- 車載用IC (AECQ グレード)
- AECQ対応スイッチングコンバータとコントローラ
- ステップダウンコンバータ
- MPQ2176B-AEC1
MPQ2176B-AEC1
- 入力電圧(最小) (V)2.4
- 入力電圧 (最大) (V)5.5
- Iout (max) (A)6
- Iq (typ) (mA)0.015 (AAM mode), 0.5 (FCCM)
- Vfb (V)0.4
- fsw(最大)(kHz)2700
- Control ModeCOT Control
- パッケージ(mm)TLGA-9 (2x3)
- グレードAutomotive
The MPQ2176B-AEC1 is a monolithic, step-down switch-mode converter with built-in internal power MOSFETs. The device provides 4A to 6A of continuous output current (IOUT) from a 2.4V to 5.5V input voltage (VIN) range, with excellent load and line regulation. The output voltage (VOUT) can be regulated to as low as 0.4V.
The constant-on-time (COT) control scheme provides fast transient response and facilitates loop stabilization. Fault protections include cycle-by-cycle current limiting, input over-voltage protection (OVP), output OVP, and thermal shutdown. These protections provide reliable, fault-tolerant operation.
The MPQ2176B-AEC1 is ideal for a wide range of applications including automotive infotainment, clusters, telematics, and advanced driver-assistance systems (ADAS).
The MPQ2176B-AEC1 requires a minimal number of readily available, standard external components, and is available in a small TLGA-9 (2mmx3mm) package. It is available in AEC-Q100 Grade 1.
- Wide 2.4V to 5.5V Operating Input Voltage (VIN) Range
- 4A to 6A of Continuous Output Current (IOUT)
- Increases Battery Life:
- Advanced Asynchronous Modulation (AAM) Mode
- Designed for High Performance:
- Constant-On-Time (COT) Control Provides Excellent Transient Response
- Constant Frequency in Steady State
- Internal Power MOSFET Switches
- Optimized for EMC/EMI:
- 2.2MHz Switching Frequency (fSW) in Continuous Conduction Mode (CCM)
- Additional Features:
- Enable (EN) Function
- Power Good (PG)
- ±1% 0.4V Feedback (FB) Accuracy
- Short-Circuit Protection (SCP) with Hiccup Mode
- Output Discharge
- Available in a TLGA-9 (2mmx3mm) Package
- MPSafeTM Compatible – Functional Safety Supporting Document Available
MPQ2176BGLNT-xxxx-AEC1-Z MPQ2176BGLNT-xxxx-AEC1-P
MPQ2176B-AEC1 Resources
ステップダウンコンバータ製品カテゴリ -
