- Products
- Power Modules
- Intelli-Module
- MPC22154-170
MPC22154-170
- Module AssemblyOpen Frame
- Vin (min) (V)4
- Vin (max) (V)16
- Vout (min) (V)0.4
- Vout (max) (V)2
- Iout (max) (A)170
- fsw (min) (kHz)400
- fsw (max) (kHz)2000
- Dimension WxL (mm)8x8
- Dimension (H) (Max) (mm)4.8
- Mounting TypeSurface Mount
- GradeIndustrial
The MPC22154-170 is a dual-phase, non-isolated, high-efficiency step-down power module with Quiet SwitcherTM Technology (QSTTM). It integrates driver MOSFETs (DrMOS) and inductors to provide high efficiency and a small footprint, which is ideal for AI and server applications.
The device has two outputs, which can support both dual-rail operation and single-rail operation. It can achieve up to 170A (85A/phase) of output current (IOUT) across a wide input voltage (VIN) range.
The MPC22154-170 offers many features to simplify system design. It works with tri-state pulse-width modulation (PWM) signal controllers, has Accu-SenseTM current-sensing to monitor the inductor current (IL), and has temperature-sensing to report the junction temperature (TJ).
The MPC22154-170 is available in an LGA-45 (8mmx8mmx4.8mm) package.
- Up to 170A Output Current (IOUT)
- Accu-SenseTM Current-Sensing (CS)
- Temperature-Sensing
- Fault Reporting
- Typical Weight: 1.6g
- Available in an LGA-45 (8mmx8mmx4.8mm) Package
MPC22154-170-T
MPC22154-170 Resources
MPC22174-170PRODUCTDual-Phase, TLVR Intelli-ModuleTM with Quiet SwitcherTM Technology
MP5096PRODUCT5.5V, 1mΩ Low-RDS(ON) E-Fuse with Inrush Current Control and Current Monitoring
MPC16253-X-54-2500PRODUCT2.5kW, Regulated 12V Output, Quarter-Brick, Digital DC/DC Power Module
