- Products
- Automotive (AECQ Grade)
- LDO
- MPQ20031-AEC1
MPQ20031-AEC1
- Vin (min) (V)1.6
- Vin (max) (V)5.5
- Iout (mA)1000
- Vout (min) (V)0.5
- Vout (max) (V)5
- Iq (typ) (µA)26
- PSRR @ 1kHz (dB)59
- Vdropout (mV)400
- Accuracy (±%)1.4
- Noise (µVrms)60
- Package (mm)QFN-8 (2x2), QFN-8 (3x3), TQFN-6 (2x2)
- GradeAutomotive
The MPQ20031-AEC1 is an ultra-low dropout linear regulator that supplies up to 1A of current with a 1.6V to 5.5V input range. The device includes a low-dropout voltage, low quiescent supply current (IQ), and provides fast line and load transient performance, making it ideal for automotive battery-powered equipment.
The MPQ20031-AEC1 provides fixed output voltage (VOUT) options: 0.75V, 0.8V, 0.85V, 1V, 1.2V, 1.8V, 2.5V, 2.8V, or 3.3V. The device also provides adjustable-output options from 0.5V to 5V.
The MPQ20031-AEC1 is stable with small ceramic output capacitors, allowing for a small overall solution size.
Full protection features include integrated thermal shutdown, current limit foldback, power good (PG), and under-voltage lockout (UVLO).
The MPQ20031-AEC1 family provides different package options, including QFN-8 (3mmx3mm), QFN-8 (2mmx2mm), and TQFN-6 (2mmx2mm) packages. It is available in AEC-Q100 Grade 1.
- Built to Handle Tough Automotive Transients and Meet AEC-Q100 Requirements:
- Guaranteed Industrial and Automotive Temperature
- 0.5V to 5V Adjustable Output
- Fixed Output (0.75V, 0.8V, 0.85V, 1V, 1.2V, 1.8V, 2.5V, 2.8V, or 3.3V)
- Outputs ±1.4% Over-Temperature Accuracy
- Stable with Low Output Ceramic Capacitance (>1μF)
- 26µA Quiescent Supply Current (IQ)
- Supports Multiple Package Options:
- Small QFN-8 (3mmx3mm) Package
- Small QFN-8 (2mmx2mm) Package
- Small TQFN-6 (2mmx2mm) Package
- Additional Features:
- 1A Nominal Current
- Current Limit Foldback
- Power Good (PG)
- MPSafeTM Compatible-Functional Safety Supporting Document Available
MPQ20031GQE-xxx0-AEC1-Z MPQ20031GQE-xxx0-AEC1-P MPQ20031GQE-xxx1-AEC1-Z MPQ20031GQE-xxx1-AEC1-P MPQ20031GGTE-xxx0-AEC1-Z MPQ20031GGTE-xxx0-AEC1-P MPQ20031GGE-xxx0-AEC1-Z MPQ20031GGE-xxx0-AEC1-P
MPQ20031-AEC1 Resources
LDOPRODUCT CATEGORY -
MPQ20082-AEC1PRODUCT40V, 300mA, Low Quiescent Current, Adjustable-Output Linear Regulator, AEC-Q100 Qualified
MPQ2019A-AEC1PRODUCT40V, 300mA, Low Quiescent Current, Linear Regulator with Adjustable Output, AEC-Q100 Qualified
MPQ2013D-AEC1PRODUCT40V, 100mA, Low Quiescent Current Linear Regulator, AEC-Q100 Qualified
MPQ2022A-AEC1PRODUCT40V, 300mA Dual-Channel LDO with Serial Digital Interface and ADC for Digital Diagnosis and Protection, AEC-Q100 Qualified
MPQ2026A-AEC1PRODUCT40V, 300mA Dual-Channel LDO with Pre-Boost, Industry-Standard Synchronous Serial Interface, and ADC for Digital Diagnosis and Protection, AEC-Q100 Qualified
