MPQ3447-AEC1
80V Wide-Input, Current-Mode, Synchronous Boost Controller, AEC-Q100 Qualified
- Regulated Outputs1
- Vin (min) (V)6
- Vin (max) (V)80
- Vout (min) (V)6
- Vout (max) (V)80
- Iq (typ) (mA)0.045
- Vfb (V)Fixed
- fsw (max) (kHz)2500
- PGYes
- SSInternal
- Input/Output DisconnectNo
- Package (mm)QFN-21 (5x5)
- GradeAutomotive
The MPQ3447-AEC1 is a high-efficiency, current-mode, synchronous boost controller with a 6V to 80V wide input voltage (VIN) range. It can operate at multiple phases for high power applications. The device also has the capability to drive 10V MOSFETs, greatly improving efficiency and minimizing power loss.
It provides either an I2C (default) or SPI interface to configure some key operating parameters, such as the switching frequency (fSW), current limit, light-load mode, frequency spread spectrum (FSS), dead time (DT), soft-start (SS) time (tSS), slope compensation, etc. fSW can be adjusted from 250kHz to 2.5MHz or synchronized directly to the external source.
The device also includes under-voltage lockout (UVLO), current limit, and thermal shutdown protection.
The MPQ3447-AEC1 is available in a QFN-21 (5mmx5mm) package. It is available in AEC-Q100 Grade 1.
- Configurable via the I2C or SPI Interface:
- Switching Frequency (fSW)
- Slope Compensation
- Current Limit Reference
- Selectable Light-Load Mode
- Pulse-Skip Modulation (PSM) for Ultra-Light Loads
- Dead Time (DT)
- SYNCIN Phase and Frequency Division
- Synchronous or Non-Synchronous Operation
- Additional Features:
- 10V Gate Driving Capability
- 250kHz to 2.5MHz fSW Synchronizable to an External Clock
- Clock SYNC Out
- Thermal Warning and Thermal Shutdown
- Power Good (PG) Indicator
- Multi-Phase Capability
- Available in a QFN-21 (5mmx5mm) Package
- Available in a Wettable-Flank Package
MPQ3447GUE-xxxx-Z MPQ3447GUE-xxxx-P MPQ3447GUE-0000-Z MPQ3447GUE-0000-P MPQ3447GUE-xxxx-AEC1-Z MPQ3447GUE-xxxx-AEC1-P MPQ3447GUE-0000-AEC1-Z MPQ3447GUE-0000-AEC1-P
MPQ3447-AEC1 Resources
HEADLIGHTSAPPLICATIONHeadlights remain one of the most important functional safety features in any vehicle. While not a new feature, most new car models now feature LED headlights to provide increased brightness, better efficiency, and longer headlight lifespans. And of course, as with any automotive application, headlight designs must meet strict thermal requirements, ISO26262 safety standards, and EMC regulations. ...
HEAD UNITS (MID-RANGE)APPLICATIONAutomotive head unit designs have evolved from the traditional hardware interfaces into sophisticated infotainment systems that offer various in-cabin functionalities. These features include navigation, wireless connections, passenger entertainment, gesture recognition, and voice control. As consumer expectations for infotainment features continue to increase, manufacturers face design challenges ...
STEP-UP (BOOST) CONVERTERS AND CONTROLLERSPRODUCT CATEGORY -
MPQ3445-AEC1PRODUCTWide-Input, Synchronous Boost Controller with Low IQ Bypass Mode, AEC-Q100 Qualified
MPQ3414C-AEC1PRODUCT1.5A, 2.2MHz, 5VOUT, 52μA IQ, Synchronous Step-Up Converter with Output Disconnect, AEC-Q100 Qualified
MPQ3446-AEC1PRODUCT55V, Wide-Input, Current-Mode, Synchronous Boost Controller, AEC-Q100 Qualified
MPQ3438-AEC1PRODUCT2A, 10V, High-Efficiency, Fully Integrated, Synchronous Boost Converter, AEC-Q100 Qualified
MPQ3431C-AEC1PRODUCT21A, High-Efficiency, Fully Integrated, Synchronous Boost Converter with Configurable Peak Switching Current Limit, AEC-Q100 Qualified
MPQ3432-AEC1PRODUCT21A, High-Efficiency, Fully Integrated, Synchronous Boost Converter with Configurable Current Limit, AEC-Q100 Qualified
MPQ3413-AEC1PRODUCT1.5A, 2.2MHz, 52μA IQ, 5V VOUT, Synchronous Step-Up Converter with Output Disconnect, AEC-Q100 Qualified
MPQ3414B-AEC1PRODUCT1.5A, 2.2MHz, 5V VOUT, 52μA IQ, Synchronous Step-Up Converter with Output Disconnect, AEC-Q100 Qualified
MPQ3452-AEC1PRODUCT22V, 3A Boost Converter with Configurable Switching Frequency, AEC-Q100 Qualified
MPQ8875A-AEC1PRODUCT36V, 5A, Four-Switch, Synchronous Buck-Boost Converter with I2C Interface AEC-Q100 Qualified
MPQ3431A-AEC1PRODUCT21A, High-Efficiency, Fully Integrated, Synchronous Boost Converter with Configurable Input Current Limit, AEC-Q100 Qualified
MPQ3910A-AEC1PRODUCT35V, Boost PWM Controller with Configurable Frequency, Soft Start, and Light-Load Operation, AEC-Q100 Qualified
MPQ3410-AEC1PRODUCT1.3A, 550kHz Synchronous Rectified Step-Up Converter AEC-Q100 Qualified
MPQ1530-AEC1PRODUCTTriple Outputs Boost Plus Linear Regulators for TFT Bias with AEC-Q100 qualification
DESIGN CONSIDERATIONS TO SUSTAIN AUTOMOTIVE CRANK CONDITIONSARTICLEModern vehicles using 12V battery systems are subjected to a number of transient conditions. Some transients involve high-voltage pulses, while others may be under low-voltage conditions. Crank transients are low-voltage conditions that occur when a car engine starts, and the car battery drops several volts below its normal operating range for a brief time. The requirements to maintain normal veh...
