- 車載用IC (AECQ グレード)
- パワースイッチ
- 理想ダイオード
- MPQ5858-AEC1
MPQ5858-AEC1
- 入力電圧(最小) (V)5
- 入力電圧 (最大) (V)70
- Reverse Battery (V)-80
- Shutdown Iq (uA)2.9
- Supply Iq (uA)260
- Controller / IntegrationController
- Gate Pull Up / Pull Down Capability (mA)300 / 1200
- グレードAutomotive
- パッケージ(mm)QFN-16 (3x4)
The MPQ5858-AEC1 is a front-end battery-conditioning IC that is designed to provide a total system protection and monitoring solution for automotive modules. It integrates a boost converter that provides a strongly boosted voltage to turn on the external N-channel MOSFET.
The device’s 2.9μA shutdown current (ISHDN) makes it ideal for battery-powered applications. Its 20mV ultra-low dropout not only minimizes the power loss, but also allows for a very low minimum input voltage (VIN), which is suitable for cold-crank conditions. In addition, the MPQ5858-AEC1's ultra-fast transient response allows it to meet stringent ISO 7637-2 and ISO 16750-2 requirements.
The MPQ5858-AEC1 provides robust protections, including reverse-battery protection, under-voltage protection (UVP), over-voltage protection (OVP), over-current protection (OCP), short-circuit protection (SCP), thermal warning, and over-temperature protection (OTP).
With an internal MOSFET between the output and ground, the MPQ5858-AEC1 features a configurable output discharge function via the I2C interface to shut down the system quickly. A selectable start-up slew rate also helps to reduce inrush current during start-up. In addition, the MPQ5858-AEC1 integrates a configurable, high-accuracy voltage sense and current sense. The sense features can also be turned off to reduce the quiescent current (IQ).
The MPQ5858-AEC1 can report the fault status via the I2C interface. An open-drain fault pin can also indicate the status of the device. In addition, the MPQ5858-AEC1 integrates a non-volatile memory (NVM), which allows for a high degree of configurability without additional external components.
The MPQ5858-AEC1 is available in a QFN-16 (3mmx4mm) package, and is available in AEC-Q100 Grade 1.
- Built to Handle Tough Automotive Transients and Meets AEC-Q100 Requirement:
- 3.3V to 80V Start-Up Voltage
- -80V Blocking Voltage
- Load Dump Up to 80V
- Cold Crank Down to 0V
- Rectifies AC Frequency Up to 200kHz
- Strong Gate Drive Ability: 800mA Pull Up and 1300mA Pull Down
- Low 2.9μA Shutdown Current (ISHDN)
- Low 260μA Quiescent Current (IQ) in Steady State
- Full Protections and Monitoring:
- Under-Voltage Protection (UVP)
- Over-Temperature Shutdown (OTSD)
- Thermal Warning (TW)
- Voltage and Current Sensing
- Fault Reporting via the Pin and I2C Interface
- Vast Configurability and Flexibility:
- Configurable Soft Start (SS)
- Configurable OCP, SCP, OVP, and UVP Thresholds and Behaviors
- I2C Interface
- Reduces Board Size:
- Available in a QFN-16 (3mmx4mm) Package
- Available with Wettable Flanks
- Additional Features:
- 20mV Ultra-Low Dropout
- Shutdown Output Discharge
- MPSafeTM Compatible - Functional Safety Supporting Document Available
MPQ5858GLE-xxxx-AEC1-Z MPQ5858GLE-xxxx-AEC1-P MPQ5858GLE-0001-AEC1-Z MPQ5858GLE-0001-AEC1-P
MPQ5858-AEC1 Resources
理想ダイオード製品カテゴリ -
フロントカメラ(同軸)アプリケーション -
MPQ5817-AEC1製品42V, 15A, Integrated Smart Diode with Reverse Protection, AEC-Q100 Qualified
MPQ5836-AEC1製品55V, 7A, Integrated Smart Diode with -60V Reverse Protection, AEC-Q100 Qualified
MPQ5852A-AEC1製品36V, Smart Diode Controller with Two Voltage Monitors, AEC-Q100 Qualified
MPQ5857-AEC1製品42Vロードダンプ、フロントエンド・バッテリーコンディショニングIC、AEC-Q100認定済み
MPQ5852-AEC1製品36V、2つの電圧モニタ付き、スマートダイオードコントローラ、AEC-Q100認定
MPQ5850-AEC1製品36V、逆入力保護付きスマートダイオードコントローラ、AEC-Q100認定
カーバッテリーフロントエンド保護用ダイオードコントローラを使用する寄稿文もし、ジャンプスタート、車両メンテナンス、または修理中に車両のバッテリー端子が逆接続されていて、この故障状態に対処できないと、電子制御ユニット (ECU) の部品が損傷する可能性があります。さらに、通常の動作中は、カーバッテリーの電圧は一定ではなく、ISO 7637やISO 16750などのEMC規格によって規制されているいくつかの過渡試験で入力電圧 (VIN) が負になることさえあります。これらの変動は、フロントエンド保護が必要であることを意味します。 ショットキーダイオードとPチャネルMOSFET (P-FET) は、バッテリー逆接続保護および車載での電気過渡保護のための車載電源システム設計で広く使用されています。しかし、これらの従来のソリューションでは消費電力が大きく、熱効率が低下し、設計者がシステムのコストとスペース要件を満たすことがより難しくなります。 本稿では、逆極性ソリュ...
