- 車載用IC (AECQ グレード)
- パワースイッチ
- 理想ダイオード
- MPQ5836-AEC1
MPQ5836-AEC1
- 入力電圧(最小) (V)3
- 入力電圧 (最大) (V)55
- Reverse Battery (V)-60
- Shutdown Iq (uA)2
- Supply Iq (uA)80
- Forward Voltage Drop (mV)140
- Iout (max) (A)7
- Controller / IntegrationIntegration
- Gate Pull Up / Pull Down Capability (mA)120
- グレードAutomotive
- パッケージ(mm)QFN-21 (3x4)
The MPQ5836-AEC1 is an integrated smart diode designed to provide a compact solution for 50W to 170W electronic control unit (ECU) systems with the most simplified external circuity.
The device’s 2µA standby current makes it ideal for battery-powered applications. The MPQ5836-AEC1 integrates a MOSFET and an internal charge pump, which support nominal loads up to 7A of continuous current and minimize power loss between the input and output. The ultra-fast transient response ensures the part can rectify the AC frequency up to 100kHz.
In addition to reverse-polarity protection and reverse-pulse protection, the MPQ5836-AEC1 also provides multiple diagnostics during fault conditions, such as under-voltage (UV), over-voltage (OV), over-current (OC), as well as over-temperature (OT) conditions.
With an extremely low under-voltage lockdown (UVLO) threshold, the device provides a wide operation range to meet the harsh start-up conditions defined in ISO16750. The device can support cold-crank voltages down to 0V.
The MPQ5836-AEC1 is available in a QFN-21 (3mmx4mm) package.
- Built to Handle Tough Automotive Transients and Meets AEC-Q100 Requirements:
- 5V to 55V Start-Up Voltage
- -60V Reverse-Polarity Voltage
- Load Dump Up to 60V
- Cold Crank Down to 0V
- Rectifies AC Frequency Up to 100kHz
- Fast On with +300mV Forward Drop
- Fast Off with -8mV Forward Drop
- Strong Gate Drive Ability: 120mA Pull-Up and 2600mA Pull-Down
- Low 2μA Quiescent Current (IQ) during Standby
- Low 80μA IQ in Steady State
- Reduces Board Size:
- Integrated Charge Pump
- Available in a QFN-21 (3mmx4mm) Package
- Robust Protections and Diagnostics:
- Input Voltage (VIN) Monitor as well as Under-Voltage (UV) and Over-Voltage (OV) Indicator
- VIN Sensing
- An Independent Voltage Monitor and UV Indicator
- Selectable OV/UV Thresholds
- Over-Current Diagnostics
- Over-Temperature Diagnostics
- Fault Reporting
- Additional Features:
- 1.8V, 3.3V, and 5V Logic-Compatible
- Available with Wettable Flanks
- MPSafeTM-Compatible: Functional Safety Supporting Documentation Available
MPQ5836GLE-xxxx-AEC1-Z MPQ5836GLE-xxxx-AEC1-P MPQ5836GLE-0000-AEC1-Z MPQ5836GLE-0000-AEC1-P
MPQ5836-AEC1 Resources
理想ダイオード製品カテゴリ -
フロントカメラ(同軸)アプリケーション -
MPQ5858-AEC1製品80V, Front-End Battery-Conditioning IC, AEC-Q100 Qualified
MPQ5817-AEC1製品42V, 15A, Integrated Smart Diode with Reverse Protection, AEC-Q100 Qualified
MPQ5852A-AEC1製品36V, Smart Diode Controller with Two Voltage Monitors, AEC-Q100 Qualified
MPQ5857-AEC1製品42Vロードダンプ、フロントエンド・バッテリーコンディショニングIC、AEC-Q100認定済み
MPQ5852-AEC1製品36V、2つの電圧モニタ付き、スマートダイオードコントローラ、AEC-Q100認定
MPQ5850-AEC1製品36V、逆入力保護付きスマートダイオードコントローラ、AEC-Q100認定
カーバッテリーフロントエンド保護用ダイオードコントローラを使用する寄稿文もし、ジャンプスタート、車両メンテナンス、または修理中に車両のバッテリー端子が逆接続されていて、この故障状態に対処できないと、電子制御ユニット (ECU) の部品が損傷する可能性があります。さらに、通常の動作中は、カーバッテリーの電圧は一定ではなく、ISO 7637やISO 16750などのEMC規格によって規制されているいくつかの過渡試験で入力電圧 (VIN) が負になることさえあります。これらの変動は、フロントエンド保護が必要であることを意味します。 ショットキーダイオードとPチャネルMOSFET (P-FET) は、バッテリー逆接続保護および車載での電気過渡保護のための車載電源システム設計で広く使用されています。しかし、これらの従来のソリューションでは消費電力が大きく、熱効率が低下し、設計者がシステムのコストとスペース要件を満たすことがより難しくなります。 本稿では、逆極性ソリュ...
