MPQ70170FS-AEC1
- Regulated Outputs9
- Vin (min) (V)2.8
- Vin (max) (V)5.5
- Iout (max) (A)16
- Package (mm)QFN-56 (8x8)
- Step-Down DC/DC Controller0
- Step-Down DC/DC Converter5
- Step-Up DC/DC Controller0
- Step-Up DC/DC Converter0
- Internal LDO4
- fsw (max) (kHz)4400
- Step-Down Converter Current (A)4, 4, 4, 4, 2
- LDO Current (A)0.35, 0.35, 0.35, 0.35
- PGYes
- SSInternal
- GradeAutomotive
- Step-Up Converter Current (A)4, 4, 4, 4, 2
The MPQ70170FS-AEC1 is a power management IC (PMIC) designed to power a variety of processors and systems-on-chip (SoCs) used in automotive safety systems. It features five integrated synchronous buck converters and four low-dropout (LDO) regulators. The buck converters offer multi-phase operation, and four of the five buck converters can be configured as two dual-phase converters or one quad-phase converter.
The integrated 13 GPIO pins with multiple functions per pin provide flexibility for a variety of systems. The user-configurable state machine (UCSM), I2C interface with packet error checking (PEC), and integrated multiple-time programmable (MTP) memory allow for a high degree of configurability.
The MPQ70170FS-AEC1 is an ISO 26262 hardware-capable device developed under MPS's advanced MPSafeTM Functional Safety Product Development process, which has been independently certified.
The MPQ70170FS-AEC1 is available in a QFN-56 (8mmx8mm) package with wettable flanks, and is available in AEC-Q100 Grade 1.
- Operating Input Voltage (VIN): 2.8V to 5.5V
- Operating Junction Temperature (TJ): -40°C to +150°C
- Reduces Board Size and BOM:
- Five Step-Down (Buck) Regulators:
- Output Voltage (VOUT) Range: 0.3V to 3.3V
- Output Current (IOUT): 4x 4A and 1x 2A
- Multi-Phase Operation Available for the 4A Bucks, IOUT Up to 16A
- Four Low-Dropout (LDO) Regulators:
- VOUT Range: 0.3V to 3.3V
- IOUT: 4x 350mA
- Bypass Mode
- Optimized for EMC/EMI:
- Switching Frequency (fSW): 2.2MHz / 4.4MHz
- Phase Shift between Buck Regulators
- Application Flexibility via Configurability:
- Fast-Plus Mode via the I2C Interface with Cyclic Redundancy Check (CRC)
- Multiple-Time Programmable (MTP) Memory
- Configurable Power Sequencing
- Configurable Digital Inputs that Can Be Used as User-Configurable State Machine (UCSM) Trigger Sources
- Configurable Soft Start (SS) and Soft Shutdown
- Four 8-Bit Analog-to-Digital Converter (ADC) Channels
- Dynamic Voltage Scaling for Bucks
- PG Pin with Configurable Resources
- 13x GPIOs with Configurable Functions
- Additional Features:
- Backup Battery Input
- 32kHz Crystal Oscillator Driver
- Real-Time Clock (RTC) with Alarm
- Available in a QFN-56 (8mmx8mm) Package with 5mm Pitch and Wettable Flanks
- Functional Safety:
- ISO 26262 Hardware Capable
- Analog/Logic Built-In Self-Testing (BIST)
- Over-Voltage (OV)/Under-Voltage (UV) Monitoring and Over-Current Protection (OCP) on All Rails
- VIN Monitoring with Over-Voltage Protection (OVP)
- Thermal Warning and Shutdown
- CRC
- Interrupt Pin for Fault Reporting
- Reset Pin for System Reset
- Watchdog with Window and Q&A Modes
- Two Error Signal Monitors (ESMs)
- Clock and Bandgap Voltage Monitoring
- Documents Available to Aid ISO 26262 System Design
MPQ70170FSGQQE-xxxxAEC1-Z MPQ70170FSGQQE-xxxxAEC1-P MPQ70170FSGQQE-0000AEC1-Z MPQ70170FSGQQE-0000AEC1-P
MPQ70170FS-AEC1 Resources
REFERENCE DESIGN
VERSAL GEN2 AI EDGE/PRIME (SOC MODE RAIL CONSOLIDATION) AUTOMOTIVE GRADEREFERENCE DESIGN -
PMICSPRODUCT CATEGORY -
MPQ70156FS-AEC1PRODUCTMPSafeTM, ASIL-B, 6V, 3A, PMIC with Buck Converter and 1-Channel Window Voltage Monitor, AEC-Q100 Qualified
MPQ7936-AEC1PRODUCT5V PMIC with 4 Buck Converters (2A/2.5A/4.5A/4.5A), 4 LDOs, and Flexible System Settings via the I2C and MOTP, AEC-Q100 Qualified
MPQ7907-AEC1PRODUCTMPSafeTM-Compatible PMIC, 5.5V, 5 Bucks and 4 LDOs with User-Configurable State Machine, AEC-Q100 Qualified
MPQ7929-AEC1PRODUCTMPSafeTM Compatible, 18V, 4-Channel PMIC with 3 Bucks, 1 LDO, and Uprated Current, AEC-Q100 Qualified
MPQ7932-AEC1PRODUCTMPSafeTM-Compatible, 5.5V PMIC with 6 Buck Converters, AEC-Q100 Qualified
MPQ70332FS-AEC1PRODUCT45V, 3A HV Buck, 2A LV Buck, 250mA LV Boost, ASIL-B PMIC, AEC-Q100 Qualified
MPQ70160FS-AEC1PRODUCTMPSafeTM ASIL-D, 5.5V, PMIC with 6 Buck Converters, AEC-Q100 Qualified
MPQ70333FS-AEC1PRODUCTMPSafeTM, 45V, 3A Buck and 250mA Boost ASIL-D PMIC, AEC-Q100 Qualified
MPQ7902-AEC1PRODUCT45V Power Management IC with 2 Bucks, 1 Boost, and Flexible System Settings via the SPI, AEC-Q100 Qualified
MPQ7935-AEC1PRODUCT5.5V, 5-Channel PMIC with Four 1A Buck Converters and a 300mA LDO, I2C, and OTP, AEC-Q100 Qualified
MPQ4390-AEC1PRODUCT40V, High Current Output, Synchronous, Dual Buck Converter, AEC-Q100 Qualified
MPQ70171FS-AEC1PRODUCTMPSafeTM, ASIL-B, 5.5V PMIC with 5 Bucks and 4 LDOs for Safety-Relevant Applications, AEC-Q100 Qualified
MPQ7970-AEC1PRODUCTMPSafeTM-Compatible, 5.5V PMIC for SoCs, 5 LDOs, 4 GPIOs, and 2 Voltage Monitors, AEC-Q100 Qualified
MPQ7934-AEC1PRODUCTMPSafeTM-Compatible, 36V, 4-Channel PMIC with 3 Bucks and 1 LDO, AEC-Q100 Qualified
MPQ70244FS-AEC1PRODUCTMPSafeTM, ASIL-B, 18V, 4-Channel PMIC with 3 Bucks and 1 LDO, Enhanced PMBus Interface Logic, AEC-Q100 Qualified
MPQ70342FS-AEC1PRODUCTMPSafeTM ASIL-B, 36V, 3-Channel PMIC, AEC-Q100 Qualified
MPQ70341FS-AEC1PRODUCTMPSafeTM, ASIL-B, 36V, 4-Channel PMIC with 3 Bucks and 1 LDO, AEC-Q100 Qualified
MPQ70701FS-AEC1PRODUCTMPSafeTM ASIL-B, 5.5V PMIC for SoCs with 5 LDOs, 4 GPIOs, and 2 Voltage Monitors, AEC-Q100 Qualified
MPQ70241FS-AEC1PRODUCTMPSafeTM, 18V, 4-Channel PMIC with 3 Bucks and 1 LDO, ASIL-B Rated, AEC-Q100 Qualified
MPQ70430FS-AEC1PRODUCT65V, 3A HV Buck, 2A LV Buck, 250mA LV Boost, ASIL-D PMIC, AEC-Q100 Qualified
