- Products
- Automotive (AECQ Grade)
- LDO
- MPQ71000FS-AEC1
MPQ71000FS-AEC1
MPSafeTM ASIL-D, 36V, 300mA, Dual LDO with ADC and I2C Interface, AEC-Q100 Qualified
- Vin (min) (V)4.5
- Vin (max) (V)36
- Iout (mA)300
- Vout (min) (V)1
- Vout (max) (V)18
- Iq (typ) (µA)32
- PSRR @ 1kHz (dB)93
- Vdropout (mV)165
- Accuracy (±%)0.5
- Package (mm)QFN-14 (3x3), QFN-16 (4x4)
- GradeAutomotive
The MPQ71000FS-AEC1 is a dual-channel, low-dropout (LDO) regulator with an I2C interface and one-time programmable (OTP) memory. The device provides power for automotive advanced driver-assistance systems (ADAS) module and active antennas in automotive systems. The wide input voltage (VIN) range makes the MPQ71000FS-AEC1 suitable for battery cold-crank (3V) conditions, up to load dump (42V) conditions.
The MPQ71000FS-AEC1 delivers up to 300mA of current per channel with excellent load and line regulation. The dual LDO output voltages (VOUT1 and VOUT2) are both configurable via the I2C interface with a range between 1V and 18V. The standard I2C interface provides flexibility in applications. Various parameters can be adjusted by writing the settings in the device without any hardware changes required.
The MPQ71000FS-AEC1 has an internal successive approximation register (SAR) analog-to-digital converter (ADC) to monitor output voltage and current, as well as the temperature. The device is provides full diagnostics of over-current (OC), short-circuit (SC), output over-voltage (OV), under-voltage (UV), short-to-battery (STB), and open-load conditions. It also features thermal shutdown.
Safety mechanisms such as built-in self-testing (BIST) provide high diagnostic coverage, which provides the desired safety coverage for ASIL-D requirements.
The MPQ71000FS-AEC1 is available in flip-chip QFN-14 (3mmx3mm) and wire-bonded QFN-16 (4mmx4mm) packages with wettable flanks. It is available in AEC-Q100 Grade 1.
- Powerful Digital Capabilities:
- No External Resistor Network for Output Voltage (VOUTx) Settings
- Configurable, Dual Low-Dropout (LDO) Regulators:
- 300mA Continuous Output Current (IOUTx) per Channel
- 1V to 18V VOUTx Range
- Adjustable IOUTx Limit
- Multi-Page One-Time Programmable (MOTP) Memory
- Wide 4.5V to 36V Input Voltage (VIN) Range
- Load Dump Up to 42V
- Cold Crank Down to 3V
- Enhanced System Oversight:
- 8-Bit Successive Approximation Register (SAR) Analog-to-Digital Converter (ADC) Monitors Output Currents, Voltages, and Temperatures
- Functional Safety Features:
- MPSafeTM Certified to ISO 26262 ASIL-D
- Analog Built-In Self-Testing (BIST)
- Logic BIST
- Real-Time Register Cyclic Redundancy Check (CRC)
- Non-Volatile Memory (NVM) CRC Protection
- Rich Protections and Diagnostics:
- Output Over-Current (OC) Detection
- Output Over-Voltage (OV) and Under-Voltage (UV) Detection
- Short-to-Battery (STB) Protection
- Open-Load Detection
- Back-to-Back MOSFETs for Reverse-Current Protection
- Over-Temperature (OT) Shutdown Detection
- Fast Mode I2C Interface with Optional Packet Error Checking (PEC)
- Configurable Parameters:
- VOUTx
- Protection Thresholds
- Fault Behaviors
- Power-On Sequencing
- Additional Features:
- 20μA Quiescent Supply Current
- 140mV LDO Voltage
- 93dB High Power Supply Rejection Ratio at 100Hz
- Available in QFN-14 (3mmx3mm) and QFN-16 (4mmx4mm) Packages
- Available in a Wettable-Flank Package
MPQ71000FSGQE-xxxx-AEC1-Z MPQ71000FSGQE-xxxx-AEC1-P MPQ71000FSGQE-0000-AEC1-Z MPQ71000FSGQE-0000-AEC1-P MPQ71000FSGRE-xxxx-AEC1-Z MPQ71000FSGRE-xxxx-AEC1-P MPQ71000FSGRE-0000-AEC1-Z MPQ71000FSGRE-0000-AEC1-P
MPQ71000FS-AEC1 Resources
WIPER CONTROLAPPLICATIONWiper control systems intelligently manage wiper speed, intermittent settings, and automatic rain-sensing features, providing drivers with optimal visibility during various weather conditions. Modern wiper controls focus on safety and convenience. From basic wiper adjustments to sophisticated rain-sensing features, wiper control technology ensures optimal functionality and safety while driving in ...
WINDOW CONTROLAPPLICATIONWindow control systems provide users with seamless control over car windows, allowing for precise adjustments with the touch of a button. Some control options encompass individual window controls, one-touch automatic functions, and safety features like obstruction detection, ensuring convenient and safe operation for passengers. MPS’s comprehensive suite of products includes motor drivers, posi...
SEAT COMFORT CONTROLAPPLICATIONSeat comfort control technology allows users to precisely regulate and personalize the comfort settings of car seats, ensuring an optimal driving experience. Whether it is adjusting lumbar support, seat heating, or ventilation, seat comfort control systems provide a seamless and responsive experience, enhancing the overall comfort within the vehicle. MPS’s comprehensive suite of products includ...
SEAT ADJUSTMENTAPPLICATIONSeat adjustment stands out as a pivotal component of automotive innovation, redefining the user experience within vehicles. This sophisticated application seamlessly integrates with the vehicle's internal systems, allowing occupants to customize their seating preferences effortlessly. Whether it's adjusting the seat height, angle, or lumbar support, seat adjustment systems ensure a personalized an...
TAILGATE CONTROLAPPLICATIONTailgate control offers a seamless and efficient approach to tailgate operation, incorporating intelligent control mechanisms to enhance user convenience and safety in various automotive scenarios. Tailgate control is an advanced solution catering to the evolving needs of automotive tailgate systems. MPS's premier suite of solutions features a comprehensive range of semiconductor components, in...
SUNROOF CONTROLAPPLICATIONSunroof controls are designed to provide seamless and efficient control over automotive sunroof systems. Whether it's adjusting the opening angle, managing the shade, or implementing anti-pinch safety measures, sunroof controls ensure a smooth and responsive experience for both drivers and passengers. MPS's comprehensive suite of solutions encompasses a range of semiconductor components tailore...
REARVIEW MIRROR CONTROLAPPLICATIONRearview mirror control is a critical component of modern vehicles, allowing drivers to adjust their rearview mirrors for optimal visibility and safety. Precise mirror positioning is essential for minimizing blind spots and ensuring a clear view of the road behind. Rearview mirror control contributes significantly to driving safety and convenience, making it a key focus for automotive manufacturer...
HVAC DAMPER CONTROLAPPLICATIONHVAC damper control plays a pivotal role in regulating airflow within heating, ventilation, and air conditioning (HVAC) systems. Precise damper control ensures efficient temperature management and air distribution, resulting in improved energy efficiency and indoor comfort. Achieving this level of control requires reliable and high-performance components. Our exceptional suite of solutions enco...
HEADS-UP DISPLAY (HUD)APPLICATIONIn the fast-evolving landscape of automotive technology, MPS provides cutting-edge components for heads-up display (HUD) applications designed to enhance the driving experience. Innovative HUD systems seamlessly integrate vital information onto the vehicle's windshield, providing drivers with real-time data, navigation prompts, and safety alerts without diverting their attention from the road. ...
REAR DOOR CONTROLAPPLICATIONIn the automotive landscape, MPS provides pivotal components for rear door control applications to ensure seamless and secure control of rear door functionalities. These parts are designed to elevate user convenience and safety by offering precise control over critical aspects of rear door operations, from locking mechanisms to sensor integration. MPS’s comprehensive suite of solutions encompas...
FRONT DOOR CONTROLAPPLICATIONThe front door control system plays a pivotal role in modern automotive design, offering convenience, security, and functionality to both drivers and passengers. This application block provides components for various functions such as power window control, central locking, and mirror adjustments. It ensures seamless access to the vehicle and a comfortable in-cabin experience. MPS's comprehensiv...
ADAPTIVE HEADLAMPSAPPLICATIONAdaptive headlamp systems represent a significant advancement in automotive safety and convenience. These systems intelligently adjust the direction and intensity of a vehicle's headlights in response to various driving conditions, enhancing visibility and reducing glare for both the driver and oncoming traffic. Adaptive headlamps are especially valuable for night driving, as they can help drivers...
HEAD UNITS (MID-RANGE)APPLICATIONAutomotive head unit designs have evolved from the traditional hardware interfaces into sophisticated infotainment systems that offer various in-cabin functionalities. These features include navigation, wireless connections, passenger entertainment, gesture recognition, and voice control. As consumer expectations for infotainment features continue to increase, manufacturers face design challenges ...
LDOPRODUCT CATEGORY -
