- Products
- Automotive (AECQ Grade)
- LDO
- MPQ2016-AEC1
MPQ2016-AEC1
- Vin (min) (V)4
- Vin (max) (V)40
- Iout (mA)30
- Vout (min) (V)1.2
- Vout (max) (V)24
- Iq (typ) (µA)12
- PSRR @ 1kHz (dB)65
- Vdropout (mV)700
- Accuracy (±%)2
- Package (mm)QFN-8 (2x3)
- GradeAutomotive
The MPQ2016 is a low-power linear regulator that supplies power to systems with high-voltage batteries. It includes a wide 4V to 40V input range, low dropout voltage and low quiescent supply current.
The MPQ2016 provides excellent line transient response time and 50dB power supply rejection ratio (PSRR). The MPQ2016 can be set externally from 1.2V to 24V through a simple resistor divider network.
The MPQ2016 also includes thermal shutdown and current limiting fault protection. It is available in a QFN-8 (2mmx3mm) package.
- Guaranteed Industrial/Automotive Temp Range Limits
- 4V to 40V Input Range
- 12μA Quiescent Supply Current
- <1.4μA Shutdown Supply Current
- 1.2V to 24V Adjustable Output
- 30mA Output Current with 50mA Peak
- Current Limit
- Better than 0.001%/mA Load Regulation
- Thermal Shutdown
- Available in a QFN-8 (2mmx3mm) Package
MPQ2016DD-LF-Z MPQ2016DD-LF-P MPQ2016DD-AEC1-LF-Z MPQ2016DD-AEC1-LF-P
MPQ2016-AEC1 Resources
LDOPRODUCT CATEGORY -
SINGLE-CHANNELPRODUCT CATEGORY -
MPQ20082-AEC1PRODUCT40V, 300mA, Low Quiescent Current, Adjustable-Output Linear Regulator, AEC-Q100 Qualified
MPQ2019A-AEC1PRODUCT40V, 300mA, Low Quiescent Current, Linear Regulator with Adjustable Output, AEC-Q100 Qualified
MPQ2013D-AEC1PRODUCT40V, 100mA, Low Quiescent Current Linear Regulator, AEC-Q100 Qualified
MPQ2022A-AEC1PRODUCT40V, 300mA Dual-Channel LDO with Serial Digital Interface and ADC for Digital Diagnosis and Protection, AEC-Q100 Qualified
MPQ2026A-AEC1PRODUCT40V, 300mA Dual-Channel LDO with Pre-Boost, Industry-Standard Synchronous Serial Interface, and ADC for Digital Diagnosis and Protection, AEC-Q100 Qualified
MPQ2024A-AEC1PRODUCT40V, 300mA, Phantom Antenna LDO with Pre-Boost, Digital Interface, and ADC for Digital Diagnosis and Protection, AEC-Q100 Qualified
MP2002APRODUCTLow Input Voltage, 500mA Linear Regulator
MPQ20073-AEC1PRODUCT2A, 1.3V to 6V DDR Memory Termination Regulator AEC-Q100 Qualified
Order
