- 車載用IC (AECQ グレード)
- AECQ対応スイッチングコンバータとコントローラ
- ステップダウンコンバータ
- MPQ2183A-AEC1
MPQ2183A-AEC1
6V, 1A to 3A, 2.5MHz, Fixed-Output, Synchronous Step-Down Converter with FSS, AEC-Q100 Qualified
- 入力電圧(最小) (V)2.5
- 入力電圧 (最大) (V)6
- Iout (max) (A)1 to 3
- Iq (typ) (mA)0.021 (AAM mode), 0.465 (FCCM)
- Vfb (V)0.6
- fsw(最大)(kHz)2800
- Control ModeCOT Control
- パッケージ(mm)QFN-8 (1.5x2)
- グレードAutomotive
The MPQ2183A-AEC1 family is a family of monolithic, step-down switch-mode converters with built-in internal power MOSFETs. The family provides 1A to 3A of continuous output current (IOUT) from a 2.5V to 6V input voltage (VIN) range, with excellent load and line regulation.
Constant-on-time (COT) control provides fast transient response and facilitates loop stabilization.
Fault protections include cycle-by-cycle current limiting and thermal shutdown.
The MPQ2183A-AEC1 is ideal for a wide range of applications, including automotive infotainment systems, clusters, and telematics.
The MPQ2183A-AEC1 requires a minimal number of readily available, standard external components, and is available in an ultra-small QFN-8 (1.5mmx2mm) package. It is available in AEC-Q100 Grade 1.
- Wide 2.5V to 6V Operating Input Voltage (VIN) Range
- 1A to 3A Continuous Output Current (IOUT) Version in Pin-Compatible Family
- 1% Output Accuracy
- Junction Temperature (TJ) Operation from -40°C to +150°C
- Increased Battery Life:
- Advanced Asynchronous Modulation (AAM) Mode for Increased Efficiency under Light-Load Conditions
- 21μA Sleep Mode Quiescent Current (IQ)
- High Performance for Improved Thermals
- Internal MOSFETs
- Optimized for EMC and EMI Reduction:
- 2.5MHz Switching Frequency (fSW)
- Forced Continuous Conduction Mode (FCCM) across the Full Load Range
- Optimized for Board Size and BOM:
- Built-In Internal Power MOSFETs
- Integrated Compensation Network
- Fixed Output Options: 0.8V, 1.1V, 1.2V, 1.35V, 1.7V, 1.8V, and 1.9V
- Additional Features:
- Enable (EN) for Power Sequencing
- Power Good (PG) Indicator
- 100% Duty Cycle On
- External Soft Start (SS) Control
- Output Discharge
- Output Voltage (VOUT) Over-Voltage Protection (VOUT OVP)
- Short-Circuit Protection (SCP) with Hiccup Mode
- Available in a QFN-8 (1.5mmx2mm) Package
- Available in a Wettable-Flank Package
- MPSafeTM Compatible – Functional Safety Supporting Document Available
MPQ2183AGQHE-xxxx-AEC1-Z MPQ2183AGQHE-xxxx-AEC1-P
MPQ2183A-AEC1 Resources
ステップダウンコンバータ製品カテゴリ -
