- MPQ4374-AEC1
MPQ4374-AEC1
- Vin (min) (V)3.5
- Vin (max) (V)36
- Iout (max) (A)16
- Iq (typ) (mA)0.043
- Vfb (V)0.6
- fsw (max) (kHz)2420
- Control ModeZDP Control
- Package (mm)TQFN-28 (5x6)
- GradeAutomotive
The MPQ4374-AEC1 is a high current output, synchronous buck converter designed for automotive applications. The device has a wide input voltage (VIN) range, fast transient response, high efficiency, and good EMI performance. It can work in dual phase to support up to 32A of continuous output current (IOUT).
The switching frequency (fSW) is selectable between 425kHz and 2.2MHz, or it can be synchronized with an external clock signal. The MPQ4374-AEC1 also provides a frequency spread spectrum (FSS) function to improve EMI performance.
Comprehensive protection features include input under-voltage lockout (UVLO), input over-voltage protection (OVP), cycle-by-cycle peak current limiting, output OVP, output short-circuit protection (SCP), and thermal shutdown.
The MPQ4374-AEC1 is available in a TQFN-28 (5mmx6mm) package with wettable flanks, and is available in AEC-Q100 Grade 1.
- High Power Output Capability:
- Multi-Phase Capability with 2 Phases Up to 32A
- Low-Resistance High-Side MOSFET (HS-FET) and Low-Side MOSFET (LS-FET)
- Built for Automotive Applications:
- Load Dump Up to 40V
- Cold Crank Down to 3V
- Wide Output Voltage (VOUT) Range:
- Outputs Up to 15V with External Feedback (FB) Divider for Adjustable-Output Option
- Fixed-Output Options: 1V, 1.2V, 1.8V, 2.5V, 3.3V, 3.8V, or 5V
- Low Quiescent Current (IQ) and Shutdown Current
- Zero-Delay Pulse-Width Modulation (PWM) Control
- Optimized for EMI/EMC:
- 425kHz or 2.2MHz Switching Frequency (fSW)
- Quiet-FETTM Switching Technology
- CISPR 25 Class 5 Compliant
- Monitoring and Protection Features:
- Cycle-by-Cycle Current Limit
- Input/Output Over-Voltage Protection (OVP)
- Output Short-Circuit Protection (SCP)
- Thermal Shutdown (TSD)
- Power Good (PG) Indicator
- Fault Indicator
- Additional Features:
- Internal Soft Start (SS)
- Clock Synchronization
- Selectable Advanced Asynchronous Modulation (AAM) Mode or Forced Continuous Conduction Mode (FCCM)
- Available in a TQFN-28 (5mmx6mm) Package with Wettable Flanks
- MPSafeTM-Compatible: Functional Safety Supporting Document Available
MPQ4374GQJTE-xxxx-AEC1-Z MPQ4374GQJTE-xxxx-AEC1-P
MPQ4374-AEC1 Resources
HEAD UNITS (MID-RANGE)APPLICATIONAutomotive head unit designs have evolved from the traditional hardware interfaces into sophisticated infotainment systems that offer various in-cabin functionalities. These features include navigation, wireless connections, passenger entertainment, gesture recognition, and voice control. As consumer expectations for infotainment features continue to increase, manufacturers face design challenges ...
