MPQ4384-AEC1
36V, 12A to 18A, Low-EMI, Synchronous Step-Down Converter with ZDPTM, AEC-Q100 Qualified
- Vin (min) (V)3.3
- Vin (max) (V)36
- Iout (max) (A)18
- Iq (typ) (mA)0.009
- Vfb (V)0.8
- fsw (max) (kHz)2500
- Control ModeZDP Control
- Package (mm)TQFN-32 (5x6)
- GradeAutomotive
The MPQ4384-AEC1 is a configurable-frequency (200kHz to 2.5MHz), synchronous step-down switching regulator with an integrated, internal high-side MOSFET (HS-FET) and low-side MOSFET (LS-FET). It provides a highly efficient, 12A to 18A output current (IOUT) with fixed-frequency, Zero-Delay pulse-width modulation (PWM) (ZDPTM) control for an optimal transient response.
The wide 3.3V to 36V input voltage (VIN) range accommodates a variety of step-down applications in the automotive environment. A 1.5μA shutdown-mode quiescent current (IQ) allows the MPQ4384-AEC1 to be used in battery-powered applications.
High power conversion efficiency across a wide load range is achieved by scaling down the switching frequency (fSW) under light-load conditions to reduce switching and gate driver losses. An open-drain power good (PG) signal indicates whether the output is within 95% to 105% of its nominal voltage.
Frequency foldback helps prevent inductor current (IL) runaway during start-up. Thermal shutdown provides reliable, fault-tolerant operation. A high duty cycle and low-dropout (LDO) mode are provided for automotive cold-crank conditions.
The MPQ4384-AEC1 is available in a TQFN-32 (5mmx6mm) package with wettable flanks. It is available in AEC-Q100 Grade 1.
- Designed for Automotive Transients:
- 3.3V to 36V Input Voltage (VIN) Range
- Low-Dropout (LDO) Mode with Soft Recovery
- Highly Scalable Family:
- 12A to 18A Output Current (IOUT) Versions in Pin-Compatible Family
- Multi-Phase Capable Up to 8 Phases
- Designed for High Performance and Reduced Component Overhead:
- Zero-Delay Pulse-Width Modulation (PWM) (ZDPTM) Control for Extremely Fast Transient Response and Fewer External Capacitors
- ±0.5% Output Accuracy, ±1% Power Good (PG) Accuracy
- Fixed or Adjustable Output Voltage (VOUT) Options
- Fixed Output: 0.8V, 1V, 1.2V, 1.8V, 2.5V, 3.3V, 3.8V, or 5V
- Adjustable Output Voltage (VOUT) Up to 13V
- Output Discharge from SW to GND
- 25ns Minimum On Time to Allow High Conversion Ratio
- High Efficiency for Increased Battery Life and Improved Thermals:
- 14μA Standby Current
- Advanced Asynchronous Modulation (AAM) Mode Increases Efficiency under Light Loads
- Integrated, Low-Resistance High-Side MOSFET (HS-FET) and Low-Side MOSFET (LS-FET)
- Thin QFN Package to Facilitate Top-Side Cooling
- Optimized for Low EMC/EMI:
- 200kHz to 2.5MHz Configurable Switching Frequency (fSW)
- Symmetric VIN Pinout Placement
- Low Noise at High Frequency Band Using Quiet-FETTM Advanced Switching Technology
- Synchronizable to an External Clock
- CISPR 25 Class 5 Compliant
- MeshConnectTM Package in a TQFN-32 (5mmx6mm) Package with Wettable Flanks
- MPSafeTM-Compatible: Functional Safety Supporting Document Available
MPQ4384GQJTE-xxxx-AEC1-Z MPQ4384GQJTE-xxxx-AEC1-P MPQ4384GQJTHE-xxxx-AEC1-Z MPQ4384GQJTHE-xxxx-AEC1-P
MPQ4384-AEC1 Resources
HEADLIGHTSAPPLICATIONHeadlights remain one of the most important functional safety features in any vehicle. While not a new feature, most new car models now feature LED headlights to provide increased brightness, better efficiency, and longer headlight lifespans. And of course, as with any automotive application, headlight designs must meet strict thermal requirements, ISO26262 safety standards, and EMC regulations. ...
HEAD UNITS (MID-RANGE)APPLICATIONAutomotive head unit designs have evolved from the traditional hardware interfaces into sophisticated infotainment systems that offer various in-cabin functionalities. These features include navigation, wireless connections, passenger entertainment, gesture recognition, and voice control. As consumer expectations for infotainment features continue to increase, manufacturers face design challenges ...
