- パワーマネジメント
- ディスプレイ用電源とコントローラ
- RGB用LEDドライバ
- MPQ3322-AEC1
MPQ3322-AEC1
24-Channel, Max 100mA/Channel, Current-Source LED Driver with Independent PWM and Analog Dimming, AEC-Q100 Qualified
- 入力電圧(最小) (V)3.5
- 入力電圧 (最大) (V)22
- Channels24
- Ichannel (max) (A)0.1
- LEDx ABS Voltage (V)24
- TopologyLED Driver with Current Source
- Dimming (Output)P-Dim, A-Dim
- Iq (mA)8
- Ishutdown (µA)2
- グレードAutomotive
- パッケージ(mm)QFN-40 (6x6)
- Power MOSFETIntegrated
- Typical LCD Screen SizesSmall (<10"), Medium (10" to 17"), Medium (10" to 29")
The MPQ3322-AEC1 is a 24-channel LED driver with a 24V voltage rating and maximum 100mA current sources. It is designed to drive LED arrays for backlighting, RGB lighting, and interior ambient lighting in automotive LCD panels and lamps.
The MPQ3322-AEC1 employs low headroom to regulate the LED current (ILEDx, where x = 1 to 24). The adaptive voltage feedback (AVF) for the previous power stage optimizes the output voltage (VOUT) for LED strings, which achieves higher system efficiency.
The device supports independent 12-bit pulse-width modulation (PWM) and 6-bit analog dimming for each channel via the based-controller area network (CAN) differential interface. The resistor on the ISET pin (RISET) configures the maximum ILEDx amplitude.
Robust protections are included to guarantee safe device operation. Protection modes include LED open protection, LED short protection (with a configurable threshold via the STH bits (04h, bits[1:0]), and over-temperature protection (OTP). All fault statuses can be read through the CAN interface. In addition, the failsafe function ensures that the MPQ3322-AEC1 remains operating in a preset state if communication information is lost.
The FF pin and single lamp mode (SLM) support single-IC and multi-IC applications for two fault statuses. If one channel fails, then the IC either only turns off the failed LED string or shuts down all channels.
The MPQ3322-AEC1 is available in a QFN-40 (6mmx6mm) package with wettable flanks, and is available in AEC-Q100 Grade 0.
- 3.5V to 22V Input Voltage (VIN) Range
- 24 Channels with Max 100mA per Channel
- <2.5% Current Matching
- Low Dropout Voltage (500mV at 100mA)
- Independent 12-Bit Pulse-Width Modulation (PWM) Dimming
- Independent 6-Bit Analog Dimming
- Adaptive Voltage Feedback (AVF) Function
- 2MHz Based Controller Area Network (CAN) Differential Interface
- Cascades Up to 16 ICs (Pin-Configurable Device Address)
- Improves EMI with LED Current (ILEDx, Where x = 1 to 24) with Slew Rate and Phase Shift
- LED Open/Short Protection
- Fault Indicator Signal Output
- Configurable FF Mode: Fault Flag Mode (FFM) and Single Lamp Mode (SLM)
- Failsafe for Loss of Communication
- Failsafe Mode Set Function
- Available in a QFN-40 (6mmx6mm) Package with Wettable Flanks
- Available in AEC-Q100 Grade 0
MPQ3322GQKE-xxxx-AEC1-Z MPQ3322GQKE-xxxx-AEC1-P MPQ3322GQKE-0000-AEC1-Z MPQ3322GQKE-0000-AEC1-P
MPQ3322-AEC1 Resources
RGB用LEDドライバ製品カテゴリ -
バックライト用LEDドライバ (WLED)製品カテゴリ -
MPQ3368-AEC1製品8-Channel, Max 200mA/Channel, Boost WLED Controller with 10000:1 Dimming Ratio and I2C, AEC-Q100 Qualified
MPQ3321A-AEC1製品48-Channel, Max 80mA/Channel, Current-Source LED Driver with Independent Analog and PWM Dimming, AEC-Q100 Qualified
MPQ3365-AEC1製品4-Channel, Max. 150mA/Ch, Boost WLED Driver with 15000:1 Dimming Ratio and I2C, AEC-Q100 Qualified
MPQ3365A-AEC1製品5-Channel, Max 150mA/Ch, Boost WLED Driver with 15000:1 Dimming Ratio and I2C, AEC-Q100 Qualified
MPQ3366C-AEC1製品6-Channel, Max 200mA/Channel, Boost WLED Controller with 10000:1 Dimming Ratio and I2C, AEC-Q100 Qualified
MPQ3359C-AEC1製品1/2/3/4-Channel, Max 160mA/Ch, Boost WLED Controller with High Dimming Ratio, AEC-Q100 Qualified
MPQ3621-AEC1製品48-Channel, Max 50mA/Ch, Current-Source LED Driver with Independent Analog and PWM Dimming, AEC-Q100 Qualified
MPQ3321-AEC1製品48-Channel, Max 80mA/Ch, Current Source LED Driver with Independent Analog and PWM Dimming, AEC-Q100 Qualified
MPQ3359A-AEC1製品1 / 2 / 3 / 4チャネル、高調光比、最大150mA/Ch、昇圧型白色LEDドライバ、AEC-Q100認定
MPQ3327-AEC1製品シリアルインタフェースとGPIO制御付き、4スイッチのラインスキャンドライバ
MPQ3359-AEC1製品高調光比、4チャネル、最大150mA/Ch、昇圧型白色LEDドライバ、AEC-Q100認定
MP3320N製品3チャネル、チャージポンプ、RGB LEDドライバ
MP3326A製品独立したPWM / アナログ調光とデジタルインタフェース付き、16チャネル、80mA/チャネル、LEDドライバ
MP3320A製品デジタルインタフェース付き、4チャネル、チャージポンプRGB LEDドライバ
MPQ3323B-AEC1製品独立したPWMアナログ調光とデジタルインタフェース付き、4チャネル、320mA/Ch、LEDドライバ、AEC-Q100認定
MP3320B製品デジタルインタフェース付き、4チャネル、同期整流昇圧型RGBW LEDドライバ
MPQ3326B-AEC1製品独立したPWMアナログ調光とシリアルインタフェース (デフォルトでイネーブル) 付き、16チャネル、80mA/Ch、LEDドライバ、AEC-Q100認定
MPQ3326A-AEC1製品独立したPWMアナログ調光とシリアルインタフェース付き、16チャネル、80mA/Ch、LEDドライバ、AEC-Q100認定
MP3324製品独立したPWM / アナログ調光とI2Cインタフェース付き、8チャネル、100mA/Ch、LEDドライバ
MPQ3367A-AEC1製品15000:1調光比およびI2Cインタフェース付き、低EMI、6チャネル、最大150mA/CH、昇圧型白色LEDドライバ、AEC-Q100認定済み
MP3326製品独立したPWMアナログ調光とI2Cインタフェース付き、16チャネル、50mA/チャネル、LEDドライバ
注文
