- Products
- Automotive (AECQ Grade)
- Power Switches
- Ideal Diode
- MPQ5836-AEC1
MPQ5836-AEC1
55V, 7A, Integrated Smart Diode with -60V Reverse Protection, AEC-Q100 Qualified
- Vin (min) (V)3
- Vin (max) (V)55
- Reverse Battery (V)-60
- Shutdown Iq (uA)2
- Supply Iq (uA)80
- Forward Voltage Drop (mV)140
- Iout (max) (A)7
- Controller / IntegrationIntegration
- Gate Pull Up / Pull Down Capability (mA)120
- GradeAutomotive
- Package (mm)QFN-21 (3x4)
The MPQ5836-AEC1 is an integrated smart diode designed to provide a compact solution for 50W to 170W electronic control unit (ECU) systems with the most simplified external circuity.
The device’s 2µA standby current makes it ideal for battery-powered applications. The MPQ5836-AEC1 integrates a MOSFET and an internal charge pump, which support nominal loads up to 7A of continuous current and minimize power loss between the input and output. The ultra-fast transient response ensures the part can rectify the AC frequency up to 100kHz.
In addition to reverse-polarity protection and reverse-pulse protection, the MPQ5836-AEC1 also provides multiple diagnostics during fault conditions, such as under-voltage (UV), over-voltage (OV), over-current (OC), as well as over-temperature (OT) conditions.
With an extremely low under-voltage lockdown (UVLO) threshold, the device provides a wide operation range to meet the harsh start-up conditions defined in ISO16750. The device can support cold-crank voltages down to 0V.
The MPQ5836-AEC1 is available in a QFN-21 (3mmx4mm) package.
- Built to Handle Tough Automotive Transients and Meets AEC-Q100 Requirements:
- 5V to 55V Start-Up Voltage
- -60V Reverse-Polarity Voltage
- Load Dump Up to 60V
- Cold Crank Down to 0V
- Rectifies AC Frequency Up to 100kHz
- Fast On with +300mV Forward Drop
- Fast Off with -8mV Forward Drop
- Strong Gate Drive Ability: 120mA Pull-Up and 2600mA Pull-Down
- Low 2μA Quiescent Current (IQ) during Standby
- Low 80μA IQ in Steady State
- Reduces Board Size:
- Integrated Charge Pump
- Available in a QFN-21 (3mmx4mm) Package
- Robust Protections and Diagnostics:
- Input Voltage (VIN) Monitor as well as Under-Voltage (UV) and Over-Voltage (OV) Indicator
- VIN Sensing
- An Independent Voltage Monitor and UV Indicator
- Selectable OV/UV Thresholds
- Over-Current Diagnostics
- Over-Temperature Diagnostics
- Fault Reporting
- Additional Features:
- 1.8V, 3.3V, and 5V Logic-Compatible
- Available with Wettable Flanks
- MPSafeTM-Compatible: Functional Safety Supporting Documentation Available
MPQ5836GLE-xxxx-AEC1-Z MPQ5836GLE-xxxx-AEC1-P MPQ5836GLE-0000-AEC1-Z MPQ5836GLE-0000-AEC1-P
MPQ5836-AEC1 Resources
IDEAL DIODEPRODUCT CATEGORY -
MPQ5858-AEC1PRODUCT80V, Front-End Battery-Conditioning IC, AEC-Q100 Qualified
MPQ5817-AEC1PRODUCT42V, 15A, Integrated Smart Diode with Reverse Protection, AEC-Q100 Qualified
MPQ5852A-AEC1PRODUCT36V, Smart Diode Controller with Two Voltage Monitors, AEC-Q100 Qualified
MPQ5857-AEC1PRODUCT42V Load Dump, Front-End Battery-Conditioning IC, AEC-Q100 Qualified
MPQ5852-AEC1PRODUCT36V, Smart Diode Controller with Two Voltage Monitors, AEC-Q100 Qualified
MPQ5850-AEC1PRODUCT36V, Smart Diode Controller with Reverse Protection, AEC-Q100 Qualified
USING A SMART IDEAL DIODE FOR CAR BATTERY FRONT-END PROTECTIONARTICLEIf the battery terminals in a car are reverse-connected during a jump start, vehicle maintenance, or repair, the components in the electronics control unit (ECU) may be damaged if they cannot handle this fault condition. On top of this, during normal operation the car battery voltage is not constant — the input voltage (VIN) can even be negative under several transient tests regulated by the EMC s...
