- Products
- Automotive (AECQ Grade)
- Power Switches
- Ideal Diode
- MPQ5858-AEC1
MPQ5858-AEC1
- Vin (min) (V)5
- Vin (max) (V)70
- Reverse Battery (V)-80
- Shutdown Iq (uA)2.9
- Supply Iq (uA)260
- Controller / IntegrationController
- Gate Pull Up / Pull Down Capability (mA)300 / 1200
- GradeAutomotive
- Package (mm)QFN-16 (3x4)
The MPQ5858-AEC1 is a front-end battery-conditioning IC that is designed to provide a total system protection and monitoring solution for automotive modules. It integrates a boost converter that provides a strongly boosted voltage to turn on the external N-channel MOSFET.
The device’s 2.9μA shutdown current (ISHDN) makes it ideal for battery-powered applications. Its 20mV ultra-low dropout not only minimizes the power loss, but also allows for a very low minimum input voltage (VIN), which is suitable for cold-crank conditions. In addition, the MPQ5858-AEC1's ultra-fast transient response allows it to meet stringent ISO 7637-2 and ISO 16750-2 requirements.
The MPQ5858-AEC1 provides robust protections, including reverse-battery protection, under-voltage protection (UVP), over-voltage protection (OVP), over-current protection (OCP), short-circuit protection (SCP), thermal warning, and over-temperature protection (OTP).
With an internal MOSFET between the output and ground, the MPQ5858-AEC1 features a configurable output discharge function via the I2C interface to shut down the system quickly. A selectable start-up slew rate also helps to reduce inrush current during start-up. In addition, the MPQ5858-AEC1 integrates a configurable, high-accuracy voltage sense and current sense. The sense features can also be turned off to reduce the quiescent current (IQ).
The MPQ5858-AEC1 can report the fault status via the I2C interface. An open-drain fault pin can also indicate the status of the device. In addition, the MPQ5858-AEC1 integrates a non-volatile memory (NVM), which allows for a high degree of configurability without additional external components.
The MPQ5858-AEC1 is available in a QFN-16 (3mmx4mm) package, and is available in AEC-Q100 Grade 1.
- Built to Handle Tough Automotive Transients and Meets AEC-Q100 Requirement:
- 3.3V to 80V Start-Up Voltage
- -80V Blocking Voltage
- Load Dump Up to 80V
- Cold Crank Down to 0V
- Rectifies AC Frequency Up to 200kHz
- Strong Gate Drive Ability: 800mA Pull Up and 1300mA Pull Down
- Low 2.9μA Shutdown Current (ISHDN)
- Low 260μA Quiescent Current (IQ) in Steady State
- Full Protections and Monitoring:
- Under-Voltage Protection (UVP)
- Over-Temperature Shutdown (OTSD)
- Thermal Warning (TW)
- Voltage and Current Sensing
- Fault Reporting via the Pin and I2C Interface
- Vast Configurability and Flexibility:
- Configurable Soft Start (SS)
- Configurable OCP, SCP, OVP, and UVP Thresholds and Behaviors
- I2C Interface
- Reduces Board Size:
- Available in a QFN-16 (3mmx4mm) Package
- Available with Wettable Flanks
- Additional Features:
- 20mV Ultra-Low Dropout
- Shutdown Output Discharge
- MPSafeTM Compatible - Functional Safety Supporting Document Available
MPQ5858GLE-xxxx-AEC1-Z MPQ5858GLE-xxxx-AEC1-P MPQ5858GLE-0001-AEC1-Z MPQ5858GLE-0001-AEC1-P
MPQ5858-AEC1 Resources
IDEAL DIODEPRODUCT CATEGORY -
MPQ5817-AEC1PRODUCT42V, 15A, Integrated Smart Diode with Reverse Protection, AEC-Q100 Qualified
MPQ5836-AEC1PRODUCT55V, 7A, Integrated Smart Diode with -60V Reverse Protection, AEC-Q100 Qualified
MPQ5852A-AEC1PRODUCT36V, Smart Diode Controller with Two Voltage Monitors, AEC-Q100 Qualified
MPQ5857-AEC1PRODUCT42V Load Dump, Front-End Battery-Conditioning IC, AEC-Q100 Qualified
MPQ5852-AEC1PRODUCT36V, Smart Diode Controller with Two Voltage Monitors, AEC-Q100 Qualified
MPQ5850-AEC1PRODUCT36V, Smart Diode Controller with Reverse Protection, AEC-Q100 Qualified
USING A SMART IDEAL DIODE FOR CAR BATTERY FRONT-END PROTECTIONARTICLEIf the battery terminals in a car are reverse-connected during a jump start, vehicle maintenance, or repair, the components in the electronics control unit (ECU) may be damaged if they cannot handle this fault condition. On top of this, during normal operation the car battery voltage is not constant — the input voltage (VIN) can even be negative under several transient tests regulated by the EMC s...
