisms such as built-in self-testing (BIST) provide high diagnostic coverage, which helps the system achieve its target ASIL rating.
The MPQ79720FS-AEC1 is available in a QFN-24 (4mmx4mm) package with wettable flanks, and is available in AEC-Q100 Grade 1.
- Designed for Automotive Advanced Driver Assistance Systems (ADAS) and Autonomous Driving Platforms:
- 8 Enable Outputs
- Time Slot Based Sequencing
- System Interrupt Signal
- Mission-Critical Safety Features:
- Write Protection on Safety Critical Registers
- Advanced Diagnostics
- Window Watchdog
- Over-Temperature Shutdown
- Support Systems Up to ASIL-D
- ISO 26262 Functional Safety Compliant
- Fast Mode I2C Interface with Cyclic Redundancy Check (CRC)
- Configurable Parameters:
- Sequence Order
- I2C Address
- Watchdog Timing
- Drive Mode for Enable Pins
- Alternate Functions for Enable Pins
- Additional Features:
- Backup Battery Input
- Real-Time Clock (RTC)
- Available in a QFN-24 (4mmx4mm) Package with a 0.5mm Pitch and Wettable Flanks
- Available in AEC-Q100 Grade 1:
- Developed for Functional Safety Applications: ISO 26262 Compliant
MPQ79720FSGRE-xxxx-AEC1-Z MPQ79720FSGRE-xxxx-AEC1-P MPQ79720FSGRE-0000-AEC1-Z MPQ79720FSGRE-0000-AEC1-P
MPQ79720FS-AEC1 Resources
POWER SEQUENCERS製品カテゴリ -
MPQ79730FS-AEC1製品MPSafeTM, ASIL-D, 6-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79721FS-AEC1製品MPSafeTM, ASIL-B, 8-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79711FS-AEC1製品MPSafeTM, ASIL-B, 10-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79710FS-AEC1製品MPSafeTM, ASIL-D, 10-Channel Power Sequencer, AEC-Q100 Qualified
MPQ79701FS-AEC1製品MPSafeTM12 通道电源定序器,符合ASIL-B标准和AEC-Q100认证
MPQ79700FS-AEC1製品MPSafe™ 、ASIL D、12チャネルパワーシーケンサ、AEC-Q100認定
MPQ79520FS-AEC1製品MPSafeTM, ASIL-D, 5-Channel Voltage Monitor, AEC-Q100 Qualified
MPQ79505FS-AEC1製品MPSafeTM, ASIL-D, 6-Channel Voltage Monitor with Integrated Watchdog Timer, AEC-Q100 Qualified
