- Products
- Automotive (AECQ Grade)
- LDO
- MPQ20085-AEC1
MPQ20085-AEC1
- Vin (min) (V)3
- Vin (max) (V)40
- Iout (mA)150
- Vout (min) (V)3.3
- Vout (max) (V)8
- Iq (typ) (µA)41
- PSRR @ 1kHz (dB)77
- Vdropout (mV)210
- Accuracy (±%)1.35
- Noise (µVrms)280
- Package (mm)QFN-10 (3x3)
- GradeAutomotive
The MPQ20085-AEC1 is a low-dropout (LDO) linear regulator that supplies power to systems that are connected to the battery in automotive applications. It includes a wide 3V to 40V input voltage (VIN) range, making it capable of withstanding transients (such as load dump) that are anticipated in automotive systems.
The device is an optimal solution for powering always-on components such as microcontrollers (MCUs) and controller area network (CAN) transceivers in standby systems. The wide output voltage (VOUT) range allows the device to generate the bias voltage for silicon carbide (SiC) gate drivers and microphones as well as power MCUs and processors.
The MPQ20085-AEC1 also incorporates exceptionally precise VOUT accuracy of ±1.35% across line, load, and temperature. This allows it to quickly react to changes in load or line such as during cold-crank conditions.
The device is equipped with integrated voltage monitoring and power good (PG). The integrated voltage sensor can be used to monitor the VIN and alert downstream components (such as MCUs) when the battery voltage begins to fall. The PG delay and voltage threshold can be adjusted by external components. The low thermal resistance enables sustained operation against dissipation across the device.
The MPQ20085-AEC1 is available in a small QFN-10 (3mmx3mm) package with wettable flanks that facilitate a compact PCB design. It is available in AEC-Q100 Grade 1.
- Versatile Voltage Range:
- Wide 3V to 40V Input Voltage (VIN) Range
- Fixed 3.3V, 4V, 5V, or 8V Output Voltage (VOUT)
- Reduces Board Size:
- Available in a Small QFN-10 (3mmx3mm) Package
- Additional Features:
- ±1.35% Output Accuracy Over-Temperature
- 210mV Low-Dropout Voltage
- High PSRR (77dB at 1kHz)
- Power Good (PG) with Programmable Delay
- Integrated Voltage Monitoring
MPQ20085GQE-xxxx-AEC1-Z MPQ20085GQE-xxxx-AEC1-P
MPQ20085-AEC1 Resources
HEAD UNITS (MID-RANGE)APPLICATIONAutomotive head unit designs have evolved from the traditional hardware interfaces into sophisticated infotainment systems that offer various in-cabin functionalities. These features include navigation, wireless connections, passenger entertainment, gesture recognition, and voice control. As consumer expectations for infotainment features continue to increase, manufacturers face design challenges ...
LDOPRODUCT CATEGORY -
MPQ20082-AEC1PRODUCT40V, 300mA, Low Quiescent Current, Adjustable-Output Linear Regulator, AEC-Q100 Qualified
MPQ2019A-AEC1PRODUCT40V, 300mA, Low Quiescent Current, Linear Regulator with Adjustable Output, AEC-Q100 Qualified
MPQ2013D-AEC1PRODUCT40V, 100mA, Low Quiescent Current Linear Regulator, AEC-Q100 Qualified
MPQ2022A-AEC1PRODUCT40V, 300mA Dual-Channel LDO with Serial Digital Interface and ADC for Digital Diagnosis and Protection, AEC-Q100 Qualified
MPQ2026A-AEC1PRODUCT40V, 300mA Dual-Channel LDO with Pre-Boost, Industry-Standard Synchronous Serial Interface, and ADC for Digital Diagnosis and Protection, AEC-Q100 Qualified
MPQ2024A-AEC1PRODUCT40V, 300mA, Phantom Antenna LDO with Pre-Boost, Digital Interface, and ADC for Digital Diagnosis and Protection, AEC-Q100 Qualified
MPQ2016-AEC1PRODUCT40V, 30mA, Low IQ Linear Regulator, AEC-Q100 Qualified
MPQ20073-AEC1PRODUCT2A, 1.3V to 6V DDR Memory Termination Regulator AEC-Q100 Qualified
MPQ2019-AEC1PRODUCT40V, 300mA, Low-Quiescent Current Adjustable Output Linear Regulator
MPQ2013-AEC1PRODUCT40V, 150mA, Low Quiescent Current Linear Regulator
