- 車載用IC (AECQ グレード)
- AECQ対応スイッチングコンバータとコントローラ
- ステップアップコンバータおよびコントローラ
- MPQ3447-AEC1
MPQ3447-AEC1
- Regulated Outputs1
- 入力電圧(最小) (V)6
- 入力電圧 (最大) (V)80
- Vout (min) (V)6
- Vout (max) (V)80
- Iq (typ) (mA)0.045
- Vfb (V)Fixed
- fsw(最大)(kHz)2500
- PGYes
- SSInternal
- Input/Output DisconnectNo
- パッケージ(mm)QFN-21 (5x5)
- グレードAutomotive
The MPQ3447-AEC1 is a high-efficiency, current-mode, synchronous boost controller with a 6V to 80V wide input voltage (VIN) range. It can operate at multiple phases for high power applications. The device also has the capability to drive 10V MOSFETs, greatly improving efficiency and minimizing power loss.
It provides either an I2C (default) or SPI interface to configure some key operating parameters, such as the switching frequency (fSW), current limit, light-load mode, frequency spread spectrum (FSS), dead time (DT), soft-start (SS) time (tSS), slope compensation, etc. fSW can be adjusted from 250kHz to 2.5MHz or synchronized directly to the external source.
The device also includes under-voltage lockout (UVLO), current limit, and thermal shutdown protection.
The MPQ3447-AEC1 is available in a QFN-21 (5mmx5mm) package. It is available in AEC-Q100 Grade 1.
- Configurable via the I2C or SPI Interface:
- Switching Frequency (fSW)
- Slope Compensation
- Current Limit Reference
- Selectable Light-Load Mode
- Pulse-Skip Modulation (PSM) for Ultra-Light Loads
- Dead Time (DT)
- SYNCIN Phase and Frequency Division
- Synchronous or Non-Synchronous Operation
- Additional Features:
- 10V Gate Driving Capability
- 250kHz to 2.5MHz fSW Synchronizable to an External Clock
- Clock SYNC Out
- Thermal Warning and Thermal Shutdown
- Power Good (PG) Indicator
- Multi-Phase Capability
- Available in a QFN-21 (5mmx5mm) Package
- Available in a Wettable-Flank Package
MPQ3447GUE-xxxx-Z MPQ3447GUE-xxxx-P MPQ3447GUE-0000-Z MPQ3447GUE-0000-P MPQ3447GUE-xxxx-AEC1-Z MPQ3447GUE-xxxx-AEC1-P MPQ3447GUE-0000-AEC1-Z MPQ3447GUE-0000-AEC1-P
MPQ3447-AEC1 Resources
ヘッドライトアプリケーションヘッドライトは、どんな車両においても最も重要な機能安全の1つです。新しい機能ではありませんが、現在、ほとんどの新しい自動車モデルにはLEDヘッドライトが搭載されており、明るさが増し、効率が向上し、ヘッドライトの寿命が長くなりました。そしてもちろん、あらゆる車載アプリケーションと同様に、ヘッドライトの設計は、厳格な熱要件、ISO26262安全規格、およびEMI規制を満たす必要があります。 そのため、MPSではAEC-Q100認定製品の広範な製品ラインアップを提供しています。MPSの非常に効率的で柔軟なライティングソリューションには、ステップアップコンバータ、降圧、昇圧、および昇降圧LEDドライバが含まれます。これらの車載グレードの製品は、最高レベルの安全性と性能を提供すると同時に、市場投入までの時間を短縮します。 MPSの信頼性とコスト効率の高い製品は、次世代の車載用ヘッ...
ステップアップコンバータおよびコントローラ製品カテゴリ -
MPQ3445-AEC1製品Wide-Input, Synchronous Boost Controller with Low IQ Bypass Mode, AEC-Q100 Qualified
MPQ3414C-AEC1製品1.5A、2.2MHz、5VOUT、52μA Iq、出力切断機能付き同期整流ステップアップコンバータ、AEC-Q100認定済み
MPQ3446-AEC1製品55V、広範な入力、電流モード、同期整流昇圧コントローラ、AEC-Q100認定済み
MPQ3438-AEC1製品2A、10V、高効率、完全統合型、同期整流昇圧型コンバータ、AEC-Q100認定
MPQ3431C-AEC1製品21A、設定可能なピークスイッチング電流制限を備えた、高効率で、完全に統合された、同期昇圧コンバータ、AEC-Q100認定
MPQ3432-AEC1製品21A、設定可能な電流制限を備えた、高効率で、完全に統合された、同期整流昇圧型コンバータ、AEC-Q100認定
MPQ3413-AEC1製品1.5A、2.2MHz、 52μA 自己消費電流、 5V VOUT、 出力切断付き同期整流ステップアップコンバータ 、AEC-Q100 認定
MPQ3414B-AEC1製品1.5A、2.2MHz、5V VOUT、52μA 自己消費電流、出力切断付き同期ステップアップコンバータ、AEC-Q100認定
MPQ3452-AEC1製品22V、設定可能なスイッチング周波数を備えた3A昇圧型コンバータ、AEC-Q100認定
MPQ8875A-AEC1製品36V、5A、4スイッチ、I2Cインタフェース付き同期整流昇降圧型コンバータ、 AEC-Q100認定
MPQ3431A-AEC1製品21A、高効率、完全集積、設定可能な入力電流制限を備えた同期整流昇圧型コンバータ、AEC-Q100認定
MPQ3910A-AEC1製品35V、設定可能な周波数、ソフトスタート、および軽負荷動作を備えた昇圧PWMコントローラ、AEC-Q100認定
MPQ3410-AEC1製品1.3A、550kHz 同期整流式ステップアップコンバータ、AEC-Q100認定
MPQ1530-AEC1製品AEC-Q100認定、TFTバイアス用、トリプル出力、昇圧型コンバータおよびリニアレギュレータ
自動車のクランク状態を維持するための設計上の考慮事項寄稿文12Vバッテリーシステムを使用した最近の自動車は多くの過渡状態にさらされています。一部の過渡現象には高電圧パルスを伴うものがあれば、他には過渡現象は低電圧条件下にある場合もあります。クランク過渡現象とは、車のエンジンがスタートし、車のバッテリーが短時間で通常の動作範囲よりも数ボルト低下するときに発生する低電圧状態のことです。 近年、クランク状態時での車両の通常動作を維持するための要件がさらに厳しくなっており、より堅牢な電源ソリューションの必要性が明らかになりました。クランク波形、および特定の電源レールから供給する必要がある負荷によっては、これらの要件を満たすシステムの設計が設計者にとって困難になる場合があります。本稿では、自動車の幅広いクランク過渡現象に耐えることができる堅牢なDC/DCコンバータについて説明します。 12Vの車載システム向けに設計する場合は、極端なスタート条件を考...
